[postgis-tickets] [PostGIS] #5332: Override proj_log_func to stop proj errors leaking out to PgSQL logs
PostGIS trac at osgeo.org
Fri Feb 10 12:56:48 PST 2023
  Reporter:  pramsey      |      Owner:  pramsey
      Type:  enhancement  |     Status:  assigned
  Priority:  medium       |  Milestone:  PostGIS 3.4.0
 Component:  postgis      |    Version:  3.3.x
Resolution:               |   Keywords:
Comment (by Paul Ramsey <pramsey@…>):
 In [changeset:"09b8c222198bd6d81ca324442360d491dafcf278/git" 09b8c22/git]:
 {{{#!CommitTicketReference repository="git"
 revision="09b8c222198bd6d81ca324442360d491dafcf278"
 When libproj throws at error, don't just write the
 message to stderr. Catch it and put it into the
 PgSQL log at a DEBUG level.
 We check all return values and return codes when
 calling into the proj API, so the extra error messages
 don't really help us.
 This is in response to our calls to proj_create()
 dumping messages into stderr, which confuses operators.
 Our projection code has to try a bunch of possible
 strings to instantiate projection objects, some of
 which fail (generating a message) and then we fall
 back to the next string. The proj "errors" are not
 errors from our pov, so we catch them and send them
 along at much lower priority.
 References #5332
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5332#comment:3>
