[postgis-tickets] [PostGIS] #5345: Topology upgrade not supporting new CAST (was: upgrade script not supporting new CAST)
PostGIS trac at osgeo.org
Tue Feb 21 00:40:05 PST 2023
  Reporter:  robe      |      Owner:  strk
      Type:  defect    |     Status:  assigned
  Priority:  medium    |  Milestone:  PostGIS 3.4.0
 Component:  topology  |    Version:  master
Resolution:            |   Keywords:
Changes (by strk):
 * status:  new => assigned
 * component:  build/upgrade/install => topology
 * summary:  upgrade script not supporting new CAST => Topology upgrade not
     supporting new CAST
Old description:
> I tried creating a CAST for topology, but the create_upgrade.pl script is
> not catching it
> has a line:
> #Generate upgrade script by stripping things that can't be reinstalled
> 3:33AM
> and # TODO: use create_upgrade.pl
New description:
 I tried creating a CAST for topology, but the topology_upgrade.sql script
 is not adding it
 topology/Makefile.in has a line:
 3:33AM
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5345#comment:1>
