[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-674-g90ebdd39d
Mon Feb 27 13:28:06 PST 2023
the project "PostGIS".
       via  90ebdd39d78f10225333ec5b605a5bfa704b614f (commit)
      from  ac81ed5c4b22e32ee7cf33bf4931b364b5bd3465 (commit)
revisions in full, below.
commit 90ebdd39d78f10225333ec5b605a5bfa704b614f
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Feb 27 22:27:27 2023 +0100
    Rename create_undef.pl to create_uninstall.pl
    Time to become clearer
diff --git a/extras/rpm/spec/postgis.spec b/extras/rpm/spec/postgis.spec
index 85955248c..d6110d059 100644
--- a/extras/rpm/spec/postgis.spec
+++ b/extras/rpm/spec/postgis.spec
@@ -22,8 +22,8 @@ Requires:	postgresql, geos, proj
 PostGIS adds support for geographic objects to the PostgreSQL object-relational
 database. In effect, PostGIS "spatially enables" the PostgreSQL server,
 allowing it to be used as a backend spatial database for geographic information
-systems (GIS), much like ESRI's SDE or Oracle's Spatial extension. PostGIS
-follows the OpenGIS "Simple Features Specification for SQL" and has been
+systems (GIS), much like ESRI's SDE or Oracle's Spatial extension. PostGIS
+follows the OpenGIS "Simple Features Specification for SQL" and has been
 certified as compliant with the "Types and Functions" profile.
 %if %javabuild
@@ -62,7 +62,7 @@ The postgis-utils package provides the utilities for PostGIS.
 %patch2 -p0
 %build
-%configure
+%configure
 make %{?_smp_mflags} LPATH=`pg_config --pkglibdir` shlib="%{name}.so"
 %if %javabuild
@@ -111,7 +111,7 @@ rm -rf %{buildroot}
 %files
 %defattr(-,root,root)
-%doc COPYING CREDITS NEWS TODO README.%{name} TODO doc/html loader/README.* doc/%{name}.xml  doc/ZMSgeoms.txt
+%doc COPYING CREDITS NEWS TODO README.%{name} TODO doc/html loader/README.* doc/%{name}.xml  doc/ZMSgeoms.txt
 %attr(755,root,root) %{_bindir}/*
 %attr(755,root,root) %{_libdir}/pgsql/liblwgeom.so*
 %{_datadir}/pgsql/contrib/*.sql
@@ -135,7 +135,7 @@ rm -rf %{buildroot}
 %attr(755,root,root) %{_datadir}/%{name}/test_estimation.pl
 %attr(755,root,root) %{_datadir}/%{name}/profile_intersects.pl
 %attr(755,root,root) %{_datadir}/%{name}/test_joinestimation.pl
-%attr(644,root,root) %{_datadir}/%{name}/create_undef.pl
+%attr(644,root,root) %{_datadir}/%{name}/create_uninstall.pl
 %attr(644,root,root) %{_datadir}/%{name}/%{name}_proc_upgrade.pl
 %attr(644,root,root) %{_datadir}/%{name}/%{name}_restore.pl
 %endif
@@ -162,7 +162,7 @@ rm -rf %{buildroot}
 - Fixed all build errors except jdbc (so, defaulted to 0)
 - Added new files under %%utils
 - Removed postgis-jdbc2-makefile.patch (applied to -head)
 * Tue Sep 27 2005 - Devrim GUNDUZ <devrim at gunduz.org>
 - Update to 1.0.4
diff --git a/postgis/Makefile.in b/postgis/Makefile.in
index b5aef0768..5a68cf9d1 100644
--- a/postgis/Makefile.in
+++ b/postgis/Makefile.in
@@ -256,11 +256,11 @@ $(SQL_OBJS): ../postgis_config.h ../postgis_revision.h
 #postgis.sql.in: sqldefines.h long_xact.sql.in.c geography.sql.in.c
-uninstall_postgis.sql: postgis.sql ../utils/create_undef.pl
-	$(PERL) @top_srcdir@/utils/create_undef.pl $< $(POSTGIS_PGSQL_VERSION) > $@
+uninstall_postgis.sql: postgis.sql ../utils/create_uninstall.pl
