[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-559-g6cc58c2a2
Mon Jan 23 11:04:22 PST 2023
the project "PostGIS".
       via  6cc58c2a2608001c395cc84f10a0e0923453d986 (commit)
       via  31bcb7d414c73df8dbc2975c6dd4a269b190c874 (commit)
       via  3b45fd06046659dab61e00780eb8f46a28b22d7e (commit)
      from  c5766f2f7069f94b9f4b32ab3243a928d583b21b (commit)
revisions in full, below.
commit 6cc58c2a2608001c395cc84f10a0e0923453d986
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Jan 23 20:02:35 2023 +0100
    Add updated comments for new join/restrict selectivity
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index d5f4bb68f..1ba84b72b 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -683,18 +683,24 @@ CREATE OR REPLACE FUNCTION geometry_within(geom1 geometry, geom2 geometry)
 	_COST_DEFAULT;
 -- Availability: 0.1.0
+-- Updated: 3.4.0 changed to use selectivity estimates
 CREATE OPERATOR @ (
 	LEFTARG = geometry, RIGHTARG = geometry, PROCEDURE = geometry_within,
 	COMMUTATOR = '~',
+	-- Updated: 3.4.0 to use selectivity estimator
 	RESTRICT = gserialized_gist_sel_2d,
+	-- Updated: 3.4.0 to use join selectivity estimator
 	JOIN = gserialized_gist_joinsel_2d
 CREATE OPERATOR ~ (
 	LEFTARG = geometry, RIGHTARG = geometry, PROCEDURE = geometry_contains,
 	COMMUTATOR = '@',
+	-- Updated: 3.4.0 to use specialized selectivity estimator
+	-- Updated: 3.4.0 to use join specialized selectivity estimator
commit 31bcb7d414c73df8dbc2975c6dd4a269b190c874
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue Dec 13 16:19:35 2022 -0800
    Add selectivity estimates to contains/within operators
index 089863493..d5f4bb68f 100644
@@ -686,14 +686,16 @@ CREATE OR REPLACE FUNCTION geometry_within(geom1 geometry, geom2 geometry)
 CREATE OPERATOR @ (
 	COMMUTATOR = '~',
-	RESTRICT = contsel, JOIN = contjoinsel
+	RESTRICT = gserialized_gist_sel_2d,
+	JOIN = gserialized_gist_joinsel_2d
 CREATE OPERATOR ~ (
 	COMMUTATOR = '@',
 -- Availability: 2.0.0
diff --git a/regress/core/regress_selectivity_expected b/regress/core/regress_selectivity_expected
index 266fa094b..6a0d37514 100644
--- a/regress/core/regress_selectivity_expected
+++ b/regress/core/regress_selectivity_expected
@@ -1,8 +1,8 @@
 restrict|geography && geography|gserialized_gist_sel_nd
 restrict|geometry && geometry|gserialized_gist_sel_2d
 restrict|geometry &&& geometry|gserialized_gist_sel_nd
-restrict|geometry @ geometry|contsel
-restrict|geometry ~ geometry|contsel
+restrict|geometry @ geometry|gserialized_gist_sel_2d
+restrict|geometry ~ geometry|gserialized_gist_sel_2d
 ERROR:  stats for "no_stats.g" do not exist
commit 3b45fd06046659dab61e00780eb8f46a28b22d7e
Date:   Mon Jan 23 20:01:41 2023 +0100
    Add support for Changed/Updated comment in operator attributes
diff --git a/utils/create_upgrade.pl b/utils/create_upgrade.pl
index f941146f9..5d5cc6e88 100755
--- a/utils/create_upgrade.pl
+++ b/utils/create_upgrade.pl
@@ -360,11 +360,30 @@ EOF
         my $opleft = 'unknown';
         my $opright = 'unknown';
         my $def = $_;
+        my $subcomment = '';
+        my @subobjects; # minversion, attribute, value
         while(<INPUT>)
+            if (/^\s*\-\-/)
+                $subcomment .= $_;
+                next;
             $def .= $_;
             $opleft = $1 if (/leftarg\s*=\s*(\w+)\s*,/i);
             $opright = $1 if (/rightarg\s*=\s*(\w+)\s*,/i);
+            # Support changing restrict selectivity at later versions
+            if (/\s+(RESTRICT|JOIN)\s*=\s*([^,\n]+)/)
+                my $last_updated = parse_last_updated($subcomment);
+                if ($last_updated)
+                    push @subobjects, [$last_updated, $1, $2];
             last if /\);/;
         my $opsig = $opleft . " " . $opname . " " . $opright;
@@ -379,8 +398,6 @@ EOF
 DO LANGUAGE 'plpgsql'
 \$postgis_proc_upgrade\$
 BEGIN
-  --IF $last_updated > version_from_num FROM _postgis_upgrade_info()
-    --We trust presence of operator rather than version info
     IF NOT EXISTS (
         SELECT o.oprname
         FROM
@@ -396,11 +413,31 @@ BEGIN
             tr.typname = '$opright'
     THEN
-    EXECUTE \$postgis_proc_upgrade_parsed_def\$ $def \$postgis_proc_upgrade_parsed_def\$;
-  END IF;
+$def
+EOF
+        my $ELSE="ELSE -- version_from >= $last_updated";
+        for my $subobj (@subobjects)
+            my $last_updated = @{$subobj}[0];
+            my $attr = @{$subobj}[1];
+            my $val = @{$subobj}[2];
+            print <<"EOF";
+    ${ELSE}
+    -- Last Updated: ${last_updated}
+    IF $last_updated > version_from_num FROM _postgis_upgrade_info() THEN
+        ALTER OPERATOR ${opname} ( $opleft, $opright ) SET ( ${attr} = ${val} );
+    END IF;
+EOF
+            $ELSE="";
+        print <<"EOF";
+  END IF; -- version_from >= $last_updated
 END
 \$postgis_proc_upgrade\$;
 EOF
     # Always output create ore replace view (see ticket #1097)
Summary of changes:
 postgis/postgis.sql.in                    | 12 +++++++--
 regress/core/regress_selectivity_expected |  4 +--
 utils/create_upgrade.pl                   | 45 ++++++++++++++++++++++++++++---
 3 files changed, 53 insertions(+), 8 deletions(-)
hooks/post-receive
