[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-570-g50bb5edd9
Thu Jan 26 11:48:05 PST 2023
the project "PostGIS".
       via  50bb5edd95ac430689597ed8b1a12efaa06526b6 (commit)
      from  f8a0f8132aa321e2a62aef83dea358424fe4401b (commit)
revisions in full, below.
commit 50bb5edd95ac430689597ed8b1a12efaa06526b6
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Thu Jan 26 11:47:48 2023 -0800
    Convert AsSVG to use stringbuffer_t
diff --git a/liblwgeom/lwout_svg.c b/liblwgeom/lwout_svg.c
index 2151ab2fa..5b2ecbde6 100644
--- a/liblwgeom/lwout_svg.c
+++ b/liblwgeom/lwout_svg.c
@@ -33,446 +33,243 @@
 #include "liblwgeom_internal.h"
+#include "stringbuffer.h"
-static lwvarlena_t *assvg_point(const LWPOINT *point, int relative, int precision);
-static lwvarlena_t *assvg_line(const LWLINE *line, int relative, int precision);
-static lwvarlena_t *assvg_polygon(const LWPOLY *poly, int relative, int precision);
-static lwvarlena_t *assvg_multipoint(const LWMPOINT *mpoint, int relative, int precision);
-static lwvarlena_t *assvg_multiline(const LWMLINE *mline, int relative, int precision);
-static lwvarlena_t *assvg_multipolygon(const LWMPOLY *mpoly, int relative, int precision);
-static lwvarlena_t *assvg_collection(const LWCOLLECTION *col, int relative, int precision);
-static size_t assvg_geom_size(const LWGEOM *geom, int relative, int precision);
-static size_t assvg_geom_buf(const LWGEOM *geom, char *output, int relative, int precision);
-static size_t pointArray_svg_size(POINTARRAY *pa, int precision);
-static size_t pointArray_svg_rel(POINTARRAY *pa, char * output, int close_ring, int precision);
-static size_t pointArray_svg_abs(POINTARRAY *pa, char * output, int close_ring, int precision);
+static void
+assvg_geom(stringbuffer_t* sb, const LWGEOM *geom, int relative, int precision);
- * Takes a GEOMETRY and returns a SVG representation
-lwvarlena_t *
-lwgeom_to_svg(const LWGEOM *geom, int precision, int relative)
+static void
+pointArray_svg_rel(stringbuffer_t* sb, const POINTARRAY *pa, int close_ring, int precision)
-	lwvarlena_t *ret = NULL;
-	int type = geom->type;
+	int i, end;
+	const POINT2D *pt;
-	/* Empty varlena for empties */
-	if( lwgeom_is_empty(geom) )
-		lwvarlena_t *v = lwalloc(LWVARHDRSZ);
-		LWSIZE_SET(v->size, LWVARHDRSZ);
-		return v;
+	double f = 1.0;
+	double dx, dy, x, y, accum_x, accum_y;
-	switch (type)
-	case POINTTYPE:
-		ret = assvg_point((LWPOINT*)geom, relative, precision);
-		break;
-	case LINETYPE:
-		ret = assvg_line((LWLINE*)geom, relative, precision);
-		break;
-	case POLYGONTYPE:
-		ret = assvg_polygon((LWPOLY*)geom, relative, precision);
-		break;
-	case MULTIPOINTTYPE:
-		ret = assvg_multipoint((LWMPOINT*)geom, relative, precision);
-		break;
-	case MULTILINETYPE:
-		ret = assvg_multiline((LWMLINE*)geom, relative, precision);
-		break;
-	case MULTIPOLYGONTYPE:
-		ret = assvg_multipolygon((LWMPOLY*)geom, relative, precision);
-		break;
-	case COLLECTIONTYPE:
-		ret = assvg_collection((LWCOLLECTION*)geom, relative, precision);
-		break;
+	char sx[OUT_DOUBLE_BUFFER_SIZE];
+	char sy[OUT_DOUBLE_BUFFER_SIZE];
-	default:
-		lwerror("lwgeom_to_svg: '%s' geometry type not supported",
-		        lwtype_name(type));
+	if (precision >= 0)
+		f = pow(10, precision);
-	return ret;
+	end = close_ring ? pa->npoints : pa->npoints - 1;
+	/* Starting point */
+	pt = getPoint2d_cp(pa, 0);
- * Point Geometry
