[postgis-tickets] [PostGIS] #5348: Non-extension based dump-restore tests failing on new ST_ClusterIntersectingWin
PostGIS trac at osgeo.org
Mon Feb 27 16:02:38 PST 2023
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  medium                 |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:  fixed                  |   Keywords:
Changes (by Sandro Santilli <strk@…>):
 * status:  assigned => closed
 * resolution:   => fixed
Comment:
 In [changeset:"418bc7396dc535fd688e0a95b35e9e169a95eac6/git" 418bc73/git]:
 {{{#!CommitTicketReference repository="git"
 revision="418bc7396dc535fd688e0a95b35e9e169a95eac6"
 Add ad-hoc script to create skip signatures for postgis_restore.pl
 Update the hardcoded skiplist to drop more things we can now generate
 Fixes #5348
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5348#comment:8>
