[postgis-tickets] [PostGIS] #5142: still failures on marc21 on my local system
PostGIS trac at osgeo.org
Tue Feb 14 12:38:56 PST 2023
  Reporter:  robe     |      Owner:  robe
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 3.4.0
 Component:  postgis  |    Version:  master
Resolution:           |   Keywords:
Comment (by robe):
 @pramsey you are so negative.  It's only failing on windows testing
 against mingw64 (my gcc 8.1, migth not be be failing on my gcc 12.2 (which
 I haven't turned on yet, since I'm struggling building proj on it). Are
 you getting failures too? I'll take out the 3 tests that are failing for
 me, they are set as separate tests anyway (polygon_06, polygon_07,
 polygon_08)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5142#comment:6>