+	x = round(pt->x*f)/f;
+	y = round(pt->y*f)/f;
-static size_t
-assvg_point_size(__attribute__((__unused__)) const LWPOINT *point, int circle, int precision)
-	size_t size;
+	lwprint_double(x, precision, sx);
+	lwprint_double(-y, precision, sy);
-	size = (OUT_MAX_BYTES_DOUBLE + precision) * 2;
-	if (circle) size += sizeof("cx='' cy=''");
-	else size += sizeof("x='' y=''");
+	stringbuffer_aprintf(sb, "%s %s l", sx, sy);
-	return size;
-static size_t
-assvg_point_buf(const LWPOINT *point, char * output, int circle, int precision)
-	char *ptr=output;
-	char x[OUT_DOUBLE_BUFFER_SIZE];
-	char y[OUT_DOUBLE_BUFFER_SIZE];
-	POINT2D pt;
+	/* accum */
+	accum_x = x;
+	accum_y = y;
-	getPoint2d_p(point->point, 0, &pt);
+	/* All the following ones */
+	for (i = 1; i < end; i++)
+		pt = getPoint2d_cp(pa, i);
-	lwprint_double(pt.x, precision, x);
-	lwprint_double(-pt.y, precision, y);
-	if (circle) ptr += sprintf(ptr, "x=\"%s\" y=\"%s\"", x, y);
-	else ptr += sprintf(ptr, "cx=\"%s\" cy=\"%s\"", x, y);
+		dx = x - accum_x;
+		dy = y - accum_y;
-	return (ptr-output);
+		accum_x += dx;
+		accum_y += dy;
-assvg_point(const LWPOINT *point, int circle, int precision)
-	size_t size = assvg_point_size(point, circle, precision);
-	lwvarlena_t *v = lwalloc(LWVARHDRSZ + size);
-	size = assvg_point_buf(point, v->data, circle, precision);
-	LWSIZE_SET(v->size, LWVARHDRSZ + size);
-	return v;
+		lwprint_double(dx, precision, sx);
+		lwprint_double(-dy, precision, sy);
+		stringbuffer_aprintf(sb, " %s %s", sx, sy);
- * Line Geometry
+ * Returns maximum size of rendered pointarray in bytes.
-static size_t
-assvg_line_size(const LWLINE *line, __attribute__((__unused__)) int relative, int precision)
+static void
+pointArray_svg_abs(stringbuffer_t* sb, const POINTARRAY *pa, int close_ring, int precision)
-	size_t size;
+	int i, end;
+	const POINT2D* pt;
-	size = sizeof("M ");
-	size += pointArray_svg_size(line->points, precision);
-	return size;
+	for (i = 0; i < end; i++)
-static size_t
-assvg_line_buf(const LWLINE *line, char * output, int relative, int precision)
-	char *ptr=output;
+		if (i == 1) stringbuffer_append(sb, " L ");
+		else if (i) stringbuffer_append(sb, " ");
-	/* Start path with SVG MoveTo */
-	ptr += sprintf(ptr, "M ");
-	if (relative)
-		ptr += pointArray_svg_rel(line->points, ptr, 1, precision);
-	else
-		ptr += pointArray_svg_abs(line->points, ptr, 1, precision);
+		lwprint_double(pt->x, precision, sx);
+		lwprint_double(-(pt->y), precision, sy);
+		stringbuffer_aprintf(sb, "%s %s", sx, sy);
-assvg_line(const LWLINE *line, int relative, int precision)
-	size_t size = assvg_line_size(line, relative, precision);
-	size = assvg_line_buf(line, v->data, relative, precision);
-	return v;
+static void
+assvg_point(stringbuffer_t* sb, const LWPOINT *point, int circle, int precision)
- * Polygon Geometry
+	const POINT2D* pt = getPoint2d_cp(point->point, 0);
-static size_t
-assvg_polygon_size(const LWPOLY *poly, __attribute__((__unused__)) int relative, int precision)
-	uint32_t i;
-	size_t size=0;
+		circle ? "x=\"%s\" y=\"%s\"" : "cx=\"%s\" cy=\"%s\"",
+		sx, sy);
-	for (i=0; i<poly->nrings; i++)
-		size += pointArray_svg_size(poly->rings[i], precision) + sizeof(" ");
-	size += sizeof("M  Z") * poly->nrings;
-	return size;
+static void
+assvg_line(stringbuffer_t* sb, const LWLINE *line, int relative, int precision)
+	/* Start path with SVG MoveTo */
+	stringbuffer_append(sb, "M ");
