[postgis-tickets] [PostGIS] #5340: totopogeom doc miss default value for tolerance
PostGIS trac at osgeo.org
Fri Feb 17 05:29:04 PST 2023
 Reporter:  PanierAvide  |      Owner:  strk
     Type:  enhancement  |     Status:  new
 Priority:  medium       |  Milestone:  PostGIS 3.3.3
Component:  topology     |    Version:  3.3.x
 Keywords:               |
 Hello,
 I discovered that documentation of totopogeom topology function lacks in
 documentation the default value for tolerance on this page :
 https://postgis.net/docs/toTopoGeom.html
 So this line :
 topogeometry toTopoGeom(geometry geom, varchar toponame, integer layer_id,
 float8 tolerance)
 May be instead :
 float8 tolerance=0)
 Best regards
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5340>
