[SCM] PostGIS branch stable-3.4 updated. 3.4.1-17-g19fc08111
Wed Dec 27 01:42:43 PST 2023
the project "PostGIS".
The branch, stable-3.4 has been updated
       via  19fc081112317a44b27cde40616fa3f321326e28 (commit)
      from  61b71ba09c98e9d9a3548035e7fcec93c2b0ebc1 (commit)
revisions in full, below.
commit 19fc081112317a44b27cde40616fa3f321326e28
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Dec 27 10:38:30 2023 +0100
    Update run_test.pl to version from master
    Adds:
      - POSTGIS_REGRESS_DB_OWNER env variable
      - POSTGIS_REGRESS_ROLE_EXT_CREATOR env variable
      - Commandline switch --after-create-db-script
diff --git a/regress/run_test.pl b/regress/run_test.pl
index 96028bf4f..7c297ba6d 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -49,6 +49,9 @@ BEGIN {
 our $DB = $ENV{"POSTGIS_REGRESS_DB"} || "postgis_reg";
 our $REGDIR = $ENV{"POSTGIS_REGRESS_DIR"} || abs_path(dirname($0));
+our $DB_OWNER = $ENV{"POSTGIS_REGRESS_DB_OWNER"};
+our $DB_ROLE_EXT_MKR = $ENV{"POSTGIS_REGRESS_ROLE_EXT_CREATOR"} || $DB_OWNER;
 our $TOP_SOURCEDIR = ${REGDIR} . '/..';
 our $ABS_TOP_SOURCEDIR = abs_path(${TOP_SOURCEDIR});
 our $TOP_BUILDDIR = $ENV{"POSTGIS_TOP_BUILD_DIR"};
@@ -80,6 +83,7 @@ my $OPT_EXPECT = 0;
 my $OPT_EXTENSIONS = 0;
 my $OPT_LEGACY = 0;
 my @OPT_HOOK_AFTER_CREATE;
+my @OPT_HOOK_AFTER_CREATE_DB;
 my @OPT_HOOK_AFTER_RESTORE;
 my @OPT_HOOK_BEFORE_DUMP;
 my @OPT_HOOK_BEFORE_TEST;
@@ -112,6 +116,7 @@ GetOptions (
 	'schema=s' => \$OPT_SCHEMA,
 	'build-dir=s' => \$TOP_BUILDDIR,
 	'after-create-script=s' => \@OPT_HOOK_AFTER_CREATE,
+	'after-create-db-script=s' => \@OPT_HOOK_AFTER_CREATE_DB,
 	'after-test-script=s' => \@OPT_HOOK_AFTER_TEST,
 	'before-uninstall-script=s' => \@OPT_HOOK_BEFORE_UNINSTALL,
 	'before-test-script=s' => \@OPT_HOOK_BEFORE_TEST,
@@ -433,7 +438,7 @@ if ( $OPT_DUMPRESTORE )
     print "Creating db '${DB}'\n";
     $rv = create_db();
     if ( ! $rv ) {
-        fail("Could not create db ${DB}", $REGRESS_LOG);
+        fail("Could not create db ${DB} (create_db returned $rv)", $REGRESS_LOG);
         die;
@@ -734,6 +739,9 @@ Options:
   --after-create-script <path>
                   script to load after spatial db creation
                   (multiple switches supported, to be run in given order)
+  --after-create-db-script <path>
+                  script to load after db creation
+                  (multiple switches supported, to be run in given order)
   --before-uninstall-script <path>
                   script to load before spatial extension uninstall
@@ -755,6 +763,21 @@ Options:
   --after-test-script <path>
                   script to load after each test run
+Environment Variables:
+  POSTGIS_REGRESS_DB
+                  Name of database to create and use for regression tests.
+                  Defaults to "postgis_reg"
+  POSTGIS_REGRESS_DB_OWNER
+                  PostgreSQL role to become owner of the regress db.
+                  Defaults to connecting user (determined by libpq env
+                  variables)
+  POSTGIS_REGRESS_ROLE_EXT_CREATOR
+                  PostgreSQL role to switch to for creating/upgrading the
+                  postgis extensions. Defaults to POSTGIS_REGRESS_DB_OWNER
+  POSTGIS_REGRESS_DIR
+                  Base directory of regress tests. Defaults to
+                  name of directory containing this script.
@@ -1490,16 +1513,28 @@ sub create_db
 	my $createcmd = "createdb --encoding=UTF-8 --template=template0 --lc-collate=C";
 	if ( $pgvernum ge 150000 ) {
-		$createcmd .= " --locale=C --locale-provider=libc"
+		$createcmd .= " --locale=C --locale-provider=libc";
-	$createcmd .= " $DB > $REGRESS_LOG";
-	return not system($createcmd);
+	if ( $DB_OWNER ) {
+		$createcmd .= " --owner $DB_OWNER";
+	$createcmd .= " $DB > $REGRESS_LOG 2>&1";
+	return 0 if system($createcmd);
+	foreach my $hook (@OPT_HOOK_AFTER_CREATE_DB)
+		print "Running after-create-db-script $hook\n";
+		die unless load_sql_file($hook, 1);
+	return 1;
 sub create_spatial
     my ($cmd, $rv);
-    print "Creating database '$DB' \n";
+    print "Creating database '$DB'.\n";
     $rv = create_db();
@@ -1546,6 +1581,7 @@ sub load_sql_file
 		my $cmd = "psql $psql_opts -c 'CREATE SCHEMA IF NOT EXISTS $OPT_SCHEMA' ";
 		$cmd .= "-c 'SET search_path TO $OPT_SCHEMA,topology'";
 		$cmd .= " -v \"opt_dumprestore=${OPT_DUMPRESTORE}\"";
+		$cmd .= " -v \"regdir=$REGDIR\"";
 		$cmd .= " -Xf $file $DB >> $REGRESS_LOG 2>&1";
 		#print "  $file\n" if $VERBOSE;
 		my $rv = system($cmd);
@@ -1571,6 +1607,11 @@ sub prepare_spatial_extensions
 	# ON_ERROR_STOP is used by psql to return non-0 on an error
 	my $psql_opts = "--no-psqlrc --variable ON_ERROR_STOP=true";
+	if ( $DB_ROLE_EXT_MKR ) {
+		print "Using role '$DB_ROLE_EXT_MKR' for spatial extensions creation.\n";
+		$psql_opts .= " -c \"set role='$DB_ROLE_EXT_MKR'\"";
 	my $sql = "CREATE SCHEMA IF NOT EXISTS ${OPT_SCHEMA}";
 	my $cmd = "psql $psql_opts -c \"". $sql . "\" $DB >> $REGRESS_LOG 2>&1";
@@ -1802,6 +1843,11 @@ sub upgrade_spatial_extensions
     my $sql;
     my $upgrade_via_function = 0;
+      print "Using role '$DB_ROLE_EXT_MKR' for spatial extensions upgrade.\n";
     if ( $OPT_UPGRADE_TO =~ /!$/ )
       $OPT_UPGRADE_TO =~ s/!$//;
Summary of changes:
 regress/run_test.pl | 56 ++++++++++++++++++++++++++++++++++++++++++++++++-----
 1 file changed, 51 insertions(+), 5 deletions(-)
hooks/post-receive
