[postgis-tickets] [PostGIS] #5312: GEOS master regression failure on tickets
PostGIS trac at osgeo.org
Wed Jan 11 11:36:24 PST 2023
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  blocker  |  Milestone:  PostGIS 3.4.0
Component:  postgis  |    Version:  3.3.x
 Keywords:           |
 Just noticed debbie has been complaining for past 2 days.
 I'm guessing this is a geos change.
 07:43:49  ./regress/core/tickets .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/tmp/3_4_pg15w64/test_85_diff)
 07:43:54
 07:43:54 --- ./regress/core/tickets_expected    2022-12-09
 01:40:36.935558736 +0000
 07:43:54 +++
 /var/lib/jenkins/workspace/postgis/tmp/3_4_pg15w64/test_85_out
 2023-01-11 12:43:54.923125616 +0000
 07:43:54 @@ -324,10 +324,10 @@
 07:43:54  #4011|ST_MultiLineString|MULTILINESTRING EMPTY|t|t
 07:43:54  #4011|ST_GeometryCollection|MULTILINESTRING((0 0,0 0))|f|f
 07:43:54  #4025|
 07:43:54 -ERROR:  lwgeom_intersection_prec: GEOS Error: TopologyException:
 Input geom 0 is invalid: Self-intersection
 07:43:54 -ERROR:  lwgeom_difference_prec: GEOS Error: TopologyException:
 07:43:54 -ERROR:  lwgeom_symdifference_prec: GEOS Error:
 TopologyException: Input geom 0 is invalid: Self-intersection
 07:43:54 -ERROR:  lwgeom_union_prec: GEOS Error: TopologyException: Input
 07:43:54 +ERROR:  lwgeom_intersection_prec: GEOS Error: TopologyException:
 side location conflict at 5 5. This can occur if the input geometry is
 invalid.
 07:43:54 +ERROR:  lwgeom_difference_prec: GEOS Error: TopologyException:
 invalid.
 07:43:54 +ERROR:  lwgeom_symdifference_prec: GEOS Error:
 TopologyException: side location conflict at 5 5. This can occur if the
 input geometry is invalid.
 07:43:54 +ERROR:  lwgeom_union_prec: GEOS Error: TopologyException: side
 location conflict at 5 5. This can occur if the input geometry is invalid.
 07:43:54  #4055a|4326
 07:43:54  #4055b|4326
 07:43:54  #4089|LINESTRING Z (1 1 1,3 3 1)
 07:43:54
 Error is apparently with this query:
 select '#4025', ST_DistanceCPA (
         'LINESTRING M (
         3002640.82925984 5833770.09678249 1180471354.482,
         3003084.56741608 5833866.22147656 1180471411.791,
         3003325.8165722 5833942.66399188 1180471442.914,
         3003634.9521919 5834039.57644606 1180471482.436,
         3003701.57229565 5833872.50949516 1180471494.55)'::geometry,
         'LINESTRING M (
         2996311.19255982 5844593.73486637 1180471513.163,
         2996310.72190852 5844712.60937002 1180471523.37,
         2996311.81673704 5844916.90864168 1180471541.171)'::geometry
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5312>
