[postgis-tickets] [PostGIS] #5335: Specific query hangs and can't be terminated when using ST_MVT/ST_AsMVTGeom
PostGIS trac at osgeo.org
Wed Feb 8 14:09:59 PST 2023
  Reporter:  seabre   |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS PostgreSQL
 Component:  postgis  |    Version:  2.5.x
Resolution:           |   Keywords:
Comment (by seabre):
 The plan is for us to upgrade fairly soon, but running into the issues now
 and didn't see anything similar reported in the changelogs. I'm able to
 reproduce consistently on the affected machine but if I load a dump into a
 machine with the following versions:
 POSTGIS="2.5.5" [EXTENSION] PGSQL="110" GEOS="3.7.3-CAPI-1.11.3 b50468f"
 PROJ="Rel. 5.2.0, September 15th, 2018" GDAL="GDAL 2.4.4, released
 2020/01/08" LIBXML="2.9.11" LIBJSON="0.13.1" LIBPROTOBUF="1.3.3" RASTER
 PostgreSQL 11.15 on x86_64-apple-darwin16.7.0, compiled by Apple LLVM
 version 8.1.0 (clang-802.0.42), 64-bit
 The query runs fine, so it could be that any of the above mentioned
 solutions solve the problem. I'll dig more and see if I can provide more
 than what is in the original ticket.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5335#comment:2>
