[PostGIS] #5652: Upgrade raster tests running even if postgis raster is disabled
PostGIS trac at osgeo.org
Fri Dec 29 16:23:03 PST 2023
 Reporter:  robe     |      Owner:  strk
     Type:  defect   |     Status:  new
 Priority:  blocker  |  Milestone:  PostGIS 3.5.0
Component:  upgrade  |    Version:  master
 Keywords:           |
 Cirrus builds are failing on master
 https://cirrus-ci.com/task/4631711644909568
  --------------- Extensions ---------------
   PostgreSQL EXTENSION support:       enabled
   PostGIS Raster:                     disabled
   PostGIS Topology:                   enabled
   SFCGAL support:                     enabled
   Address Standardizer support:       enabled
 /usr/local/bin/perl -lpe
 "s'MODULE_PATHNAME'\$libdir/postgis_sfcgal-3'g;s'@extschema@\.''g" >
 sfcgal_after_upgrade.sql
 rm -f sfcgal_after_upgrade.sql.tmp
 echo "BEGIN;" > sfcgal_upgrade.sql
 cat sfcgal_before_upgrade.sql sfcgal_upgrade.sql.in
 sfcgal_after_upgrade.sql >> sfcgal_upgrade.sql
 echo "COMMIT;" >> sfcgal_upgrade.sql
 gmake[1]: Leaving directory '/tmp/cirrus-ci-build/sfcgal'
 ---- Making all in utils
 gmake[1]: Entering directory '/tmp/cirrus-ci-build/utils'
 sed -e '1,/^__END__/d' postgis_restore.pl.in \
         | sort -u \
         > postgis_restore_data.hardcoded
 gmake[1]: *** No rule to make target
 '../raster/rt_pg/rtpostgis_upgrade.sql', needed by
 'postgis_restore_data.generated'.  Stop.
 gmake[1]: Leaving directory '/tmp/cirrus-ci-build/utils'
 gmake: *** [GNUmakefile:27: all] Error 1
 I think it might have something to do with the fact that they don't have
 raster enabled, so they shouldn't even be trying to build raster extension
 or upgrades scripts.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5652>
