[PostGIS] #5650: debbie showing failure on upgrade - ERROR: cannot drop operator @(geometry, geometry) because other objects depend on it (enforce_max_extent_rast_
PostGIS trac at osgeo.org
Wed Dec 27 05:58:50 PST 2023
@(geometry,geometry) because other objects depend on it
  Reporter:  robe     |      Owner:  robe
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 3.3.6
 Component:  raster   |    Version:  3.4.x
Resolution:           |   Keywords:
Comment (by robe):
 Other key errors in those logs
  raster/test/regress/rt_fromgdalraster .. failed (diff expected obtained:
 /tmp/pgis_reg/test_283_diff)
 --- ./raster/test/regress/rt_fromgdalraster_expected    2023-12-27
 04:29:04.050635827 +0000
 +++ /tmp/pgis_reg/test_283_out  2023-12-27 04:31:10.818014496 +0000
 @@ -1,3 +1,4 @@
 +WARNING:  'postgis.gdal_enabled_drivers' is already set and cannot be
 changed until you reconnect
 (0,0,90,90,1,-1,0,0,0,3)|(8100,1479000,182.592592592593,114.982851945091,0,255)|(8100,1479000,182.592592592593,114.982851945091,0,255)|(8100,1453500,179.444444444444,116.438931167192,0,255)
 1|(-168,85,10,10,0.083,-0.083,0,0,4269,3)|(100,0,0,0,0,0)|(100,0,0,0,0,0)|(100,0,0,0,0,0)
 2|(-168,85,10,10,0.083,-0.083,0,0,4326,3)|(100,0,0,0,0,0)|(100,0,0,0,0,0)|(100,0,0,0,0,0)
  raster/test/regress/rt_asgdalraster .. failed (diff expected obtained:
 /tmp/pgis_reg/test_284_diff)
 --- ./raster/test/regress/rt_asgdalraster_expected      2023-12-27
 +++ /tmp/pgis_reg/test_284_out  2023-12-27 04:31:10.906014080 +0000
 @@ -1,3 +1,4 @@
 changed until you reconnect at character 49
  0
  1
  1
  raster/test/regress/rt_astiff .. failed (diff expected obtained:
 /tmp/pgis_reg/test_285_diff)
 --- ./raster/test/regress/rt_astiff_expected    2023-12-27
 +++ /tmp/pgis_reg/test_285_out  2023-12-27 04:31:10.990013680 +0000
 @@ -1,3 +1,4 @@
 changed until you reconnect at character 18
  t
  t
  1
  raster/test/regress/rt_asjpeg .. failed (diff expected obtained:
 /tmp/pgis_reg/test_286_diff)
 --- ./raster/test/regress/rt_asjpeg_expected    2023-12-27
 +++ /tmp/pgis_reg/test_286_out  2023-12-27 04:31:11.050013395 +0000
 @@ -1,3 +1,4 @@
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5650#comment:6>
