[postgis-tickets] [PostGIS] #5349: postgis_restore.pl autogenerate function signatures for new install
PostGIS trac at osgeo.org
Mon Feb 27 09:13:32 PST 2023
 Reporter:  robe                   |      Owner:  strk
     Type:  defect                 |     Status:  new
 Priority:  medium                 |  Milestone:  PostGIS 3.4.0
Component:  build/upgrade/install  |    Version:  master
 Keywords:                         |
 As noted in #5348, function signatures are hardcoded
 When non-extension dumprestore fails it's probably the postgis_restore.pl
 script missing knowledge about a signature that should be stripped from
 the dump. It might be useful to generate part of that list, given our
 source knows about ANY signature we EVER released in a version we support
 soft-upgrade from, but those dumps could also come from earlier version,
 which is why the list we can generate is partial.
 This ticket is to support not hard-coding new ones.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5349>
