[postgis-tickets] [PostGIS] #5338: Dump/Restore of raster table fails on enforce_coverage_tile_rast constraint
PostGIS trac at osgeo.org
Thu Feb 16 08:04:59 PST 2023
  Reporter:  pramsey  |      Owner:  robe
      Type:  defect   |     Status:  closed
  Priority:  medium   |  Milestone:  PostGIS 3.0.9
 Component:  postgis  |    Version:  3.0.x
Resolution:  fixed    |   Keywords:
Comment (by strk):
 Regina I think my pull request
 https://git.osgeo.org/gitea/postgis/postgis/pulls/112 would change the
 behavior to run before-upgrade scripts PRIOR to dump so that this bug can
 be tested, could you verify ?
 In order to test you would:
  1) Add the offending data in hook-before-upgrade-raster.sql
  2) Use run_test.pl as you tried to do (but the versino in my pull request
 above)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5338#comment:10>
