[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-636-gf93359b21
Fri Feb 17 16:55:18 PST 2023
the project "PostGIS".
       via  f93359b21380998e86a38805f069bd22383ccf6e (commit)
       via  6bedfb72ca0ab3e5919d17f3f52f259573c0a56a (commit)
      from  5930a3ff2f321548223e9a9147a3eea6870b52cd (commit)
revisions in full, below.
commit f93359b21380998e86a38805f069bd22383ccf6e
Author: Regina Obe <lr at pcorp.us>
Date:   Mon Jan 23 12:01:01 2023 -0500
    Garden test changes
    1. Add in infinity check tests
    2. Update the log table version name
diff --git a/doc/xsl/postgis_gardentest.sql.xsl b/doc/xsl/postgis_gardentest.sql.xsl
index 7fbd4512c..36bae0635 100644
--- a/doc/xsl/postgis_gardentest.sql.xsl
+++ b/doc/xsl/postgis_gardentest.sql.xsl
@@ -33,7 +33,7 @@
 	<xsl:variable name='var_matrix'>'FF1FF0102'</xsl:variable>
 	<xsl:variable name='var_boolean'>false</xsl:variable>
 	<xsl:variable name='var_geom_name'>the_geom</xsl:variable>
-	<xsl:variable name='var_logtable'>postgis_garden_log33</xsl:variable>
+	<xsl:variable name='var_logtable'>postgis_garden_log34</xsl:variable>
 	<xsl:variable name='var_logupdatesql'>UPDATE <xsl:value-of select="$var_logtable" /> SET log_end = clock_timestamp()
 		FROM (SELECT logid FROM <xsl:value-of select="$var_logtable" /> ORDER BY logid DESC limit 1) As foo
 		WHERE <xsl:value-of select="$var_logtable" />.logid = foo.logid  AND <xsl:value-of select="$var_logtable" />.log_end IS NULL;</xsl:variable>
@@ -269,6 +269,25 @@ FROM (VALUES ( ST_GeomFromEWKT('SRID=4326;MULTIPOLYGON(((-71.0821 42.3036 2,-71.
 			UNION ALL SELECT ST_MakePolygon(ST_GeomFromText('LINESTRING(1 2, 1 2,1 2, 1 2, 3 2, 1 2)',4326)) As the_geom
 		</pgis:gset>
+		<pgis:gset ID="Infinite Polygons" GeometryType="POLYGON" createtable="true">(SELECT '0106000020E61000000100000001030000000100000005000000000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F'::geometry  AS the_geom
+		</pgis:gset>
+		<pgis:gset ID="Infinite 3D Polygons" GeometryType="POLYGON" createtable="true">(SELECT '01060000A0E61000000100000001030000800100000005000000000000000000F07F000000000000F07F000000000000F03F000000000000F07F000000000000F07F000000000000F03F000000000000F07F000000000000F07F000000000000F03F000000000000F07F000000000000F07F000000000000F03F000000000000F07F000000000000F07F000000000000F03F'::geometry  AS the_geom
+		</pgis:gset>
+		<pgis:gset ID="Infinite Linestrings" GeometryType="LINESTRING" createtable="true">(SELECT '0102000020E610000005000000000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F'::geometry  AS the_geom
+		</pgis:gset>
+		<pgis:gset ID="Infinite Point" GeometryType="POINT" createtable="true">(SELECT '0101000020E6100000000000000000F07F000000000000F07F'::geometry AS the_geom )
+		</pgis:gset>
+		<pgis:gset ID="Infinite MultiPoint" GeometryType="MULTIPOINT" createtable="true">(SELECT
+		'0104000020E6100000050000000101000000000000000000F07F000000000000F07F0101000000000000000000F07F000000000000F07F0101000000000000000000F07F000000000000F07F0101000000000000000000F07F000000000000F07F0101000000000000000000F07F000000000000F07F'::geometry AS the_geom )