+	$(PERL) @top_srcdir@/utils/create_uninstall.pl $< $(POSTGIS_PGSQL_VERSION) > $@
-uninstall_legacy.sql: legacy.sql ../utils/create_undef.pl
+uninstall_legacy.sql: legacy.sql ../utils/create_uninstall.pl
 distclean: clean
 	rm -f Makefile
diff --git a/raster/rt_pg/Makefile.in b/raster/rt_pg/Makefile.in
index cbbf6db57..4fa8a748c 100644
--- a/raster/rt_pg/Makefile.in
+++ b/raster/rt_pg/Makefile.in
@@ -156,8 +156,8 @@ rtpostgis_upgrade.sql: rtpostgis_upgrade_cleanup.sql rtpostgis_upgrade.sql.in rt
 	cat $^ | sed -e 's/^BEGIN;$$//' -e 's/^COMMIT;$$//' >> $@
 	echo 'COMMIT;' >> $@
-uninstall_rtpostgis.sql: rtpostgis.sql ../../utils/create_undef.pl
+uninstall_rtpostgis.sql: rtpostgis.sql ../../utils/create_uninstall.pl
 distclean: clean
 	rm -f Makefile
diff --git a/sfcgal/Makefile.in b/sfcgal/Makefile.in
index 9776bb87d..f6e4360fa 100644
--- a/sfcgal/Makefile.in
+++ b/sfcgal/Makefile.in
@@ -135,11 +135,11 @@ sfcgal_upgrade.sql: sfcgal_before_upgrade.sql sfcgal_upgrade.sql.in sfcgal_after
 	cat $^ >> $@
 	echo "COMMIT;" >> $@
-uninstall_sfcgal_legacy.sql: sfcgal_legacy.sql ../utils/create_undef.pl
+uninstall_sfcgal_legacy.sql: sfcgal_legacy.sql ../utils/create_uninstall.pl
-uninstall_sfcgal.sql: sfcgal.sql ../utils/create_undef.pl
+uninstall_sfcgal.sql: sfcgal.sql ../utils/create_uninstall.pl
 distclean: clean
 	rm -f Makefile
diff --git a/topology/Makefile.in b/topology/Makefile.in
index 4d0d2f811..0e02a6012 100644
--- a/topology/Makefile.in
+++ b/topology/Makefile.in
@@ -156,8 +156,8 @@ topology.sql: \
 	../postgis/sqldefines.h \
-uninstall_topology.sql: topology.sql ../utils/create_undef.pl
+uninstall_topology.sql: topology.sql ../utils/create_uninstall.pl
 check-unit:
diff --git a/utils/Makefile.in b/utils/Makefile.in
index e30676fd2..9d18b28a3 100644
--- a/utils/Makefile.in
+++ b/utils/Makefile.in
@@ -31,7 +31,7 @@ INSTALL = $(SHELL) @top_srcdir@/build-aux/install-sh
 SCRIPTS_built = postgis_restore.pl
 SCRIPTS = \
-	create_undef.pl \
+	create_uninstall.pl \
 	repo_revision.pl \
 	create_upgrade.pl \
 	profile_intersects.pl \
diff --git a/utils/create_undef.pl b/utils/create_uninstall.pl
similarity index 98%
rename from utils/create_undef.pl
rename to utils/create_uninstall.pl
index 4036801dc..1f351e362 100755
--- a/utils/create_undef.pl
+++ b/utils/create_uninstall.pl
@@ -21,7 +21,7 @@ eval "exec perl -w $0 $@"
 	if (0);
-($#ARGV == 1) || die "Usage: perl create_undef.pl <postgis.sql> <pgsql_version #>\nCreates a new SQL script to delete all the PostGIS functions.\n";
+($#ARGV == 1) || die "Usage: perl $0 <postgis.sql> <pgsql_version #>\nCreates a new SQL script to delete all the PostGIS functions.\n";
 # drops are in the following order:
 # - Views
Summary of changes:
 extras/rpm/spec/postgis.spec                   | 12 ++++++------
 postgis/Makefile.in                            |  8 ++++----
 raster/rt_pg/Makefile.in                       |  4 ++--
 sfcgal/Makefile.in                             |  8 ++++----
 topology/Makefile.in                           |  4 ++--
 utils/Makefile.in                              |  2 +-
 utils/{create_undef.pl => create_uninstall.pl} |  2 +-
 7 files changed, 20 insertions(+), 20 deletions(-)
 rename utils/{create_undef.pl => create_uninstall.pl} (98%)
hooks/post-receive
