[postgis-tickets] [PostGIS] #5313: ST_Collect + ST_InterpolateRaster = "Unknown geometry type"
PostGIS trac at osgeo.org
Fri Jan 13 00:27:20 PST 2023
 Reporter:  Player701  |      Owner:  pramsey
     Type:  defect     |     Status:  new
 Priority:  high       |  Milestone:  PostGIS 3.3.3
Component:  postgis    |    Version:  3.3.x
 Keywords:             |
 It seems that sometimes ST_InterpolateRaster does not like the geometry
 produced by ST_Collect. The geometries in question are all multipoints
 produced from 1 or more points. Re-creating them from ST_AsText output
 seems to clear the error, but is unoptimal.
 I don't know whether it is ST_Collect or ST_InterpolateRaster being at
 fault here, but I suspect the latter because all other operations I've
 tried on the output of ST_Collect (ST_XMin, ST_NumGeometries etc) do not
 throw any errors.
 Also, depending on the input values, ST_InterpolateRaster may instead
 complain that input geometry does not have Z-values even though it clearly
 does. Again, re-creating the geometry from ST_AsText output makes it work.
 I first thought I was doing something wrong when I saw the message about
 no Z-values, but after I got the "unknown geometry type" error I came to a
 conclusion that I indeed encountered a bug.
 Example query (NB: in the real life scenario points are selected from a
 table):
 {{{#!sql
 SELECT ST_InterpolateRaster(
   (SELECT ST_Collect(pt)
     FROM (
     SELECT 'POINT Z(3729230.119184725 5657111.610875956
 273.3486328125)'::geometry AS pt
     UNION SELECT 'POINT Z(3757059.9918830437 5657111.610875956
 273.0422668457031)'::geometry AS pt
     ) pts
   'invdist',
   ST_AddBand(ST_MakeEmptyRaster(1, 1, 0, 0, 1), '32BF')
 Produces the following error on my machine (Windows 10 x64 22H2):
 ERROR:  Unknown geometry type: 1699745866 - Invalid type
 SQL state: XX000
 But this works:
 {{{#!sql
   ST_AsText((SELECT ST_Collect(pt)
     FROM (
     ) pts
   ))::geometry,
   'invdist',
 Another example query:
 {{{#!sql
     FROM (
     SELECT 'POINT Z(1 2 3)'::geometry AS pt
     UNION SELECT 'POINT Z(3 4 5)'::geometry AS pt
     ) pts
   'invdist',
 Produces the following error:
 ERROR:  RASTER_InterpolateRaster: input geometry does not have Z values
 SQL state: XX000
 But this works:
 {{{#!sql
     FROM (
     ) pts
   ))::geometry,
   'invdist',
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5313>
