[postgis-tickets] [PostGIS] #5338: Dump/Restore of raster table fails on enforce_coverage_tile_rast constraint
PostGIS trac at osgeo.org
Tue Feb 14 22:12:46 PST 2023
  Reporter:  pramsey  |      Owner:  robe
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 3.0.9
 Component:  postgis  |    Version:  3.0.x
Resolution:           |   Keywords:
Comment (by robe):
 The issue here is with functions used in constraints that reference other
 functions.
 I'm frustrated I can't incorporate a test for this in our chain easily for
 a couple of reasons
 1) It would only pass if testing under --extension because it's only in
 extension scripts we can  schema qualify.  For non-extension install we
 just strip the @extschema at . variables
 2)
 @strk I thought I was hoping I could use
 --dumprestore --extension
 But seems dumprestore is just testing dumping an restoring an empty
 database so not that useful.
 I thought it would run the tests, dump and then restore?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5338#comment:2>
