[postgis-tickets] [SCM] PostGIS branch stable-3.0 updated. 3.0.8-4-g92e739924
Thu Feb 16 22:43:03 PST 2023
the project "PostGIS".
The branch, stable-3.0 has been updated
       via  92e7399245050479ce0c464279d6f6aac80d551e (commit)
      from  400317a3cb36c77c94bc61e0709b5744fef0bbfe (commit)
revisions in full, below.
commit 92e7399245050479ce0c464279d6f6aac80d551e
Author: Regina Obe <lr at pcorp.us>
Date:   Fri Feb 17 01:35:08 2023 -0500
    Prefilter to check for non-finite coordinates before feeding
    ST_SimplifyPreserveTopology, ST_Buffer, ST_SetPoint
    to avoid crash/hang.
    References #5320
    References #5315
    References #5319
    for PostGIS 3.0.9
diff --git a/NEWS b/NEWS
index d5ead5c73..e22648026 100644
--- a/NEWS
+++ b/NEWS
@@ -4,6 +4,8 @@ xxxx/xx/xx
 * Bug Fixes *
   - #5338, Dump/Restore of raster table fails on
   		     enforce_coverage_tile_rast constraint (Regina Obe)
+  - #5315, #5319, #5320 crashes on infinite coordinates
+          (Regina Obe, Paul Ramsey)
 PostGIS 3.0.8
 2022/11/11
diff --git a/liblwgeom/liblwgeom.h.in b/liblwgeom/liblwgeom.h.in
index 3e01ee197..c8fb31e7d 100644
--- a/liblwgeom/liblwgeom.h.in
+++ b/liblwgeom/liblwgeom.h.in
@@ -884,6 +884,12 @@ extern const GBOX *lwgeom_get_bbox(const LWGEOM *lwgeom);
 extern int lwgeom_is_collection(const LWGEOM *lwgeom);
+* Check if a LWGEOM has any non-finite (NaN or Inf) coordinates.
+extern int lwgeom_isfinite(const LWGEOM *lwgeom);
 /* Functions that work on type numbers */
diff --git a/liblwgeom/lwgeom.c b/liblwgeom/lwgeom.c
index a07ca53a1..6e13e35a0 100644
--- a/liblwgeom/lwgeom.c
+++ b/liblwgeom/lwgeom.c
@@ -2524,3 +2524,29 @@ void lwgeom_trim_bits_in_place(LWGEOM* geom, int32_t prec_x, int32_t prec_y, int
 	lwpointiterator_destroy(it);
+int
+lwgeom_isfinite(const LWGEOM *lwgeom)
+	LWPOINTITERATOR* it = lwpointiterator_create(lwgeom);
+	int hasz = lwgeom_has_z(lwgeom);
+	int hasm = lwgeom_has_m(lwgeom);
+	while (lwpointiterator_has_next(it))
+		POINT4D p;
+		lwpointiterator_next(it, &p);
+		int finite = isfinite(p.x) &&
+			isfinite(p.y) &&
+			(hasz ? isfinite(p.z) : 1) &&
+			(hasm ? isfinite(p.m) : 1);
+		if (!finite)
+			lwpointiterator_destroy(it);
+			return LW_FALSE;
+	return LW_TRUE;
diff --git a/postgis/lwgeom_functions_basic.c b/postgis/lwgeom_functions_basic.c
index 83ec8aa0b..5de03d1c1 100644
--- a/postgis/lwgeom_functions_basic.c
+++ b/postgis/lwgeom_functions_basic.c
@@ -2320,15 +2320,24 @@ Datum LWGEOM_setpoint_linestring(PG_FUNCTION_ARGS)
 	lwg = lwgeom_from_gserialized(pglwg1);
 	line = lwgeom_as_lwline(lwg);
 	if (!line)
 		elog(ERROR, "First argument must be a LINESTRING");
 		PG_RETURN_NULL();
