[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-550-g07d29463a
Thu Jan 12 12:37:42 PST 2023
the project "PostGIS".
       via  07d29463a26ecc47dc1fd43897d05493a3645700 (commit)
      from  bfe389e553de2f6b3c628fbb6b077dce430289a1 (commit)
revisions in full, below.
commit 07d29463a26ecc47dc1fd43897d05493a3645700
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Thu Jan 12 12:37:36 2023 -0800
    Make exception test a little less dependent on exception text
diff --git a/regress/core/tickets.sql b/regress/core/tickets.sql
index 17b861e63..7ce4de725 100644
--- a/regress/core/tickets.sql
+++ b/regress/core/tickets.sql
@@ -1088,10 +1088,24 @@ select '#4025', ST_DistanceCPA (
 -- a butterfly polygon in all cases
-SELECT '#4037.1', ST_AsText(ST_Intersection('POLYGON((0 0, 10 10, 0 10, 10 0, 0 0))', ST_MakeEnvelope(2,2,8,8)));
-SELECT '#4037.2', ST_AsText(ST_Difference('POLYGON((0 0, 10 10, 0 10, 10 0, 0 0))', ST_MakeEnvelope(2,2,8,8)));
-SELECT '#4037.3', ST_AsText(ST_SymDifference('POLYGON((0 0, 10 10, 0 10, 10 0, 0 0))', ST_MakeEnvelope(2,2,8,8)));
-SELECT '#4037.4', ST_AsText(ST_Union('POLYGON((0 0, 10 10, 0 10, 10 0, 0 0))', ST_MakeEnvelope(2,2,8,8)));
+CREATE FUNCTION catcherror(sql text)
+RETURNS text
+AS $$
+BEGIN
+  EXECUTE sql;
+  RETURN 'NO ERROR';
+EXCEPTION WHEN OTHERS THEN
+  RETURN SQLERRM;
+END;
+LANGUAGE 'plpgsql';
+SELECT '#4037.1', Left(catcherror('SELECT ST_Intersection(''POLYGON((0 0, 10 10, 0 10, 10 0, 0 0))'', ST_MakeEnvelope(2,2,8,8))'),55);
+SELECT '#4037.2', Left(catcherror('SELECT ST_Difference(''POLYGON((0 0, 10 10, 0 10, 10 0, 0 0))'', ST_MakeEnvelope(2,2,8,8))'),53);
+SELECT '#4037.3', Left(catcherror('SELECT ST_SymDifference(''POLYGON((0 0, 10 10, 0 10, 10 0, 0 0))'', ST_MakeEnvelope(2,2,8,8))'),56);
+SELECT '#4037.4', Left(catcherror('SELECT ST_Union(''POLYGON((0 0, 10 10, 0 10, 10 0, 0 0))'', ST_MakeEnvelope(2,2,8,8))'),48);
+DROP FUNCTION catcherror(text);
 -- #4055
 SELECT '#4055a', ST_SRID(unnest(ST_ClusterWithin(ARRAY['SRID=4326;POINT (3 7)'::geometry, 'SRID=4326;LINESTRING (3 0, 3 9)'], 0)));
diff --git a/regress/core/tickets_expected b/regress/core/tickets_expected
index cdb129edc..706ef3c5b 100644
--- a/regress/core/tickets_expected
+++ b/regress/core/tickets_expected
@@ -324,10 +324,10 @@ NOTICE:  Too few points in geometry component at or near point 0 0
 #4011|ST_MultiLineString|MULTILINESTRING EMPTY|t|t
 #4011|ST_GeometryCollection|MULTILINESTRING((0 0,0 0))|f|f
 #4025|
-ERROR:  lwgeom_intersection_prec: GEOS Error: TopologyException: Input geom 0 is invalid: Self-intersection
-ERROR:  lwgeom_difference_prec: GEOS Error: TopologyException: Input geom 0 is invalid: Self-intersection
-ERROR:  lwgeom_symdifference_prec: GEOS Error: TopologyException: Input geom 0 is invalid: Self-intersection
-ERROR:  lwgeom_union_prec: GEOS Error: TopologyException: Input geom 0 is invalid: Self-intersection
+#4037.1|lwgeom_intersection_prec: GEOS Error: TopologyException
+#4037.2|lwgeom_difference_prec: GEOS Error: TopologyException
+#4037.3|lwgeom_symdifference_prec: GEOS Error: TopologyException
+#4037.4|lwgeom_union_prec: GEOS Error: TopologyException
 #4055a|4326
 #4055b|4326
 #4089|LINESTRING Z (1 1 1,3 3 1)
Summary of changes:
 regress/core/tickets.sql      | 22 ++++++++++++++++++----
 regress/core/tickets_expected |  8 ++++----
 2 files changed, 22 insertions(+), 8 deletions(-)
hooks/post-receive
