[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-638-g1cdfe9fa4
Sun Feb 19 15:51:43 PST 2023
the project "PostGIS".
       via  1cdfe9fa401d65b839dbf2d131cd3bf92e12deef (commit)
      from  c2dbb220d05789dd4f4ae76b19071c2c742444ea (commit)
revisions in full, below.
commit 1cdfe9fa401d65b839dbf2d131cd3bf92e12deef
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Feb 20 00:50:51 2023 +0100
    run_test.pl: don't prepare target db restoring from ext based dump
    Closes #5343
diff --git a/regress/run_test.pl b/regress/run_test.pl
index f6384ab59..6afc54bd4 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -394,13 +394,21 @@ if ( $OPT_DUMPRESTORE )
         die;
-    print "Creating spatial db '${DB}'\n";
-    undef($OPT_UPGRADE_FROM); # to directly prepare the target
-    $rv = create_spatial();
+    print "Creating db '${DB}'\n";
+    $rv = create_db();
     if ( ! $rv ) {
-        fail("Could not create spatial db ${DB}", $REGRESS_LOG);
+        fail("Could not create db ${DB}", $REGRESS_LOG);
         die;
+    # Extension based spatial db do not need the target
+    # database to be prepared in any way, script based
+    # spatial db requires being prepared.
+    if ( not $OPT_EXTENSIONS )
+        die unless prepare_spatial();
     die unless restore_db($DBDUMP);
     unlink($DBDUMP);
@@ -1427,7 +1435,7 @@ sub count_postgis_objects
 sub create_db
 	my $createcmd = "createdb --encoding=UTF-8 --template=template0 --lc-collate=C $DB > $REGRESS_LOG";
-	return system($createcmd);
+	return not system($createcmd);
 sub create_spatial
Summary of changes:
 regress/run_test.pl | 18 +++++++++++++-----
 1 file changed, 13 insertions(+), 5 deletions(-)
hooks/post-receive
