[postgis-tickets] [PostGIS] #5339: postgis_restore.pl skips TABLEDATA for layer and topology (should not)
PostGIS trac at osgeo.org
Thu Feb 16 11:30:38 PST 2023
 Reporter:  strk                   |      Owner:  strk
     Type:  defect                 |     Status:  new
 Priority:  medium                 |  Milestone:  PostGIS 3.3.3
Component:  build/upgrade/install  |    Version:  3.3.x
 Keywords:                         |
 This is the reason why the after-upgrade hook for topology fails when you
 run:
 regress/run_test.pl --nodrop -v --dumprestore --topology --upgrade
 --before-upgrade-script topology/test/regress/hooks/hook-before-upgrade-
 topology.sql --after-upgrade-script topology/test/regress/hooks/hook-
 after-upgrade-topology.sql regress/core/tickets
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5339>
