[postgis-tickets] [PostGIS] #5316: Regress failure with in-develop proj
PostGIS trac at osgeo.org
Mon Jan 23 13:18:48 PST 2023
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 3.4.0
 Component:  postgis  |    Version:  master
Resolution:           |   Keywords:
Comment (by ImreSamu):
 I have a similar problem with the https://github.com/postgis/docker-
 postgis project.
 and an extra line is solving the test.
 `projsync --system-directory --all`
 but then the `postgis/postgis:15-master` image size
 increasing from 555MB ----> ~ 1.28GB
 ( so I need a less space-consuming solution / workaround . )
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5316#comment:2>