+		</pgis:gset>
 	<!-- TODO: Finish off MULTI list -->
 	</pgis:gardens>
 	<!--This is just a placeholder to hold geometries that will crash server when hitting against some functions
diff --git a/doc/xsl/postgis_gardentest_subset.sql.xsl b/doc/xsl/postgis_gardentest_subset.sql.xsl
deleted file mode 100644
index 21e5c34e4..000000000
--- a/doc/xsl/postgis_gardentest_subset.sql.xsl
+++ /dev/null
@@ -1,375 +0,0 @@
-<?xml version="1.0" encoding="utf-8"?>
-<xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform"  xmlns:pgis="http://www.postgis.org/pgis">
-	 Copyright 2009, Regina Obe
-	 License: BSD
-	 Purpose: This is an xsl transform that generates an sql test script from xml docs to test all the functions we have documented
-			using a garden variety of geometries.  Its intent is to flag major crashes.  This version is similar to the full but designed to
-			test more geometries but only against one function.  Useful for intro of new functions or comparing major changes from function of one version of PostGIS to the other
-	<xsl:output method="text" />
-	<xsl:variable name='testversion'>3.3.0</xsl:variable>
-	<xsl:variable name="fninclude"><xsl:value-of select="$inputfninclude"/></xsl:variable>
-	<xsl:variable name='var_srid'>3395</xsl:variable>
-	<xsl:variable name='var_position'>1</xsl:variable>
-	<xsl:variable name='var_integer1'>3</xsl:variable>
-	<xsl:variable name='var_integer2'>5</xsl:variable>
-	<xsl:variable name='var_float1'>0.5</xsl:variable>
-	<xsl:variable name='var_float2'>0.75</xsl:variable>
-	<xsl:variable name='var_distance'>100</xsl:variable>
-	<xsl:variable name='var_version1'>1</xsl:variable>
-	<xsl:variable name='var_version2'>2</xsl:variable>
-	<xsl:variable name='var_NDRXDR'>XDR</xsl:variable>
-	<xsl:variable name='var_text'>'monkey'</xsl:variable>
-	<xsl:variable name='var_varchar'>'test'</xsl:variable>
-	<xsl:variable name='var_spheroid'>'SPHEROID["GRS_1980",6378137,298.257222101]'</xsl:variable>
-	<xsl:variable name='var_matrix'>'FF1FF0102'</xsl:variable>
-	<xsl:variable name='var_boolean'>false</xsl:variable>
-	<pgis:gardens>
-	<pgis:gset ID='PointSet' GeometryType='POINT'>(SELECT ST_SetSRID(ST_Point(i,j),4326) As the_geom
-		FROM (SELECT a*1.01234567890 FROM generate_series(-10,50,10) As a) As i(i)
-			CROSS JOIN generate_series(40,70, 15) j
-			ORDER BY i,j
-			)</pgis:gset>
-		<pgis:gset ID='LineSet' GeometryType='LINESTRING'>(SELECT ST_MakeLine(ST_SetSRID(ST_Point(i,j),4326),ST_SetSRID(ST_Point(j,i),4326))  As the_geom
-			CROSS JOIN generate_series(40,70, 15) As j
-			WHERE NOT(i = j)
-			ORDER BY i, i*j)</pgis:gset>
-		<pgis:gset ID='PolySet' GeometryType='POLYGON'>(SELECT ST_Buffer(ST_SetSRID(ST_Point(i,j),4326), j*0.05)  As the_geom
-			CROSS JOIN generate_series(40,70, 20) As j
-			ORDER BY i, i*j, j)</pgis:gset>
-		<pgis:gset ID='PointMSet' GeometryType='POINTM'>(SELECT ST_SetSRID(ST_MakePointM(i,j,m),4326) As the_geom
-			CROSS JOIN generate_series(50,70, 20) AS j
-			CROSS JOIN generate_series(1,2) As m
-			ORDER BY i, j, i*j*m)</pgis:gset>
