[postgis-tickets] [PostGIS] #5293: toTopoGeom: corrupted topology: face xxx could not be constructed only from edges knowing about it (like edge yyy).
PostGIS trac at osgeo.org
Wed Feb 22 06:39:17 PST 2023
  Reporter:  strk      |      Owner:  strk
      Type:  defect    |     Status:  new
  Priority:  medium    |  Milestone:  PostGIS 3.4.0
 Component:  topology  |    Version:  master
Resolution:            |   Keywords:
Comment (by laopsahl):
 I am testing on
 POSTGIS="3.2.3 2f97b6c" [EXTENSION] PGSQL="140" GEOS="3.11.0-CAPI-1.17.0"
 PROJ="9.0.1" LIBXML="2.9.14" LIBJSON="0.16" LIBPROTOBUF="1.4.1"
 WAGYU="0.5.0 (Internal)" TOPOLOGY
 When I run the command below with test.sql a couple of times this, I see
 the log below.
 This are also the same error messages related to this error
 [https://gitlab.com/nibioopensource/resolve-overlap-and-gap/-/issues/46]
 rm /tmp/error.out; psql nibio_reg -f /tmp/test.sql 2>/tmp/error.out; cat
 /tmp/error.out
 I find this in error.out file.
 psql:/tmp/test.sql:1: NOTICE:  00000: Dropping all layers from topology
 'postgis_ticket_5293_topo' (3)
 psql:/tmp/test.sql:1: NOTICE:  00000: drop cascades to 6 other objects
 DETAIL:  drop cascades to table postgis_ticket_5293_topo.face
 drop cascades to table postgis_ticket_5293_topo.node
 drop cascades to table postgis_ticket_5293_topo.edge_data
 drop cascades to view postgis_ticket_5293_topo.edge
 drop cascades to sequence postgis_ticket_5293_topo.layer_id_seq
 drop cascades to table postgis_ticket_5293_topo.relation
 psql:/tmp/test.sql:74: ERROR:  XX000: Corrupted topology: adjacent edges
 -64 and -64 bind different face (45 and 0)
 psql:/tmp/test.sql:79: ERROR:  XX000: Corrupted topology: adjacent edges
 psql:/tmp/test.sql:111: NOTICE:  00000: Checking for coincident nodes
 psql:/tmp/test.sql:111: NOTICE:  00000: Checking for edges crossing nodes
 psql:/tmp/test.sql:111: NOTICE:  00000: Checking for invalid or not-simple
 edges
 psql:/tmp/test.sql:111: NOTICE:  00000: Checking for crossing edges
 psql:/tmp/test.sql:111: NOTICE:  00000: Checking for edges start_node
 mismatch
 psql:/tmp/test.sql:111: NOTICE:  00000: Checking for edges end_node
 mismatch
 psql:/tmp/test.sql:111: NOTICE:  00000: Checking for faces without edges
 psql:/tmp/test.sql:111: NOTICE:  00000: Checking edge linking
 psql:/tmp/test.sql:111: NOTICE:  00000: Building edge rings
 psql:/tmp/test.sql:111: NOTICE:  00000: Found 95 rings, 63 valid shells,
 32 valid holes
 psql:/tmp/test.sql:111: NOTICE:  00000: Constructing geometry of all faces
 psql:/tmp/test.sql:111: NOTICE:  00000: Checking faces
 psql:/tmp/test.sql:111: NOTICE:  00000: Checked 63 faces
 psql:/tmp/test.sql:111: NOTICE:  00000: Checking for holes coverage
 psql:/tmp/test.sql:111: NOTICE:  00000: Finished checking for coverage of
 32 holes
 psql:/tmp/test.sql:111: NOTICE:  00000: Checking for node containing_face
 correctness
 psql:/tmp/test.sql:112: ERROR:  XX000: Corrupted topology: adjacent edges
 -64 and -64 bind different face (45 and 52)
 psql:/tmp/test.sql:113: NOTICE:  00000: Checking for coincident nodes
 psql:/tmp/test.sql:113: NOTICE:  00000: Checking for edges crossing nodes
 psql:/tmp/test.sql:113: NOTICE:  00000: Checking for invalid or not-simple
 edges
 psql:/tmp/test.sql:113: NOTICE:  00000: Checking for crossing edges
 psql:/tmp/test.sql:113: NOTICE:  00000: Checking for edges start_node
 mismatch
 psql:/tmp/test.sql:113: NOTICE:  00000: Checking for edges end_node
 mismatch
 psql:/tmp/test.sql:113: NOTICE:  00000: Checking for faces without edges
 psql:/tmp/test.sql:113: NOTICE:  00000: Checking edge linking
 psql:/tmp/test.sql:113: NOTICE:  00000: Building edge rings
 psql:/tmp/test.sql:113: NOTICE:  00000: Found 95 rings, 63 valid shells,
 32 valid holes
 psql:/tmp/test.sql:113: NOTICE:  00000: Constructing geometry of all faces
 psql:/tmp/test.sql:113: NOTICE:  00000: Checking faces
 psql:/tmp/test.sql:113: NOTICE:  00000: Checked 63 faces
 psql:/tmp/test.sql:113: NOTICE:  00000: Checking for holes coverage
 psql:/tmp/test.sql:113: NOTICE:  00000: Finished checking for coverage of
 32 holes
 psql:/tmp/test.sql:113: NOTICE:  00000: Checking for node containing_face
 correctness
 Larss-MacBook-Pro:resolve-overlap-and-gap lop$ gzip /tmp/test.sql
 Larss-MacBook-Pro:resolve-overlap-and-gap lop$ cat /tmp/error.out
 edges
 mismatch
 mismatch
 32 valid holes
 32 holes
 correctness
 edges
 mismatch
 mismatch
 32 valid holes
 32 holes
 correctness
 edges
 mismatch
 mismatch
 32 valid holes
 32 holes
 correctness
 edges
 mismatch
 mismatch
 32 valid holes
 32 holes
 correctness
 edges
 mismatch
 mismatch
 32 valid holes
 32 holes
 correctness
 edges
 mismatch
 mismatch
 32 valid holes
 32 holes
 correctness
 edges
 mismatch
 mismatch
 32 valid holes
 32 holes
 correctness
 edges
 mismatch
 mismatch
 32 valid holes
 32 holes
 correctness
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5293#comment:6>
