[postgis-tickets] [PostGIS] #5315: ST_Buffer causes segfault
PostGIS trac at osgeo.org
Fri Jan 20 09:41:05 PST 2023
  Reporter:  ewie     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 3.2.4
 Component:  postgis  |    Version:  3.2.x
Resolution:           |   Keywords:
Changes (by robe):
 * priority:  medium => blocker
 * milestone:   => PostGIS 3.2.4
Comment:
 Confirmed it crashes too
 POSTGIS="3.3.2 3.3.2" [EXTENSION] PGSQL="150" GEOS="3.11.1-CAPI-1.17.1"
 SFCGAL="SFCGAL 1.4.1, CGAL 5.3, BOOST 1.78.0" PROJ="7.2.1" GDAL="GDAL
 3.4.3, released 2022/04/22" LIBXML="2.9.9" LIBJSON="0.12"
 LIBPROTOBUF="1.2.1" WAGYU="0.5.0 (Internal)" TOPOLOGY RASTER    PostgreSQL
 15.1, compiled by Visual C++ build 1914, 64-bit
 SELECT
   ST_Buffer(
     ST_Transform(
       ST_SetSRID(
         ST_GeomFromText(
           'MULTIPOLYGON(((0 0, 1 0, 1 1, 0 1, 0 0)))',
           4326
         4647
       25832
     1
 But interestingly this doesn't crash:
 SELECT
     ST_Transform(
       ST_SetSRID(
         ST_GeomFromText(
           4326
         4647
       25832
 and gives a:
 MULTIPOLYGON(((Infinity Infinity,Infinity Infinity,Infinity
 Infinity,Infinity Infinity,Infinity Infinity)))
 It doesn't crash on my Linux Debian Arm server
 running:
 {{{POSTGIS="3.3.2 4975da8" [EXTENSION] PGSQL="150"
 GEOS="3.10.2-CAPI-1.16.0" SFCGAL="SFCGAL 1.4.1, CGAL 5.3.1, BOOST 1.74.0"
 PROJ="8.2.1" GDAL="GDAL 3.4.1, released 2021/12/27" LIBXML="2.9.13"
 LIBJSON="0.15" LIBPROTOBUF="1.3.3" WAGYU="0.5.0 (Internal)" (core procs
 from "3.3.0dev fef762990" need upgrade) TOPOLOGY (topology procs from
 "3.3.0dev fef762990" need upgrade) RASTER (raster procs from "3.3.0dev
 fef762990" need upgrade) (sfcgal procs from "3.3.0dev fef762990" need
 upgrade)    PostgreSQL 15.1 (Ubuntu 15.1-1.pgdg22.04+1) on aarch64
 -unknown-linux-gnu, compiled by gcc (Ubuntu 11.3.0-1ubuntu1~22.04) 11.3.0,
 64-bit}}}
 it gives error on both the ST_AsText and ST_Buffer
 ERROR:  transform: Point outside of projection domain (2050)
 So I guess the ultimate issue, is buffer can't buffer the infinity polygon
 which interestingly I can't cast back to a geometry. Gives invalid
 geometry if I try to do
 SELECT ST_Buffer('MULTIPOLYGON(((Infinity Infinity,Infinity
 Infinity,Infinity Infinity,Infinity Infinity,Infinity
 Infinity)))'::geometry)
 However on my Linux box
 SELECT
 ST_Buffer('0106000020E86400000100000001030000000100000005000000000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F'::geometry,
 10)
 Gives a ERROR: SSL SYSCALL error: EOF detected
 which is not quite a crash but should never happen.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5315#comment:3>