-		<pgis:gset ID='LineMSet' GeometryType='LINESTRINGM'>(SELECT ST_MakeLine(ST_SetSRID(ST_MakePointM(i,j,m),4326),ST_SetSRID(ST_MakePointM(j,i,m),4326))  As the_geom
-			CROSS JOIN generate_series(50,70, 20) As j
-			WHERE NOT(i = j)
-			ORDER BY i, j, m, i*j*m)</pgis:gset>
-		<pgis:gset ID='PolygonMSet' GeometryType='POLYGONM'>(SELECT ST_MakePolygon(ST_AddPoint(ST_AddPoint(ST_MakeLine(ST_SetSRID(ST_MakePointM(i+m,j,m),4326),ST_SetSRID(ST_MakePointM(j+m,i-m,m),4326)),ST_SetSRID(ST_MakePointM(i,j,m),4326)),ST_SetSRID(ST_MakePointM(i+m,j,m),4326)))  As the_geom
-			)</pgis:gset>
-		<pgis:gset ID='PointSet3D' GeometryType='POINTZ'>(SELECT ST_SetSRID(ST_MakePoint(i,j,k),4326) As the_geom
-			CROSS JOIN generate_series(40,70, 20) j
-			CROSS JOIN generate_series(1,2) k
-			ORDER BY i,i*j, j*k, i + j + k)</pgis:gset>
-		<pgis:gset ID='LineSet3D' GeometryType='LINESTRINGZ'>(SELECT ST_SetSRID(ST_MakeLine(ST_MakePoint(i,j,k), ST_MakePoint(i+k,j+k,k)),4326) As the_geom
-			ORDER BY i, j, i+j+k, k, i*j*k)</pgis:gset>
-		<pgis:gset ID='PolygonSet3D' GeometryType='POLYGONZ'>(SELECT ST_SetSRID(ST_MakePolygon(ST_AddPoint(ST_AddPoint(ST_MakeLine(ST_MakePoint(i+m,j,m),ST_MakePoint(j+m,i-m,m)),ST_MakePoint(i,j,m)),ST_MakePointM(i+m,j,m))),4326)  As the_geom
-			ORDER BY i, j, i+j+m, m, i*j*m)</pgis:gset>
-		<pgis:gset ID='PolyhedralSurface' GeometryType='PolyhedralSurface'>(SELECT ST_GeomFromEWKT(
-'SRID=0;PolyhedralSurface(
-((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
-((0 0 0, 0 1 0, 1 1 0, 1 0 0, 0 0 0)), ((0 0 0, 1 0 0, 1 0 1, 0 0 1, 0 0 0)),  ((1 1 0, 1 1 1, 1 0 1, 1 0 0, 1 1 0)),
-((0 1 0, 0 1 1, 1 1 1, 1 1 0, 0 1 0)),  ((0 0 1, 1 0 1, 1 1 1, 0 1 1, 0 0 1))
-)') )</pgis:gset>
-		<pgis:gset ID='GCSet3D' GeometryType='GEOMETRYCOLLECTIONZ' SkipUnary='1'>(SELECT ST_Collect(ST_Collect(ST_SetSRID(ST_MakePoint(i,j,m),4326),ST_SetSRID(ST_MakePolygon(ST_AddPoint(ST_AddPoint(ST_MakeLine(ST_MakePoint(i+m,j,m),ST_MakePoint(j+m,i-m,m)),ST_MakePoint(i,j,m)),ST_MakePointM(i+m,j,m))),4326)))  As the_geom
-			)</pgis:gset>
-<!-- MULTIs start here -->
-		<pgis:gset ID='MultiPointSet' GeometryType='MULTIPOINT'>(SELECT ST_Collect(s.the_geom) As the_geom
-		FROM (SELECT ST_SetSRID(ST_Point(i,j),4326) As the_geom
-			) As s)</pgis:gset>
-		<pgis:gset ID='MultiLineSet' GeometryType='MULTILINESTRING'>(SELECT ST_Collect(s.the_geom) As the_geom
-		FROM (SELECT ST_MakeLine(ST_SetSRID(ST_Point(i,j),4326),ST_SetSRID(ST_Point(j,i),4326))  As the_geom
-			WHERE NOT(i = j)) As s)</pgis:gset>
-		<pgis:gset ID='MultiPolySet' GeometryType='MULTIPOLYGON'>(SELECT ST_Multi(ST_Union(ST_Buffer(ST_SetSRID(ST_Point(i,j),4326), j*0.05)))  As the_geom
-			CROSS JOIN generate_series(40,70, 25) As j)</pgis:gset>
-		<pgis:gset ID='MultiPointSet3D' GeometryType='MULTIPOINTZ'>(SELECT ST_Collect(ST_SetSRID(ST_MakePoint(i,j,k),4326)) As the_geom
-			CROSS JOIN generate_series(40,70, 25) j
-			CROSS JOIN generate_series(1,3) k
-			)</pgis:gset>
-		<pgis:gset ID='MultiLineSet3D' GeometryType='MULTILINESTRINGZ'>(SELECT ST_Multi(ST_Union(ST_SetSRID(ST_MakeLine(ST_MakePoint(i,j,k), ST_MakePoint(i+k,j+k,k)),4326))) As the_geom
