[postgis-tickets] [PostGIS] #5119: Allow COPY to topology edge view
PostGIS trac at osgeo.org
Wed Feb 15 12:30:45 PST 2023
  Reporter:  strk         |      Owner:  strk
      Type:  enhancement  |     Status:  new
  Priority:  medium       |  Milestone:  PostGIS 3.4.0
 Component:  topology     |    Version:  master
Resolution:               |   Keywords:  usability
Comment (by pramsey):
 To complete the thought: had I been looking at the original edge table and
 been thinking "I need to add a directionality flag to the right/left face
 information" I'd have just added two booleans to the end of the edge table
 to flag the directionality. very small, additive-only change.
 I think the goal of "hewing to the standard" kind of falls apart when what
 you are adding (the capability to store rings that include a self-
 intersection in the form of a "spike") is a capability the original
 standard didn't anticipate. I imagine if you brought it to the SQL/MM
 folks they'd say "uh, no, you should only have OGC valid rings
 participating in faces". So you're in uncharted waters, change the edge
 table slightly to sail safely through.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5119#comment:5>