+	if (relative)
+		pointArray_svg_rel(sb, line->points, 1, precision);
+	else
+		pointArray_svg_abs(sb, line->points, 1, precision);
-static size_t
-assvg_polygon_buf(const LWPOLY *poly, char * output, int relative, int precision)
+static void
+assvg_polygon(stringbuffer_t* sb, const LWPOLY *poly, int relative, int precision)
 	uint32_t i;
-	char *ptr=output;
+	for (i = 0; i<poly->nrings; i++)
-		if (i) ptr += sprintf(ptr, " ");	/* Space beetween each ring */
-		ptr += sprintf(ptr, "M ");		/* Start path with SVG MoveTo */
+		if (i) stringbuffer_append(sb, " ");	/* Space beetween each ring */
+		stringbuffer_append(sb, "M ");		/* Start path with SVG MoveTo */
 		if (relative)
-			ptr += pointArray_svg_rel(poly->rings[i], ptr, 0, precision);
-			ptr += sprintf(ptr, " z");	/* SVG closepath */
+			pointArray_svg_rel(sb, poly->rings[i], 0, precision);
+			stringbuffer_append(sb, " z");	/* SVG closepath */
 		else
-			ptr += pointArray_svg_abs(poly->rings[i], ptr, 0, precision);
-			ptr += sprintf(ptr, " Z");	/* SVG closepath */
+			pointArray_svg_abs(sb, poly->rings[i], 0, precision);
+			stringbuffer_append(sb, " Z");	/* SVG closepath */
-assvg_polygon(const LWPOLY *poly, int relative, int precision)
-	size_t size = assvg_polygon_size(poly, relative, precision);
-	size = assvg_polygon_buf(poly, v->data, relative, precision);
-	return v;
- * Multipoint Geometry
-static size_t
-assvg_multipoint_size(const LWMPOINT *mpoint, int relative, int precision)
-	const LWPOINT *point;
-	size_t size=0;
-	uint32_t i;
-	for (i=0 ; i<mpoint->ngeoms ; i++)
-		point = mpoint->geoms[i];
-		size += assvg_point_size(point, relative, precision);
-	size += sizeof(",") * --i;  /* Arbitrary comma separator */
-	return size;
-static size_t
-assvg_multipoint_buf(const LWMPOINT *mpoint, char *output, int relative, int precision)
+static void
+assvg_multipoint(stringbuffer_t* sb, const LWMPOINT *mpoint, int relative, int precision)
 	uint32_t i;
-	char *ptr=output;
+	for (i = 0; i<mpoint->ngeoms; i++)
-		if (i) ptr += sprintf(ptr, ",");  /* Arbitrary comma separator */
+		if (i) stringbuffer_append(sb, ",");  /* Arbitrary comma separator */
-		ptr += assvg_point_buf(point, ptr, relative, precision);
+		assvg_point(sb, point, relative, precision);
-assvg_multipoint(const LWMPOINT *mpoint, int relative, int precision)
-	size_t size = assvg_multipoint_size(mpoint, relative, precision);
-	size = assvg_multipoint_buf(mpoint, v->data, relative, precision);
-	return v;
- * Multiline Geometry
-static size_t
-assvg_multiline_size(const LWMLINE *mline, int relative, int precision)
-	const LWLINE *line;
-	size_t size=0;
-	uint32_t i;
-	for (i=0 ; i<mline->ngeoms ; i++)
-		line = mline->geoms[i];
-		size += assvg_line_size(line, relative, precision);
-	size += sizeof(" ") * --i;   /* SVG whitespace Separator */
-	return size;
-static size_t
-assvg_multiline_buf(const LWMLINE *mline, char *output, int relative, int precision)
+static void
+assvg_multiline(stringbuffer_t* sb, const LWMLINE *mline, int relative, int precision)
 	const LWLINE *line;
 	uint32_t i;
-	char *ptr=output;
+	for (i = 0; i<mline->ngeoms; i++)
-		if (i) ptr += sprintf(ptr, " ");  /* SVG whitespace Separator */
+		if (i) stringbuffer_append(sb, " ");  /* SVG whitespace Separator */
-		ptr += assvg_line_buf(line, ptr, relative, precision);
+		assvg_line(sb, line, relative, precision);