 	if ( line->points->npoints < 1 ) 	{
 		elog(ERROR, "Line has no points");
 		PG_RETURN_NULL();
+	if (!lwgeom_isfinite(lwg))
+		elog(ERROR, "Geometry contains invalid coordinate");
+		PG_RETURN_NULL();
 	if (which < 0)
 		/* Use backward indexing for negative values */
diff --git a/postgis/lwgeom_geos.c b/postgis/lwgeom_geos.c
index 6eebc72b3..f06826189 100644
--- a/postgis/lwgeom_geos.c
+++ b/postgis/lwgeom_geos.c
@@ -831,23 +831,32 @@ Datum convexhull(PG_FUNCTION_ARGS)
 PG_FUNCTION_INFO_V1(topologypreservesimplify);
 Datum topologypreservesimplify(PG_FUNCTION_ARGS)
-	GSERIALIZED	*geom1;
+	GSERIALIZED	*gs1;
+	LWGEOM *lwg1;
 	double	tolerance;
 	GEOSGeometry *g1, *g3;
 	GSERIALIZED *result;
 	uint32_t type;
-	geom1 = PG_GETARG_GSERIALIZED_P(0);
+	gs1 = PG_GETARG_GSERIALIZED_P(0);
 	tolerance = PG_GETARG_FLOAT8(1);
+	lwg1 = lwgeom_from_gserialized(gs1);
 	/* Empty.Simplify() == Empty */
-	type = gserialized_get_type(geom1);
-	if ( gserialized_is_empty(geom1) || type == TINTYPE || type == TRIANGLETYPE )
-		PG_RETURN_POINTER(geom1);
+	type = lwgeom_get_type(lwg1);
+	if (lwgeom_is_empty(lwg1) || type == TINTYPE || type == TRIANGLETYPE)
+		PG_RETURN_POINTER(gs1);
+	if (!lwgeom_isfinite(lwg1))
+		lwpgerror("Geometry contains invalid coordinates");
+		PG_RETURN_NULL();
 	initGEOS(lwpgnotice, lwgeom_geos_error);
-	g1 = POSTGIS2GEOS(geom1);
+	g1 = LWGEOM2GEOS(lwg1, LW_TRUE);
+	lwgeom_free(lwg1);
 	if (!g1)
 		HANDLE_GEOS_ERROR("First argument geometry could not be converted to GEOS");
@@ -858,9 +867,9 @@ Datum topologypreservesimplify(PG_FUNCTION_ARGS)
 	POSTGIS_DEBUGF(3, "result: %s", GEOSGeomToWKT(g3));
-	GEOSSetSRID(g3, gserialized_get_srid(geom1));
+	GEOSSetSRID(g3, gserialized_get_srid(gs1));
-	result = GEOS2POSTGIS(g3, gserialized_has_z(geom1));
+	result = GEOS2POSTGIS(g3, gserialized_has_z(gs1));
 	GEOSGeom_destroy(g3);
 	if (!result)
@@ -869,7 +878,7 @@ Datum topologypreservesimplify(PG_FUNCTION_ARGS)
 		PG_RETURN_NULL(); /* never get here */
-	PG_FREE_IF_COPY(geom1, 0);
+	PG_FREE_IF_COPY(gs1, 0);
 	PG_RETURN_POINTER(result);
@@ -915,7 +924,7 @@ Datum buffer(PG_FUNCTION_ARGS)
 		SET_VARSIZE(params_text, 0);
-	/* Empty.Buffer() == Empty[polygon] */
+		/* Empty.Buffer() == Empty[polygon] */
 	if ( gserialized_is_empty(geom1) )
 		lwg = lwpoly_as_lwgeom(lwpoly_construct_empty(
@@ -924,6 +933,15 @@ Datum buffer(PG_FUNCTION_ARGS)
 		PG_RETURN_POINTER(geometry_serialize(lwg));
+	lwg = lwgeom_from_gserialized(geom1);
+		PG_RETURN_NULL();
+	lwgeom_free(lwg);
diff --git a/regress/core/setpoint.sql b/regress/core/setpoint.sql
index 51519ac54..553e50309 100644
--- a/regress/core/setpoint.sql
+++ b/regress/core/setpoint.sql
