[postgis-tickets] [PostGIS] #5336: topoelementarray_agg that takes topogeom
PostGIS trac at osgeo.org
Mon Feb 13 09:30:31 PST 2023
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS 3.4.0
Component:  postgis  |    Version:  master
 Keywords:           |
 When you want to pass in a topogeom as a topoelement for building, the
 syntax is pretty ugly and hard to explain.
 As discussed in this thread
 https://lists.osgeo.org/pipermail/postgis-users/2023-February/045845.html
 In order to build hierarchical topoelement using topogeom, you need to do
 this ugly thing of
 TopoElementArray_Agg(
 ARRAY[(topo).id,(topo).layer_id]::topology.topoelement )
 It would be cleaner if we have a topoelementArray_agg that takes a topo or
 have topogeometry be able to autocast to a topoelement.
 Then the above would reduce to
 TopoElementArray_Agg( topo )
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5336>