-			)</pgis:gset>
-		<pgis:gset ID='MultiPolySet3D' GeometryType='MULTIPOLYGONZ'>(SELECT ST_Multi(ST_Union(s.the_geom)) As the_geom
-		FROM (SELECT ST_MakePolygon(ST_AddPoint(ST_AddPoint(ST_MakeLine(ST_SetSRID(ST_MakePoint(i+m,j,m),4326),ST_SetSRID(ST_MakePoint(j+m,i-m,m),4326)),ST_SetSRID(ST_MakePoint(i,j,m),4326)),ST_SetSRID(ST_MakePoint(i+m,j,m),4326)))  As the_geom
-			CROSS JOIN generate_series(50,70, 25) As j
-		<pgis:gset ID='MultiPointMSet' GeometryType='MULTIPOINTM'>(SELECT ST_Collect(s.the_geom) As the_geom
-		FROM (SELECT ST_SetSRID(ST_MakePointM(i,j,m),4326) As the_geom
-			CROSS JOIN generate_series(50,70, 25) AS j
-		<pgis:gset ID='MultiLineMSet' GeometryType='MULTILINESTRINGM'>(SELECT ST_Collect(s.the_geom) As the_geom
-		FROM (SELECT ST_MakeLine(ST_SetSRID(ST_MakePointM(i,j,m),4326),ST_SetSRID(ST_MakePointM(j,i,m),4326))  As the_geom
-		<pgis:gset ID='MultiPolygonMSet' GeometryType='MULTIPOLYGONM'>(
-			SELECT ST_GeomFromEWKT('SRID=4326;MULTIPOLYGONM(((0 0 2,10 0 1,10 10 -2,0 10 -5,0 0 -5),(5 5 6,7 5 6,7 7 6,5 7 10,5 5 -2)))')  As the_geom
-			)</pgis:gset>
-		<!--These are special case geometries -->
-		<pgis:gset ID="Empty" GeometryType="GEOMETRY" createtable="false">(SELECT ST_GeomFromText('GEOMETRYCOLLECTION EMPTY',4326) As the_geom
-			UNION ALL SELECT ST_GeomFromText('POLYGON EMPTY',4326) As the_geom
-		</pgis:gset>
-		<pgis:gset ID="SingleNULL" GeometryType="GEOMETRY" createtable="false">(SELECT CAST(Null As geometry) As the_geom)</pgis:gset>
-		<pgis:gset ID="MultipleNULLs" GeometryType="GEOMETRY" createtable="false">(SELECT CAST(Null As geometry) As the_geom FROM generate_series(1,4) As foo)</pgis:gset>
-	<!-- TODO: Finish off MULTI list -->
-	</pgis:gardens>
-	<!--This is just a placeholder to hold geometries that will crash server when hitting against some functions
-		We'll fix these crashers in 1.4 -->
-	<pgis:gardencrashers>
-		<pgis:gset ID='CurvePolySet' GeometryType='CURVEPOLYGON'>(SELECT ST_LineToCurve(ST_Buffer(ST_SetSRID(ST_Point(i,j),4326), j))  As the_geom
-				FROM generate_series(-10,50,10) As i
-					ORDER BY i, j, i*j)</pgis:gset>
-		<pgis:gset ID='CircularStringSet' GeometryType='CIRCULARSTRING'>(SELECT ST_LineToCurve(ST_Boundary(ST_Buffer(ST_SetSRID(ST_Point(i,j),4326), j)))  As the_geom
-	</pgis:gardencrashers>
-        <!-- We deal only with the reference chapter -->
-        <xsl:template match="/">
-                <xsl:apply-templates select="/book/chapter[@id='reference']" />
-        </xsl:template>
-	<xsl:template match='chapter'>
-<!-- Start regular function checks excluding operators -->
-		<xsl:for-each select="sect1[not(contains(@id,'Operator'))]/refentry">
-		<xsl:sort select="@id"/>
-			<xsl:for-each select="refsynopsisdiv/funcsynopsis/funcprototype">
-<!--Create dummy parameters to be used later -->
-				<xsl:variable name='fnfakeparams'><xsl:call-template name="replaceparams"><xsl:with-param name="func" select="." /></xsl:call-template></xsl:variable>
-				<xsl:variable name='fnargs'><xsl:call-template name="listparams"><xsl:with-param name="func" select="." /></xsl:call-template></xsl:variable>
