[postgis-tickets] [PostGIS] #5338: Dump/Restore of raster table fails on enforce_coverage_tile_rast constraint
PostGIS trac at osgeo.org
Thu Feb 16 08:42:13 PST 2023
  Reporter:  pramsey  |      Owner:  robe
      Type:  defect   |     Status:  closed
  Priority:  medium   |  Milestone:  PostGIS 3.0.9
 Component:  postgis  |    Version:  3.0.x
Resolution:  fixed    |   Keywords:
Comment (by Sandro Santilli <strk@…>):
 In [changeset:"ecea1b90e42943d78affaf8ddb96dbacc198f9a9/git" ecea1b9/git]:
 {{{#!CommitTicketReference repository="git"
 revision="ecea1b90e42943d78affaf8ddb96dbacc198f9a9"
 run_test.pl: run before-upgrade hooks before dump, use postgis_restore.pl
 when needed
 We can only use pg_restore when the dumped database is extension based.
 See #5075 and #5338
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5338#comment:13>
