[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-670-g1a004f40f
Mon Feb 27 10:24:28 PST 2023
the project "PostGIS".
       via  1a004f40f7fb446aa84caae213d4b782ea74e209 (commit)
      from  e7ac8e1f8a63cbc4af2eb0d3b815f7fac79eac6f (commit)
revisions in full, below.
commit 1a004f40f7fb446aa84caae213d4b782ea74e209
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Feb 27 19:11:38 2023 +0100
    Always update the postgis_restore.pl skip list
    References #5348
diff --git a/.gitignore b/.gitignore
index 8485dcc10..b928337a8 100644
--- a/.gitignore
+++ b/.gitignore
@@ -185,6 +185,8 @@ libpgcommon/Makefile
 libpgcommon/cunit/Makefile
 utils/Makefile
 utils/postgis_restore.pl
+utils/postgis_restore_data.generated
+utils/postgis_restore_data.hardcoded
 doc/sfcgal_comments.sql
 postgis/sfcgal.sql
 postgis/uninstall_sfcgal.sql
diff --git a/utils/Makefile.in b/utils/Makefile.in
index a0b8be196..938dca6ad 100644
--- a/utils/Makefile.in
+++ b/utils/Makefile.in
@@ -41,14 +41,18 @@ SCRIPTS = \
 all: $(SCRIPTS_built)
 DROP_FILES = \
-  ../raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in \
-  ../raster/rt_pg/rtpostgis_drop.sql.in \
-  ../postgis/postgis_after_upgrade.sql \
-  ../postgis/postgis_before_upgrade.sql
-update-restore:
-	tac postgis_restore.pl.in | sed '/^__END__/q' | grep -v '^__END__' \
-    > postgis_restore_data
+  $(top_srcdir)/raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in \
+  $(top_srcdir)/raster/rt_pg/rtpostgis_drop.sql.in \
+  $(top_srcdir)/postgis/postgis_after_upgrade.sql \
+  $(top_srcdir)/postgis/postgis_before_upgrade.sql
+postgis_restore_data.hardcoded: postgis_restore.pl.in
+	tac $< \
+		| sed '/^__END__/q' \
+		| grep -v '^__END__' \
+postgis_restore_data.generated: $(DROP_FILES)
 	grep '^DROP FUNCTION IF EXISTS' $(DROP_FILES) | \
     cut -d: -f2 | sed 's/^DROP FUNCTION IF EXISTS //' | \
     sed 's/ *, */,/g' | \
@@ -60,17 +64,20 @@ update-restore:
     sed 's/\<int\>/integer/g' | \
     sed 's/\<int4\>/integer/g' | \
     sed 's/\<int8\>/bigint/g' | \
-    sed 's/\(.*\); *\(--.*\)\?/FUNCTION \1/' >> postgis_restore_data
-	cat postgis_restore.pl.in | sed '/^__END__/q' > postgis_restore.pl.in.new
-	cat postgis_restore_data | sort -u >> postgis_restore.pl.in.new
-	mv postgis_restore.pl.in.new postgis_restore.pl.in
+    sed 's/\(.*\); *\(--.*\)\?/FUNCTION \1/' \
-postgis_restore.pl: postgis_restore.pl.in
-	sed 's, at SRID_MAXIMUM@,$(SRID_MAXIMUM),g;s, at SRID_USER_MAXIMUM@,$(SRID_USER_MAXIMUM),' $< >$@
+postgis_restore.pl: postgis_restore.pl.in postgis_restore_data.hardcoded postgis_restore_data.generated Makefile
+	cat $< \
+		| sed 's, at SRID_MAXIMUM@,$(SRID_MAXIMUM),g;s, at SRID_USER_MAXIMUM@,$(SRID_USER_MAXIMUM),' \
+		> postgis_restore.pl
+	cat postgis_restore_data.hardcoded postgis_restore_data.generated \
+		| sort -u >> postgis_restore.pl
 	chmod +x $@
 clean:
-	rm -f $(SCRIPTS_built) postgis_restore_data
+	rm -f $(SCRIPTS_built) postgis_restore_data.generated postgis_restore_data.hardcoded
 distclean: clean
 	rm -f Makefile
Summary of changes:
 .gitignore        |  2 ++
 utils/Makefile.in | 37 ++++++++++++++++++++++---------------
 2 files changed, 24 insertions(+), 15 deletions(-)
hooks/post-receive