-				<xsl:variable name='fnname'><xsl:value-of select="funcdef/function"/></xsl:variable>
-				<xsl:variable name='fndef'><xsl:value-of select="funcdef"/></xsl:variable>
-				<xsl:variable name='numparams'><xsl:value-of select="count(paramdef/parameter)" /></xsl:variable>
-				<xsl:variable name='numparamgeoms'><xsl:value-of select="count(paramdef/type[contains(text(),'geometry') or contains(text(),'geography') or contains(text(),'box') or contains(text(), 'bytea')]) + count(paramdef/parameter[contains(text(),'WKT')]) + count(paramdef/parameter[contains(text(),'geomgml')])" /></xsl:variable>
-				<xsl:variable name='numparamgeogs'><xsl:value-of select="count(paramdef/type[contains(text(),'geography')] )" /></xsl:variable>
-				<!-- For each function prototype generate a test sql statement -->
-				<xsl:choose>
-<!--Test functions that take no arguments or take no geometries -->
-	<xsl:when test="$numparamgeoms = '0' and contains($fninclude,funcdef/function)">SELECT  'Starting <xsl:value-of select="funcdef/function" />(<xsl:value-of select="$fnargs" />)';BEGIN;
-SELECT  <xsl:value-of select="funcdef/function" />(<xsl:value-of select="$fnfakeparams" />);
-COMMIT;
-SELECT  'Ending <xsl:value-of select="funcdef/function" />(<xsl:value-of select="$fnargs" />)';
-	</xsl:when>
-<!--Start Test aggregate and unary functions -->
-<!-- put functions that take only one geometry no need to cross with another geom collection, these are unary geom, aggregates, and so forth -->
-	<xsl:when test="$numparamgeoms = '1' and contains($fninclude,funcdef/function)" >
-		<xsl:for-each select="document('')//pgis:gardens/pgis:gset">
-			<xsl:choose>
-			  <xsl:when test="contains(paramdef, 'geometry ')">
-	SELECT 'Geometry <xsl:value-of select="$fnname" /><xsl:text> </xsl:text><xsl:value-of select="@ID" />: Start Testing <xsl:value-of select="@GeometryType" />';
-	BEGIN; <!-- If output is geometry show ewkt rep -->
-	SELECT ST_AsEWKT(<xsl:value-of select="$fnname" />(<xsl:value-of select="$fnfakeparams" />))
-			  </xsl:when>
-			  <xsl:when test="contains(paramdef, 'geography ')">
-	SELECT 'Geography <xsl:value-of select="$fnname" /><xsl:text> </xsl:text><xsl:value-of select="@ID" />: Start Testing <xsl:value-of select="@GeometryType" />';
-	BEGIN; <!-- If output is geometry show astext rep -->
-	SELECT ST_AsText(<xsl:value-of select="$fnname" />(<xsl:value-of select="$fnfakeparams" />))
-			  </xsl:when>
-			  <xsl:otherwise>
-	SELECT 'Other <xsl:value-of select="$fnname" /><xsl:text> </xsl:text><xsl:value-of select="@ID" />: Start Testing <xsl:value-of select="@GeometryType" />';
-	SELECT <xsl:value-of select="$fnname" />(<xsl:value-of select="$fnfakeparams" />)
-			  </xsl:otherwise>
-			</xsl:choose>
-			FROM (<xsl:value-of select="." />) As foo1
-			LIMIT 3;
-	COMMIT;
-	SELECT '<xsl:value-of select="$fnname" /><xsl:text> </xsl:text> <xsl:value-of select="@ID" />: End Testing <xsl:value-of select="@GeometryType" />';
-		<xsl:text>
-		</xsl:text>
-		</xsl:for-each>
-	</xsl:when>