-assvg_multiline(const LWMLINE *mline, int relative, int precision)
-	size_t size = assvg_multiline_size(mline, relative, precision);
-	size = assvg_multiline_buf(mline, v->data, relative, precision);
-	return v;
- * Multipolygon Geometry
-static size_t
-assvg_multipolygon_size(const LWMPOLY *mpoly, int relative, int precision)
+static void
+assvg_multipolygon(stringbuffer_t* sb, const LWMPOLY *mpoly, int relative, int precision)
 	const LWPOLY *poly;
-	size_t size=0;
 	uint32_t i;
-	for (i=0 ; i<mpoly->ngeoms ; i++)
+	for (i = 0; i<mpoly->ngeoms; i++)
 		poly = mpoly->geoms[i];
-		size += assvg_polygon_size(poly, relative, precision);
+		assvg_polygon(sb, poly, relative, precision);
-	return size;
-static size_t
-assvg_multipolygon_buf(const LWMPOLY *mpoly, char *output, int relative, int precision)
-	const LWPOLY *poly;
-	uint32_t i;
-	char *ptr=output;
-		poly = mpoly->geoms[i];
-		ptr += assvg_polygon_buf(poly, ptr, relative, precision);
-assvg_multipolygon(const LWMPOLY *mpoly, int relative, int precision)
-	size_t size = assvg_multipolygon_size(mpoly, relative, precision);
-	size = assvg_multipolygon_buf(mpoly, v->data, relative, precision);
-	return v;
-* Collection Geometry
-static size_t
-assvg_collection_size(const LWCOLLECTION *col, int relative, int precision)
-	uint32_t i = 0;
-	size_t size=0;
-	const LWGEOM *subgeom;
-	for (i=0; i<col->ngeoms; i++)
-		subgeom = col->geoms[i];
-		size += assvg_geom_size(subgeom, relative, precision);
-	if ( i ) /* We have some geometries, so add space for delimiters. */
-		size += sizeof(";") * --i;
-	if (size == 0) size++; /* GEOMETRYCOLLECTION EMPTY, space for null terminator */
-	return size;
-static size_t
-assvg_collection_buf(const LWCOLLECTION *col, char *output, int relative, int precision)
+static void
+assvg_collection(stringbuffer_t* sb, const LWCOLLECTION *col, int relative, int precision)
 	uint32_t i;
-	char *ptr=output;
 	/* EMPTY GEOMETRYCOLLECTION */
-	if (col->ngeoms == 0) *ptr = '\0';
+	if (col->ngeoms == 0) return;
+	for (i = 0; i<col->ngeoms; i++)
-		if (i) ptr += sprintf(ptr, ";");
+		if (i) stringbuffer_append(sb, ";");
-		ptr += assvg_geom_buf(subgeom, ptr, relative, precision);
+		assvg_geom(sb, subgeom, relative, precision);
-	return (ptr - output);
-assvg_collection(const LWCOLLECTION *col, int relative, int precision)
-	size_t size = assvg_collection_size(col, relative, precision);
-	size = assvg_collection_buf(col, v->data, relative, precision);
-	return v;
-static size_t
-assvg_geom_buf(const LWGEOM *geom, char *output, int relative, int precision)
+static void
-	char *ptr=output;
 	switch (type)
 	case POINTTYPE:
-		ptr += assvg_point_buf((LWPOINT*)geom, ptr, relative, precision);
+		assvg_point(sb, (LWPOINT*)geom, relative, precision);
 		break;
 	case LINETYPE:
-		ptr += assvg_line_buf((LWLINE*)geom, ptr, relative, precision);
+		assvg_line(sb, (LWLINE*)geom, relative, precision);
 		break;
 	case POLYGONTYPE:
-		ptr += assvg_polygon_buf((LWPOLY*)geom, ptr, relative, precision);
+		assvg_polygon(sb, (LWPOLY*)geom, relative, precision);
 		break;
-		ptr += assvg_multipoint_buf((LWMPOINT*)geom, ptr, relative, precision);
+		assvg_multipoint(sb, (LWMPOINT*)geom, relative, precision);
 		break;
 	case MULTILINETYPE:
-		ptr += assvg_multiline_buf((LWMLINE*)geom, ptr, relative, precision);
+		assvg_multiline(sb, (LWMLINE*)geom, relative, precision);
 		break;
-		ptr += assvg_multipolygon_buf((LWMPOLY*)geom, ptr, relative, precision);
