[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-622-gf7885e500
    git at osgeo.org
    git at osgeo.org
    Thu Feb 16 08:42:09 PST 2023
the project "PostGIS".
       via  f7885e500686145b098a633356a70b49bfb1c1eb (commit)
       via  ecea1b90e42943d78affaf8ddb96dbacc198f9a9 (commit)
      from  7223866c546ddce6b2d4b2d304cf70eb099b0da0 (commit)
revisions in full, below.
commit f7885e500686145b098a633356a70b49bfb1c1eb
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Feb 16 17:39:35 2023 +0100
    Add test for #5338
diff --git a/raster/test/regress/hooks/hook-after-upgrade-raster.sql b/raster/test/regress/hooks/hook-after-upgrade-raster.sql
index 49f51173b..b220246ea 100644
--- a/raster/test/regress/hooks/hook-after-upgrade-raster.sql
+++ b/raster/test/regress/hooks/hook-after-upgrade-raster.sql
@@ -1 +1,2 @@
 DROP TABLE upgrade_test_raster;
+DROP TABLE upgrade_test_raster_with_regular_blocking;
diff --git a/raster/test/regress/hooks/hook-before-upgrade-raster.sql b/raster/test/regress/hooks/hook-before-upgrade-raster.sql
index 8c000dbaf..94d972fc3 100644
--- a/raster/test/regress/hooks/hook-before-upgrade-raster.sql
+++ b/raster/test/regress/hooks/hook-before-upgrade-raster.sql
@@ -14,3 +14,20 @@ INSERT INTO upgrade_test_raster(r) VALUES
 --SET client_min_messages TO ERROR;
 SELECT AddRasterConstraints('upgrade_test_raster', 'r');
+CREATE TABLE upgrade_test_raster_with_regular_blocking(r raster);
+INSERT INTO upgrade_test_raster_with_regular_blocking(r) VALUES
+	ST_AddBand(
+		ST_MakeEmptyRaster(
+			10, 10, 1, 1, 2, 2, 0, 0,4326
+		1,
+		'8BSI'::text,
+		-129,
+		NULL
+--SET client_min_messages TO ERROR;
+SELECT AddRasterConstraints('upgrade_test_raster_with_regular_blocking', 'r', 'regular_blocking');
commit ecea1b90e42943d78affaf8ddb96dbacc198f9a9
Date:   Wed Nov 9 12:59:42 2022 +0100
    run_test.pl: run before-upgrade hooks before dump, use postgis_restore.pl when needed
    We can only use pg_restore when the dumped database is extension based.
    See #5075 and #5338
diff --git a/regress/run_test.pl b/regress/run_test.pl
index 5750dce07..3f2b1291c 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -142,7 +142,10 @@ sub findOrDie
 # Prepend scripts' build dirs to path
 # TODO: make this conditional ?
-$ENV{PATH} = $TOP_BUILDDIR . '/loader:' . $TOP_BUILDDIR .  '/raster/loader:' . $ENV{PATH};
+$ENV{PATH} = $TOP_BUILDDIR . '/loader:' .
+             $TOP_BUILDDIR . '/raster/loader:' .
+             $TOP_BUILDDIR . '/utils:' .
+             $ENV{PATH};
 our $SHP2PGSQL;
 sub shp2pgsql
@@ -165,6 +168,12 @@ sub raster2pgsql
     return $RASTER2PGSQL;
+our $POSTGIS_RESTORE;
+sub postgis_restore
+    $POSTGIS_RESTORE = findOrDie 'postgis_restore.pl', @_ unless defined($POSTGIS_RESTORE);
 if ( $OPT_UPGRADE_PATH )
   $OPT_UPGRADE = 1; # implied
@@ -366,34 +375,59 @@ if ( $OPT_UPGRADE )
     print "Upgrading from postgis $libver\n";
-	foreach my $hook (@OPT_HOOK_BEFORE_UPGRADE)
-		print "Running before-upgrade-script $hook\n";
-		die unless load_sql_file($hook, 1);
-    if ( $OPT_EXTENSIONS )
+    foreach my $hook (@OPT_HOOK_BEFORE_UPGRADE)
-        die unless upgrade_spatial_extensions();
+        print "Running before-upgrade-script $hook\n";
+        die unless load_sql_file($hook, 1);
-    else
-        die unless upgrade_spatial();
+if ( $OPT_DUMPRESTORE )
+    my $DBDUMP = dump_db();
+    die unless defined $DBDUMP;
+    print "Dropping db '${DB}'\n";
+    my $rv = system("dropdb ${DB} >> $REGRESS_LOG 2>&1");
+    if ( $rv ) {
+        fail("Could not drop ${DB}", $REGRESS_LOG);
+        die;
-	foreach my $hook (@OPT_HOOK_AFTER_UPGRADE)
-		print "Running after-upgrade-script $hook\n";
+    print "Creating spatial db '${DB}'\n";
+    undef($OPT_UPGRADE_FROM); # to directly prepare the target
+    $rv = create_spatial();
+    if ( ! $rv ) {
+        fail("Could not create spatial db ${DB}", $REGRESS_LOG);
+        die;
+    die unless restore_db($DBDUMP);
-    # Update libver
-    $libver = sql("select postgis_lib_version()");
+    unlink($DBDUMP);
-if ( $OPT_DUMPRESTORE )
+if ( $OPT_UPGRADE )
-    die unless dump_restore();
+    unless ( $OPT_DUMPRESTORE )
+        if ( $OPT_EXTENSIONS )
+            die unless upgrade_spatial_extensions();
+        else
+            die unless upgrade_spatial();
+    foreach my $hook (@OPT_HOOK_AFTER_UPGRADE)
+        print "Running after-upgrade-script $hook\n";
+    # Update libver
+    $libver = sql("select postgis_lib_version()");
@@ -632,7 +666,8 @@ Options:
                        an exclamation mark (ie: ":auto!" or "3.0.0!") to
                        request upgrade via postgis_extensions_upgrade()
                        if available.