-<!--Functions more than 1 args not already covered this will cross every geometry type with every other -->
-	<xsl:when test="contains($fninclude,funcdef/function)">
-	<!--Store first garden sql geometry from -->
-			<xsl:variable name="from1"><xsl:value-of select="." /></xsl:variable>
-			<xsl:variable name='geom1type'><xsl:value-of select="@ID"/></xsl:variable>
-SELECT '<xsl:value-of select="$fnname" /> <xsl:text> </xsl:text><xsl:value-of select="@ID" />(<xsl:value-of select="$fnargs" />): Start Testing <xsl:value-of select="$geom1type" /> against other types';
-			<xsl:choose>
-			  <xsl:when test="$numparamgeogs > '0'">
-				SELECT 'Geography <xsl:value-of select="$fnname" /><xsl:text> </xsl:text><xsl:value-of select="@ID" />(<xsl:value-of select="$fnargs" />): Start Testing <xsl:value-of select="$geom1type" />, <xsl:value-of select="@GeometryType" />';
-	BEGIN; <!-- If output is geography show wkt rep -->
-	SELECT <xsl:value-of select="$fnname" />(<xsl:value-of select="$fnfakeparams" />), ST_AsText(foo1.the_geom) As ref1_geom, ST_AsText(foo2.the_geom) As ref2_geom
-			  </xsl:when>
-			  <xsl:when test="$numparamgeoms > '0'">
-				SELECT 'Geometry <xsl:value-of select="$fnname" /><xsl:text> </xsl:text><xsl:value-of select="@ID" />(<xsl:value-of select="$fnargs" />): Start Testing <xsl:value-of select="$geom1type" />, <xsl:value-of select="@GeometryType" />';
-	SELECT <xsl:value-of select="$fnname" />(<xsl:value-of select="$fnfakeparams" />), ST_AsEWKT(foo1.the_geom) As ref1_geom, ST_AsEWKT(foo2.the_geom) As ref2_geom
-			  </xsl:when>
-			  <xsl:otherwise>
-				SELECT 'Other <xsl:value-of select="$fnname" /><xsl:text> </xsl:text><xsl:value-of select="@ID" />(<xsl:value-of select="$fnargs" />): Start Testing <xsl:value-of select="$geom1type" />, <xsl:value-of select="@GeometryType" />';
-			  </xsl:otherwise>
-			</xsl:choose>
-			FROM (<xsl:value-of select="$from1" />) As foo1 CROSS JOIN (<xsl:value-of select="." />) As foo2
-			LIMIT 2;
-	COMMIT;
-	SELECT '<xsl:value-of select="$fnname" />(<xsl:value-of select="$fnargs" />) <xsl:text> </xsl:text> <xsl:value-of select="@ID" />: End Testing <xsl:value-of select="$geom1type" />, <xsl:value-of select="@GeometryType" />';
-		<xsl:text>
-		</xsl:text>
-			</xsl:for-each>
-SELECT '<xsl:value-of select="$fnname" /><xsl:text> </xsl:text><xsl:value-of select="@ID" />(<xsl:value-of select="$fnargs" />): End Testing <xsl:value-of select="@GeometryType" /> against other types';
-		</xsl:for-each>
-		</xsl:when>
-	</xsl:choose>
-			</xsl:for-each>
-		</xsl:for-each>
-	</xsl:template>
-	<!--macro to replace func args with dummy var args -->
-	<xsl:template name="replaceparams">
-		<xsl:param name="func" />
-		<xsl:for-each select="$func">
-			<xsl:for-each select="paramdef">
-				<xsl:choose>
-					<xsl:when test="contains(parameter, 'matrix') or contains(parameter, 'Matrix')">
-						<xsl:value-of select="$var_matrix" />
-					</xsl:when>
-					<xsl:when test="contains(parameter, 'distance')">
-						<xsl:value-of select="$var_distance" />
-					</xsl:when>
