[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-625-g633cf975c
Thu Feb 16 10:21:14 PST 2023
the project "PostGIS".
       via  633cf975c931a2b74455dc3673840c7b30af0e14 (commit)
      from  cc2455bde3257754b5d052357c241d4eab400286 (commit)
revisions in full, below.
commit 633cf975c931a2b74455dc3673840c7b30af0e14
Author: Regina Obe <lr at pcorp.us>
Date:   Thu Feb 16 02:41:52 2023 -0500
    Prevent crash on infinite coordinates
    for PostGIS 3.4
    References #5319 ST_SetPoint
    References #5315 ST_Buffer
    References #5318 ST_MaximumnInscribedCircle
diff --git a/postgis/lwgeom_functions_basic.c b/postgis/lwgeom_functions_basic.c
index 1bf6f0bc4..72e61bf77 100644
--- a/postgis/lwgeom_functions_basic.c
+++ b/postgis/lwgeom_functions_basic.c
@@ -2444,6 +2444,7 @@ Datum LWGEOM_setpoint_linestring(PG_FUNCTION_ARGS)
 	lwg = lwgeom_from_gserialized(pglwg1);
 	line = lwgeom_as_lwline(lwg);
 	if (!line)
 		elog(ERROR, "First argument must be a LINESTRING");
@@ -2455,6 +2456,12 @@ Datum LWGEOM_setpoint_linestring(PG_FUNCTION_ARGS)
 		PG_RETURN_NULL();
+	if (!lwgeom_isfinite(lwg))
+		elog(ERROR, "Geometry contains invalid coordinate");
+		PG_RETURN_NULL();
 	if (which < 0)
 		/* Use backward indexing for negative values */
diff --git a/postgis/lwgeom_geos.c b/postgis/lwgeom_geos.c
index 3349c2612..10b088d03 100644
--- a/postgis/lwgeom_geos.c
+++ b/postgis/lwgeom_geos.c
@@ -397,6 +397,13 @@ Datum ST_MaximumInscribedCircle(PG_FUNCTION_ARGS)
 		double width, height, size, tolerance;
 		GBOX gbox;
 		int gtype;
+		LWGEOM *lwg;
+		lwg = lwgeom_from_gserialized(geom);
+			lwpgerror("Geometry contains invalid coordinates");
+			PG_RETURN_NULL();
 		if (!gserialized_get_gbox_p(geom, &gbox))
 			PG_RETURN_NULL();
@@ -978,6 +985,14 @@ Datum buffer(PG_FUNCTION_ARGS)
 		PG_RETURN_POINTER(geometry_serialize(lwg));
+	lwg = lwgeom_from_gserialized(geom1);
+		PG_RETURN_NULL();
 	initGEOS(lwpgnotice, lwgeom_geos_error);
 	g1 = POSTGIS2GEOS(geom1);
diff --git a/regress/core/geos39.sql b/regress/core/geos39.sql
index 8885fdd85..4a444a418 100644
--- a/regress/core/geos39.sql
+++ b/regress/core/geos39.sql
@@ -42,3 +42,6 @@ SELECT 'mic-cte' AS name, ST_AsText(st_snaptogrid((ST_MaximumInscribedCircle(ply
 SELECT 'rp-1', ST_AsText(ST_ReducePrecision('POINT(1.412 19.323)', 0.1));
 SELECT 'rp-2', ST_AsText(ST_ReducePrecision('POINT(1.412 19.323)', 1.0));
 SELECT 'rp-3', ST_AsText(ST_ReducePrecision('POINT(1.412 19.323)', 10));
+-- ST_MaximumInscribedCircle infinite check https://trac.osgeo.org/postgis/ticket/5318
+SELECT '#5318', ST_MaximumInscribedCircle('0106000020E61000000100000001030000000100000005000000000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F'::geometry) As result;
diff --git a/regress/core/geos39_expected b/regress/core/geos39_expected
index 06ebbd417..ec9be2b85 100644
--- a/regress/core/geos39_expected
+++ b/regress/core/geos39_expected
@@ -8,3 +8,4 @@ mic-cte|POINT(49.512 49.512)
 rp-1|POINT(1.4 19.3)
 rp-2|POINT(1 19)
 rp-3|POINT(0 20)
+ERROR:  Geometry contains invalid coordinates
diff --git a/regress/core/setpoint.sql b/regress/core/setpoint.sql
index 51519ac54..553e50309 100644
--- a/regress/core/setpoint.sql
+++ b/regress/core/setpoint.sql
@@ -26,3 +26,6 @@ SELECT ST_asewkt(ST_SetPoint('LINESTRING(0 0 0 0, 1 1 1 1, 2 2 2 2, 4 4 4 4)', 2
 SELECT ST_asewkt(ST_SetPoint('LINESTRING(0 0 0 0, 1 1 1 1, 2 2 2 2, 4 4 4 4)', 1, 'POINTM(90 91 92)'));
 SELECT ST_asewkt(ST_SetPoint('LINESTRING(0 0 0 0, 1 1 1 1, 2 2 2 2, 4 4 4 4)', 0, 'POINT(90 91 92 93)'));
+-- https://trac.osgeo.org/postgis/ticket/5319
+SELECT '#5319', ST_SetPoint('0102000020E610000005000000000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F'::geometry, 1,ST_GeomFromText('POINT(0 0)',4326)  )  As result;
diff --git a/regress/core/setpoint_expected b/regress/core/setpoint_expected
index 210195c40..cbc622b07 100644
--- a/regress/core/setpoint_expected
+++ b/regress/core/setpoint_expected
@@ -11,3 +11,4 @@ LINESTRING(0 0 0 0,1 1 1 1,2 2 2 2,90 91 0 0)
 LINESTRING(0 0 0 0,1 1 1 1,90 91 92 0,4 4 4 4)
 LINESTRING(0 0 0 0,90 91 0 92,2 2 2 2,4 4 4 4)
 LINESTRING(90 91 92 93,1 1 1 1,2 2 2 2,4 4 4 4)
diff --git a/regress/core/tickets.sql b/regress/core/tickets.sql
index 7ce4de725..70c0f2132 100644
--- a/regress/core/tickets.sql
+++ b/regress/core/tickets.sql
@@ -1479,3 +1479,5 @@ reset max_parallel_workers_per_gather;
 reset force_parallel_mode;
 SET client_min_messages TO NOTICE;
+-- https://trac.osgeo.org/postgis/ticket/5315
+SELECT '#5315', ST_Buffer('0106000020E86400000100000001030000000100000005000000000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F'::geometry, 1);
diff --git a/regress/core/tickets_expected b/regress/core/tickets_expected
index 706ef3c5b..258c4f10e 100644
--- a/regress/core/tickets_expected
+++ b/regress/core/tickets_expected
@@ -462,3 +462,4 @@ ERROR:  LWGEOM_addpoint: Invalid offset
 ERROR:  Line has no points
 #5139|100000
 #5139|1000000
Summary of changes:
 postgis/lwgeom_functions_basic.c |  7 +++++++
 postgis/lwgeom_geos.c            | 15 +++++++++++++++
 regress/core/geos39.sql          |  3 +++
 regress/core/geos39_expected     |  1 +
 regress/core/setpoint.sql        |  3 +++
 regress/core/setpoint_expected   |  1 +
 regress/core/tickets.sql         |  2 ++
 regress/core/tickets_expected    |  1 +
 8 files changed, 33 insertions(+)
hooks/post-receive