-  --dumprestore   dump and restore spatially-enabled db before running tests
+  --dumprestore   dump and (after upgrade, if --upgrade is given)
+                  restore spatially-enabled db before running tests
   --nodrop        do not drop the regression database on exit
   --schema        where to install/find PostGIS (relocatable) PostGIS
                   (defaults to "public")
@@ -1414,7 +1449,7 @@ sub create_spatial
         if ( ! $OPT_UPGRADE_FROM )
             exit($FAIL) unless prepare_spatial();
-            return;
+            return 1;
         if ( $OPT_UPGRADE_FROM !~ /^unpackaged(.*)/ )
@@ -1428,6 +1463,8 @@ sub create_spatial
         exit($FAIL) unless prepare_spatial($1);
+    return 1;
@@ -1966,33 +2003,36 @@ sub uninstall_spatial
 	return 1;
-# Dump and restore the database
-sub dump_restore
+# Dump the database, return dump filename
+sub dump_db
-    my $DBDUMP = $TMPDIR . '/' . $DB . ".dump";
     my $rv;
+    my $DBDUMP = $TMPDIR . '/' . $DB . '.dump';
-	print "Dumping and restoring database '${DB}'\n";
+    print "Dumping database '${DB}'\n";
     $rv = system("pg_dump -Fc -f${DBDUMP} ${DB} >> $REGRESS_LOG 2>&1");
     if ( $rv ) {
         fail("Could not dump ${DB}", $REGRESS_LOG);
-        return 0;
-    $rv = system("dropdb ${DB} >> $REGRESS_LOG 2>&1");
-    if ( $rv ) {
-        fail("Could not drop db ${DB}", $REGRESS_LOG);
-        return 0;
+        return undef;
+    return ${DBDUMP};
-    $rv = create_db();
-    if ( $rv ) {
-        fail("Could not create ${DB}", $REGRESS_LOG);
-        return 0;
+# Restore the dump file passed as first argument
+sub restore_db
+    my $rv;
+    my $DBDUMP = shift;
+    if ( $OPT_EXTENSIONS ) {
+        print "Restoring database '${DB}' using pg_restore\n";
+        $rv = system("pg_restore -d ${DB} ${DBDUMP} >> $REGRESS_LOG 2>&1");
+    } else {
+        print "Restoring database '${DB}' using postgis_restore.pl\n";
+        my $cmd = postgis_restore() . " ${DBDUMP} | psql --set ON_ERROR_STOP=1 -X ${DB} >> $REGRESS_LOG 2>&1";
+        $rv = system($cmd);
-    $rv = system("pg_restore -d ${DB} ${DBDUMP} >> $REGRESS_LOG 2>&1");
     if ( $rv ) {
         fail("Could not restore ${DB}", $REGRESS_LOG);
         return 0;
@@ -2011,11 +2051,10 @@ sub dump_restore
-    unlink($DBDUMP);
     return 1;
+# Dump and restore the database
 sub diff
 	my ($expected_file, $obtained_file) = @_;
Summary of changes:
 .../regress/hooks/hook-after-upgrade-raster.sql    |   1 +
 .../regress/hooks/hook-before-upgrade-raster.sql   |  17 +++
 regress/run_test.pl                                | 123 ++++++++++++++-------
 3 files changed, 99 insertions(+), 42 deletions(-)
hooks/post-receive
