[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-602-g12befaaa4
Mon Feb 13 09:32:31 PST 2023
the project "PostGIS".
       via  12befaaa4befd6ce57dadb9dbf8797e4b9fbde65 (commit)
      from  b1b8c11bfe54d7756ed53719e74783dd2733d3df (commit)
revisions in full, below.
commit 12befaaa4befd6ce57dadb9dbf8797e4b9fbde65
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Feb 10 11:02:12 2023 +0100
    Add before and after test hooks in run_test.pl
diff --git a/regress/run_test.pl b/regress/run_test.pl
index 06667de1a..c78e76631 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -77,6 +77,8 @@ my $OPT_WITH_SFCGAL = 0;
 my $OPT_EXPECT = 0;
 my $OPT_EXTENSIONS = 0;
 my @OPT_HOOK_AFTER_CREATE;
+my @OPT_HOOK_BEFORE_TEST;
+my @OPT_HOOK_AFTER_TEST;
 my @OPT_HOOK_BEFORE_UNINSTALL;
 my @OPT_HOOK_BEFORE_UPGRADE;
 my @OPT_HOOK_AFTER_UPGRADE;
@@ -104,7 +106,9 @@ GetOptions (
 	'schema=s' => \$OPT_SCHEMA,
 	'build-dir=s' => \$TOP_BUILDDIR,
 	'after-create-script=s' => \@OPT_HOOK_AFTER_CREATE,
+	'after-test-script=s' => \@OPT_HOOK_AFTER_TEST,
 	'before-uninstall-script=s' => \@OPT_HOOK_BEFORE_UNINSTALL,
+	'before-test-script=s' => \@OPT_HOOK_BEFORE_TEST,
 	'before-upgrade-script=s' => \@OPT_HOOK_BEFORE_UPGRADE,
 	'after-upgrade-script=s' => \@OPT_HOOK_AFTER_UPGRADE
@@ -461,6 +465,12 @@ foreach $TEST (@ARGV)
 	# catch a common mistake (strip trailing .sql)
 	$TEST =~ s/.sql$//;
+	foreach my $hook (@OPT_HOOK_BEFORE_TEST)
+		print "  Running before-test-script $hook\n" if $VERBOSE > 1;
+		die unless load_sql_file($hook, 1);
 	start_test($TEST);
 	$TEST_OBJ_COUNT_PRE = count_postgis_objects();
@@ -543,6 +553,12 @@ foreach $TEST (@ARGV)
 		fail("PostGIS object count pre-test ($TEST_OBJ_COUNT_POST) != post-test ($TEST_OBJ_COUNT_PRE)");
+	foreach my $hook (@OPT_HOOK_AFTER_TEST)
+		print "  Running after-test-script $hook\n" if $VERBOSE > 1;
 foreach my $hook (@OPT_HOOK_BEFORE_UNINSTALL)
@@ -642,6 +658,12 @@ Options:
   --after-upgrade-script <path>
                   script to load after upgrade
                   (multiple switches supported, to be run in given order)
+  --before-test-script <path>
+                  script to load before each test run
+                  (multiple switches supported, to be run in given order)
+  --after-test-script <path>
+                  script to load after each test run
Summary of changes:
 regress/run_test.pl | 22 ++++++++++++++++++++++
 1 file changed, 22 insertions(+)
hooks/post-receive