-					<xsl:when test="contains(parameter, 'srid')">
-						<xsl:value-of select="$var_srid" />
-					</xsl:when>
-					<xsl:when test="contains(parameter, 'position')">
-						<xsl:value-of select="$var_position" />
-					</xsl:when>
-					<xsl:when test="contains(parameter, 'NDR')">
-						'<xsl:value-of select="$var_NDRXDR" />'
-					</xsl:when>
-					<xsl:when test="contains(parameter, 'version') and position() = 2">
-						<xsl:value-of select="$var_version1" />
-					</xsl:when>
-					<xsl:when test="(contains(parameter, 'version'))">
-						<xsl:value-of select="$var_version2" />
-					</xsl:when>
-					<xsl:when test="(contains(parameter,'geomgml'))">
-						<xsl:text>ST_AsGML(foo1.the_geom)</xsl:text>
-					</xsl:when>
-					<xsl:when test="(contains(type,'box') or type = 'geometry' or type = 'geometry ' or contains(type,'geometry set')) and (position() = 1 or count($func/paramdef/type[contains(text(),'geometry') or contains(text(),'box') or contains(text(), 'WKT') or contains(text(), 'bytea')]) = '1')">
-						<xsl:text>foo1.the_geom</xsl:text>
-					</xsl:when>
-					<xsl:when test="(type = 'geography' or type = 'geography ' or contains(type,'geography set')) and (position() = 1 or count($func/paramdef/type[contains(text(),'geography')]) = '1' )">
-						<xsl:text>geography(foo1.the_geom)</xsl:text>
-					</xsl:when>
-					<xsl:when test="contains(type,'box') or type = 'geometry' or type = 'geometry '">
-						<xsl:text>foo2.the_geom</xsl:text>
-					</xsl:when>
-					<xsl:when test="type = 'geography' or type = 'geography '">
-						<xsl:text>geography(foo2.the_geom)</xsl:text>
-					</xsl:when>
-					<xsl:when test="contains(type, 'geometry[]') and count($func/paramdef/type[contains(text(),'geometry') or contains(text(),'box') or contains(text(), 'WKT') or contains(text(), 'bytea')]) = '1'">
-						ARRAY[foo1.the_geom]
-					</xsl:when>
-					<xsl:when test="contains(type, 'geometry[]')">
-						ARRAY[foo2.the_geom]
-					</xsl:when>
-					<xsl:when test="contains(parameter, 'EWKT')">
-						<xsl:text>ST_AsEWKT(foo1.the_geom)</xsl:text>
-					</xsl:when>
-					<xsl:when test="contains(parameter, 'WKT')">
-						<xsl:text>ST_AsText(foo1.the_geom)</xsl:text>
-					</xsl:when>
-					<xsl:when test="contains(parameter, 'EWKB')">
-						<xsl:text>ST_AsEWKB(foo1.the_geom)</xsl:text>
-					</xsl:when>
-					<xsl:when test="contains(type, 'bytea')">
-						<xsl:text>ST_AsBinary(foo1.the_geom)</xsl:text>
-					</xsl:when>
-					<xsl:when test="contains(type, 'float') or contains(type, 'double')">
-						<xsl:value-of select="$var_float1" />
-					</xsl:when>
-					<xsl:when test="contains(type, 'spheroid')">
-						<xsl:value-of select="$var_spheroid" />
-					</xsl:when>
-					<xsl:when test="contains(type, 'integer') and position() = 2">
-						<xsl:value-of select="$var_integer1" />
-					</xsl:when>
-					<xsl:when test="contains(type, 'integer')">
-						<xsl:value-of select="$var_integer2" />
-					</xsl:when>
-					<xsl:when test="contains(type, 'text')">
-						<xsl:value-of select="$var_text" />
-					</xsl:when>
