[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-590-gdd3d8a4cd
Tue Feb 7 23:33:58 PST 2023
the project "PostGIS".
       via  dd3d8a4cd8595dac230f49a272f9b403fe4ee6fb (commit)
      from  bf31e1dedef2eb6735603276f7369475dc9ae2a3 (commit)
revisions in full, below.
commit dd3d8a4cd8595dac230f49a272f9b403fe4ee6fb
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Tue Feb 7 23:33:54 2023 -0800
    Improve doc for Topology
diff --git a/doc/extras_topology.xml b/doc/extras_topology.xml
index 2519450e0..57d78db02 100644
--- a/doc/extras_topology.xml
+++ b/doc/extras_topology.xml
@@ -463,8 +463,7 @@ SELECT topology.RenameTopoGeometryColumn('public.parcels', 'topogeom', 'tgeom');
                 <title>Description</title>
                 <para>
-Renames a topology schema updating its metadata record in
-topology.topology.
+Renames a topology schema, updating its metadata record in the <varname>topology.topology</varname> table.
 		</para>
                 <!-- use this format if new function -->
@@ -475,8 +474,7 @@ topology.topology.
 			<refsection>
 				<title>Examples</title>
 				<para>
-This example renames a topology from <varname>topo_stage</varname> to
-<varname>topo_prod</varname>.
+Rename a topology from <varname>topo_stage</varname> to <varname>topo_prod</varname>.
 				</para>
 				<programlisting>SELECT topology.RenameTopology('topo_stage', 'topo_prod');</programlisting>
@@ -486,7 +484,7 @@ This example renames a topology from <varname>topo_stage</varname> to
 			<refsection>
 				<title>See Also</title>
-				<para>>
+				<para>
                     <xref linkend="CopyTopology" />,
                     <xref linkend="RenameTopoGeometryColumn" />
                 </para>
@@ -1141,7 +1139,7 @@ ANALYZE themselves, to use updated statistics.
 		<refentry id="CreateTopology">
 			<refnamediv>
 				<refname>CreateTopology</refname>
-				<refpurpose>Creates a new topology schema and registers this new schema in the topology.topology table.</refpurpose>
+				<refpurpose>Creates a new topology schema and registers it in the topology.topology table.</refpurpose>
 			</refnamediv>
 			<refsynopsisdiv>
@@ -1177,11 +1175,23 @@ ANALYZE themselves, to use updated statistics.
 			<refsection>
-                <para>Creates a new schema with name <varname>topology_name</varname> consisting of tables (<varname>edge_data</varname>,<varname>face</varname>,<varname>node</varname>, <varname>relation</varname>
-                    and registers this new topology in the topology.topology table. It returns the id of the topology in the topology table. The srid is the spatial reference identified as
-                defined in spatial_ref_sys table for that topology.  Topologies must be uniquely named.  The tolerance is measured in the units of the spatial reference system.  If the tolerance (<varname>prec</varname>) is not specified defaults to 0.</para>
+                <para>Creates a new topology schema with name <varname>topology_name</varname>
+                and registers it in the <varname>topology.topology</varname> table.
+				Topologies must be uniquely named.
+				The topology tables (<varname>edge_data</varname>, <varname>face</varname>, <varname>node</varname>,and <varname>relation</varname> are created in the schema.
+				It returns the id of the topology.
+				</para>
+ 				<para>The <varname>srid</varname> is the <link linkend="spatial_ref_sys">spatial reference system</link> SRID for the topology.
+				</para>
+				<para>The tolerance <varname>prec</varname> is measured in the units of the spatial reference system.
+				The tolerance defaults to 0.
+				</para>
+				<para><varname>hasz</varname> defaults to false if not specified. </para>
-                <para>This is similar to the SQL/MM <xref linkend="ST_InitTopoGeo" /> but a bit more functional.  <varname>hasz</varname> defaults to false if not specified.</para>
+                <para>This is similar to the SQL/MM <xref linkend="ST_InitTopoGeo" /> but has more functionality.</para>
                 <para>Availability: 1.1</para>
@@ -1191,12 +1201,12 @@ ANALYZE themselves, to use updated statistics.
