[SCM] PostGIS branch master updated. 3.4.0rc1-869-ge6d55d369
Thu Dec 28 01:45:23 PST 2023
the project "PostGIS".
       via  e6d55d369f849687cdd251bdd66d4b9d6b403d2e (commit)
      from  3886dee1bd2b7ea99b45990b0d9475d1082dd3e5 (commit)
revisions in full, below.
commit e6d55d369f849687cdd251bdd66d4b9d6b403d2e
Author: Zuochenwei <zuochenwei5 at gmail.com>
Date:   Thu Dec 28 08:28:30 2023 +0000
    Translated PostGIS Manual using Weblate (Chinese (Simplified))
    Currently translated at 100.0% (5664 of 5664 strings)
    Translation: postgis/PostGIS Manual
    Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/zh_Hans/
diff --git a/doc/po/zh_Hans/postgis-manual.po b/doc/po/zh_Hans/postgis-manual.po
index 362120b18..847d98510 100644
--- a/doc/po/zh_Hans/postgis-manual.po
+++ b/doc/po/zh_Hans/postgis-manual.po
@@ -7,7 +7,7 @@ msgstr ""
 "Project-Id-Version: postgis 3.5\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2023-12-27 04:20+0000\n"
-"PO-Revision-Date: 2023-12-26 03:45+0000\n"
+"PO-Revision-Date: 2023-12-28 09:45+0000\n"
 "Last-Translator: Zuochenwei <zuochenwei5 at gmail.com>\n"
 "Language-Team: Chinese (Simplified) <https://weblate.osgeo.org/projects/"
 "postgis/postgis-manual/zh_Hans/>\n"
@@ -21633,7 +21633,7 @@ msgstr ""
 #, no-c-format
 msgid ""
 "Returns the n-D distance between the A and B geometries or bounding boxes"
-msgstr ""
+msgstr "返回 A 和 B 几何图形或边界框之间的 n 维距离"
 #. Tag: para
 #, no-c-format
@@ -21643,9 +21643,9 @@ msgid ""
 "geometries. Useful for doing nearest neighbor <emphasis "
 "role=\"strong\">approximate</emphasis> distance ordering."
 msgstr ""
-"<varname><<->></varname>运算符返回两个几何图形边界框质心之间的 n "
-"维(欧几里德)距离。 对于进行最 近邻<emphasis role=\"strong\">近似</emphasis>"
-"距离排序很有用。"
+"<varname><<->></varname>运算符返回两个几何图之间的 n "
+"维(欧几里德)距离。 对于进行最 近邻<emphasis role=\"strong\""
+">近似</emphasis>距离排序很有用。"
 #. Tag: para
 #, no-c-format
Summary of changes:
 doc/po/zh_Hans/postgis-manual.po | 10 +++++-----
 1 file changed, 5 insertions(+), 5 deletions(-)
hooks/post-receive
