[postgis-tickets] [SCM] postgis.net branch website updated. 3e516bc3e1620bcc7f1b12419a18fb6909ecac54
Fri Feb 3 21:18:20 PST 2023
the project "postgis.net".
The branch, website has been updated
       via  3e516bc3e1620bcc7f1b12419a18fb6909ecac54 (commit)
      from  a50e70ef860218b3fd8014a492fc9c343d3af92d (commit)
revisions in full, below.
commit 3e516bc3e1620bcc7f1b12419a18fb6909ecac54
Author: Regina Obe <lr at pcorp.us>
Date:   Sat Feb 4 00:12:16 2023 -0500
    Detail how to fix a broken raster install
diff --git a/content/post/2023/02-03_tip-removing-raster-3.md b/content/post/2023/02-03_tip-removing-raster-3.md
new file mode 100644
index 0000000..8911d97
--- /dev/null
+++ b/content/post/2023/02-03_tip-removing-raster-3.md
@@ -0,0 +1,72 @@
+title: Fixing a broken postgis raster install
+slug: tip-removing-raster-from-2-3
+layout: post
+category: tips
+tags: [newbie, upgrade]
+author: Regina Obe
+thumbnail:
+date: "2023-02-03"
+As of PostGIS 3.0, the PostGIS raster support is no longer part of the
+`postgis` extension, but instead spun off into a PostGIS extension called `postgis_raster`.
+[Upgrading raster from 2.* to 3.*](/2022/01/14/tip-upgrading-raster-from-2-3) covers the proper
+way of upgrading your install from PostGIS 2+ to PostGIS 3+.
+Unfortunately many people in a heat of panic when seeing the notice "UNPACKAGED"
+in their check of
+```SELECT postgis_full_extension()```
+tried to do something like drop raster type with cascade. Dropping the raster type *DOES NOT* remove
+all the raster functions, but *DOES* destroy all your raster data if you had any. Do not do that.
+But if you did happen to do that, this solution is for you.
+The only solution after breaking your raster install is to remove the remaining bits of the postgis raster functionality.
+At that point, you can reinstall using `CREATE EXENSION postgis_raster`, or not bother if you don't need
+raster support.
+<!--more-->
+How do you know your raster install is broken?
+If you run:
+```postgres
+ALTER EXTENSION postgis UPDATE;
+-- yes run it twice
+SELECT postgis_extensions_upgrade();
+and then check
+```postgres
+SELECT postgis_full_version();
+and you still see the message
+```RASTER (raster lib from "2.5.3 r17699" need upgrade) [UNPACKAGED!]```
+You've broken your raster functionality so badly, it can't be upgraded.
+First before doing anything, confirm you have no raster tables.
+The below query should either error out or return **0**:
+```postgres
+SELECT count(1) FROM raster_columns;
+To fix this issue, run the script [*uninstall_rtpostgis.sql*](/stuff/uninstall_rtpostgis.sql).
+It should remove even older versions of postgis raster functions, since the function sets of older versions are generally a subset of the 2.5.
+Now to confirm it is all gone, run the below again.
+```postgres
+You should now see no mention of *RASTER* or *GDAL*.
Summary of changes:
 content/post/2023/02-03_tip-removing-raster-3.md | 72 ++++++++++++++++++++++++
 1 file changed, 72 insertions(+)
 create mode 100644 content/post/2023/02-03_tip-removing-raster-3.md
hooks/post-receive
postgis.net