 			<refsection>
-				<para>This example creates a new schema called ma_topo that will store edges, faces, and relations in Massachusetts State Plane meters.
-					The tolerance represents 1/2 meter since the spatial reference system is a meter based spatial reference system</para>
-				<programlisting>SELECT topology.CreateTopology('ma_topo',26986, 0.5);</programlisting>
+				<para>Create a topology schema called <varname>ma_topo</varname> that stores edges and nodes in Massachusetts State Plane-meters (SRID = 26986).
+					The tolerance represents 0.5 meters since the spatial reference system is meter-based.</para>
+				<programlisting>SELECT topology.CreateTopology('ma_topo', 26986, 0.5);</programlisting>
-				<para>Create Rhode Island topology in State Plane ft</para>
-<programlisting>SELECT topology.CreateTopology('ri_topo',3438) As topoid;
+				<para>Create a topology for Rhode Island called <varname>ri_topo</varname> in spatial reference system State Plane-feet (SRID = 3438)</para>
+<programlisting>SELECT topology.CreateTopology('ri_topo', 3438) AS topoid;
 topoid
 2</programlisting>
@@ -1213,7 +1223,7 @@ topoid
 		<refentry id="CopyTopology">
 			<refnamediv>
 				<refname>CopyTopology</refname>
-				<refpurpose>Makes a copy of a topology structure (nodes, edges, faces, layers and TopoGeometries).</refpurpose>
+				<refpurpose>Makes a copy of a topology (nodes, edges, faces, layers and TopoGeometries) into a new schema</refpurpose>
 			</refnamediv>
 			<refsynopsisdiv>
@@ -1230,11 +1240,14 @@ topoid
                 <para>
-Creates a new topology with name <varname>new_topology_name</varname> and SRID and precision taken from <varname>existing_topology_name</varname>, copies all nodes, edges and faces in there, copies layers and their TopoGeometries too.
+Creates a new topology with name <varname>new_name</varname>, with SRID and precision copied from <varname>existing_topology_name</varname>
+The nodes, edges and faces in <varname>existing_topology_name</varname> are copied into the new topology,
+as well as Layers and their associated TopoGeometries.
 		</para>
                 <note><para>
-The new rows in topology.layer will contain synthesized values for schema_name, table_name and feature_column. This is because the TopoGeometry will only exist as a definition but won't be available in any user-level table yet.
+The new rows in the <varname>topology.layer</varname> table contain synthetic values for schema_name, table_name and feature_column.
+This is because the TopoGeometry objects exist only as a definition and are not yet available in a user-defined table.
 		</para></note>
@@ -1245,9 +1258,9 @@ The new rows in topology.layer will contain synthesized values for schema_name,
 			<refsection>
 				<para>
-This example makes a backup of a topology called ma_topo
+Make a backup of a topology called <varname>ma_topo</varname>.
 				</para>
-				<programlisting>SELECT topology.CopyTopology('ma_topo', 'ma_topo_bakup');</programlisting>
+				<programlisting>SELECT topology.CopyTopology('ma_topo', 'ma_topo_backup');</programlisting>
 			</refsection>
@@ -1266,7 +1279,7 @@ This example makes a backup of a topology called ma_topo
 		<refentry id="ST_InitTopoGeo">
 			<refnamediv>
 				<refname>ST_InitTopoGeo</refname>
-				<refpurpose>Creates a new topology schema and registers this new schema in the topology.topology table and details summary of process.</refpurpose>
 			</refnamediv>
 			<refsynopsisdiv>
@@ -1281,7 +1294,9 @@ This example makes a backup of a topology called ma_topo
 			<refsection>
-                <para>This is an SQL-MM equivalent of CreateTopology but lacks the spatial reference and tolerance options of CreateTopology and outputs a text description of creation instead of topology id.</para>
+                <para>This is the SQL-MM equivalent of <xref linkend="CreateTopology"/>.
+                It lacks options for spatial reference system and tolerance.
+                it returns a text description of the topology creation, instead of the topology id.</para>
Summary of changes:
 doc/extras_topology.xml | 59 +++++++++++++++++++++++++++++++------------------
 1 file changed, 37 insertions(+), 22 deletions(-)
hooks/post-receive