@@ -26,3 +26,6 @@ SELECT ST_asewkt(ST_SetPoint('LINESTRING(0 0 0 0, 1 1 1 1, 2 2 2 2, 4 4 4 4)', 2
 SELECT ST_asewkt(ST_SetPoint('LINESTRING(0 0 0 0, 1 1 1 1, 2 2 2 2, 4 4 4 4)', 1, 'POINTM(90 91 92)'));
 SELECT ST_asewkt(ST_SetPoint('LINESTRING(0 0 0 0, 1 1 1 1, 2 2 2 2, 4 4 4 4)', 0, 'POINT(90 91 92 93)'));
+-- https://trac.osgeo.org/postgis/ticket/5319
+SELECT '#5319', ST_SetPoint('0102000020E610000005000000000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F'::geometry, 1,ST_GeomFromText('POINT(0 0)',4326)  )  As result;
diff --git a/regress/core/setpoint_expected b/regress/core/setpoint_expected
index 210195c40..cbc622b07 100644
--- a/regress/core/setpoint_expected
+++ b/regress/core/setpoint_expected
@@ -11,3 +11,4 @@ LINESTRING(0 0 0 0,1 1 1 1,2 2 2 2,90 91 0 0)
 LINESTRING(0 0 0 0,1 1 1 1,90 91 92 0,4 4 4 4)
 LINESTRING(0 0 0 0,90 91 0 92,2 2 2 2,4 4 4 4)
 LINESTRING(90 91 92 93,1 1 1 1,2 2 2 2,4 4 4 4)
+ERROR:  Geometry contains invalid coordinate
diff --git a/regress/core/tickets.sql b/regress/core/tickets.sql
index 69c36f5e2..08e2ffe55 100644
--- a/regress/core/tickets.sql
+++ b/regress/core/tickets.sql
@@ -1388,3 +1388,8 @@ SELECT '#4770.c', ST_AsText(g), s FROM w;
 -- https://trac.osgeo.org/postgis/ticket/5151
 SELECT '#5151', ST_SetPoint(ST_GeomFromText('LINESTRING EMPTY',4326), 1, ST_GeomFromText('POINT(40 50)',4326)) As result;
+-- https://trac.osgeo.org/postgis/ticket/5315
+SELECT '#5315', ST_Buffer('0106000020E86400000100000001030000000100000005000000000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F'::geometry, 1);
+SELECT '#5320', ST_SimplifyPreserveTopology('0106000020E86400000100000001030000000100000005000000000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F'::geometry, 1);
diff --git a/regress/core/tickets_expected b/regress/core/tickets_expected
index a11023589..2f3094a8a 100644
--- a/regress/core/tickets_expected
+++ b/regress/core/tickets_expected
@@ -455,3 +455,5 @@ ERROR:  LWGEOM_addpoint: Invalid offset
 #4770.c|POINT(0 0)|300
 #4770.c|MULTIPOINT(0 0,1 1)|602
 ERROR:  Line has no points
+ERROR:  Geometry contains invalid coordinates
Summary of changes:
 NEWS                             |  2 ++
 liblwgeom/liblwgeom.h.in         |  6 ++++++
 liblwgeom/lwgeom.c               | 26 ++++++++++++++++++++++++++
 postgis/lwgeom_functions_basic.c |  9 +++++++++
 postgis/lwgeom_geos.c            | 38 ++++++++++++++++++++++++++++----------
 regress/core/setpoint.sql        |  3 +++
 regress/core/setpoint_expected   |  1 +
 regress/core/tickets.sql         |  5 +++++
 regress/core/tickets_expected    |  2 ++
 9 files changed, 82 insertions(+), 10 deletions(-)
hooks/post-receive
