[postgis-tickets] [PostGIS] #5336: topoelementarray_agg that takes topogeom
PostGIS trac at osgeo.org
Mon Feb 13 09:31:40 PST 2023
  Reporter:  robe      |      Owner:  robe
      Type:  defect    |     Status:  new
  Priority:  medium    |  Milestone:  PostGIS 3.4.0
 Component:  topology  |    Version:  master
Resolution:            |   Keywords:
Description changed by robe:
Old description:
> When you want to pass in a topogeom as a topoelement for building, the
> syntax is pretty ugly and hard to explain.
> As discussed in this thread
> https://lists.osgeo.org/pipermail/postgis-users/2023-February/045845.html
> In order to build hierarchical topoelement using topogeom, you need to do
> this ugly thing of
> TopoElementArray_Agg(
> ARRAY[(topo).id,(topo).layer_id]::topology.topoelement )
> It would be cleaner if we have a topoelementArray_agg that takes a topo
> or have topogeometry be able to autocast to a topoelement.
> Then the above would reduce to
> TopoElementArray_Agg( topo )
New description:
 this ugly thing of
 topogeometry or have topogeometry be able to autocast to a topoelement.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5336#comment:2>