-					<xsl:when test="contains(type, 'varchar')">
-						<xsl:value-of select="$var_varchar" />
-					</xsl:when>
-					<xsl:when test="contains(type,'timestamp') or type = 'date'">
-						<xsl:text>'2009-01-01'</xsl:text>
-					</xsl:when>
-					<xsl:when test="contains(type,'boolean')">
-						<xsl:value-of select="$var_boolean" />
-					</xsl:when>
-				</xsl:choose>
-				<xsl:if test="position()<last()"><xsl:text>, </xsl:text></xsl:if>
-			</xsl:for-each>
-		</xsl:for-each>
-	</xsl:template>
-	<!--macro to pull out function parameter names so we can provide a pretty arg list prefix for each function -->
-	<xsl:template name="listparams">
-			<xsl:if test="count(paramdef/parameter) > 0"> </xsl:if>
-				<xsl:choose>
-					<xsl:when test="count(parameter) > 0">
-						<xsl:value-of select="parameter" />
-					</xsl:when>
-				</xsl:choose>
-			</xsl:for-each>
-		</xsl:for-each>
-	</xsl:template>
-</xsl:stylesheet>
diff --git a/doc/xsl/raster_gardentest.sql.xsl b/doc/xsl/raster_gardentest.sql.xsl
index 053df77ef..6f7ff25cf 100644
--- a/doc/xsl/raster_gardentest.sql.xsl
+++ b/doc/xsl/raster_gardentest.sql.xsl
@@ -8,7 +8,7 @@
 			using a garden variety of rasters.  Its intent is to flag major crashes.
+	<xsl:variable name='testversion'>3.4.0</xsl:variable>
 	<xsl:variable name='fnexclude'>AddRasterColumn AddRasterConstraints DropRasterConstraints DropRasterColumn DropRasterTable</xsl:variable>
 	<!--This is just a place holder to state functions not supported in 1.3 or tested separately -->
@@ -31,7 +31,7 @@
 	<xsl:variable name='var_rastercolumn'>'rast'</xsl:variable>
 	<xsl:variable name='var_rastertable'>'pgis_rgarden_1bb'</xsl:variable>
-	<xsl:variable name='var_logtable'>raster_garden_log33</xsl:variable>
+	<xsl:variable name='var_logtable'>raster_garden_log34</xsl:variable>
 	<xsl:variable name='var_pixeltypes'>{8BUI,1BB}</xsl:variable>
 	<xsl:variable name='var_pixelvalues'>{255,0}</xsl:variable>
 	<xsl:variable name='var_algorithm'>'Lanczos'</xsl:variable>
@@ -67,6 +67,10 @@
+		</pgis:gset>
 	</pgis:gardens>
 	<!--changed all to no skew so they pass the world tests -->
 	<pgis:pixeltypes>
commit 6bedfb72ca0ab3e5919d17f3f52f259573c0a56a
Date:   Fri Feb 17 19:21:37 2023 -0500
    remove dump_restore from debbie run it's currently failing with schema exists errors topology, tiger
diff --git a/ci/debbie/postgis_regress.sh b/ci/debbie/postgis_regress.sh
index 801f21c60..e51925692 100644
--- a/ci/debbie/postgis_regress.sh
+++ b/ci/debbie/postgis_regress.sh
@@ -14,7 +14,7 @@ set -e
 # export SFCGAL_VER=1.3
 export MAKE_GARDEN=0
 export MAKE_EXTENSION=1
-export DUMP_RESTORE=1
+export DUMP_RESTORE=0
 export MAKE_LOGBT=0
 export NO_SFCGAL=0
 export MAKE_UPGRADE=1
Summary of changes:
 ci/debbie/postgis_regress.sh              |   2 +-
 doc/xsl/postgis_gardentest.sql.xsl        |  21 +-
 doc/xsl/postgis_gardentest_subset.sql.xsl | 375 ------------------------------
 doc/xsl/raster_gardentest.sql.xsl         |   8 +-
 4 files changed, 27 insertions(+), 379 deletions(-)
 delete mode 100644 doc/xsl/postgis_gardentest_subset.sql.xsl
hooks/post-receive