+		assvg_multipolygon(sb, (LWMPOLY*)geom, relative, precision);
 		break;
 	default:
@@ -480,150 +277,58 @@ assvg_geom_buf(const LWGEOM *geom, char *output, int relative, int precision)
 		        lwtype_name(type));
-static size_t
-assvg_geom_size(const LWGEOM *geom, int relative, int precision)
+ * Takes a GEOMETRY and returns a SVG representation
+lwvarlena_t *
+lwgeom_to_svg(const LWGEOM *geom, int precision, int relative)
-	size_t size = 0;
+	stringbuffer_t sb;
+	int type = geom->type;
+	/* Empty varlena for empties */
+	if(lwgeom_is_empty(geom))
+		lwvarlena_t *v = lwalloc(LWVARHDRSZ);
+		LWSIZE_SET(v->size, LWVARHDRSZ);
+		return v;
+	stringbuffer_init_varlena(&sb);
 	switch (type)
 	case POINTTYPE:
-		size = assvg_point_size((LWPOINT*)geom, relative, precision);
+		assvg_point(&sb, (LWPOINT*)geom, relative, precision);
 		break;
 	case LINETYPE:
-		size = assvg_line_size((LWLINE*)geom, relative, precision);
+		assvg_line(&sb, (LWLINE*)geom, relative, precision);
 		break;
 	case POLYGONTYPE:
-		size = assvg_polygon_size((LWPOLY*)geom, relative, precision);
+		assvg_polygon(&sb, (LWPOLY*)geom, relative, precision);
 		break;
-		size = assvg_multipoint_size((LWMPOINT*)geom, relative, precision);
+		assvg_multipoint(&sb, (LWMPOINT*)geom, relative, precision);
 		break;
 	case MULTILINETYPE:
-		size = assvg_multiline_size((LWMLINE*)geom, relative, precision);
+		assvg_multiline(&sb, (LWMLINE*)geom, relative, precision);
 		break;
-		size = assvg_multipolygon_size((LWMPOLY*)geom, relative, precision);
+		assvg_multipolygon(&sb, (LWMPOLY*)geom, relative, precision);
+		break;
+	case COLLECTIONTYPE:
+		assvg_collection(&sb, (LWCOLLECTION*)geom, relative, precision);
 		break;
 	default:
-		lwerror("assvg_geom_size: '%s' geometry type not supported.",
+		lwerror("lwgeom_to_svg: '%s' geometry type not supported", lwtype_name(type));
-	return size;
+	return stringbuffer_getvarlena(&sb);
-static size_t
-pointArray_svg_rel(POINTARRAY *pa, char *output, int close_ring, int precision)
-	int i, end;
-	char *ptr;
-	char sx[OUT_DOUBLE_BUFFER_SIZE];
-	char sy[OUT_DOUBLE_BUFFER_SIZE];
-	const POINT2D *pt;
-	double f = 1.0;
-	double dx, dy, x, y, accum_x, accum_y;
-	ptr = output;
-	if (precision >= 0)
-		f = pow(10, precision);
-	if (close_ring) end = pa->npoints;
-	else end = pa->npoints - 1;
-	/* Starting point */
-	pt = getPoint2d_cp(pa, 0);
-	x = round(pt->x*f)/f;
-	y = round(pt->y*f)/f;
-	lwprint_double(x, precision, sx);
-	lwprint_double(-y, precision, sy);
-	ptr += sprintf(ptr,"%s %s l", sx, sy);
-	/* accum */
-	accum_x = x;
-	accum_y = y;
-	/* All the following ones */
-	for (i=1 ; i < end ; i++)
-		// lpt = pt;
-		pt = getPoint2d_cp(pa, i);
-		dx = x - accum_x;
-		dy = y - accum_y;
-		lwprint_double(dx, precision, sx);
-		lwprint_double(-dy, precision, sy);
-		accum_x += dx;
-		accum_y += dy;
-		ptr += sprintf(ptr," %s %s", sx, sy);
- * Returns maximum size of rendered pointarray in bytes.
-static size_t
-pointArray_svg_abs(POINTARRAY *pa, char *output, int close_ring, int precision)
-	int i, end;
-	char *ptr;
-	POINT2D pt;
-	ptr = output;
-	for (i=0 ; i < end ; i++)
-		getPoint2d_p(pa, i, &pt);
-		if (i == 1) ptr += sprintf(ptr, " L ");
-		else if (i) ptr += sprintf(ptr, " ");
-		ptr += sprintf(ptr,"%s %s", x, y);
-static size_t
-pointArray_svg_size(POINTARRAY *pa, int precision)
-	return (OUT_MAX_BYTES_DOUBLE + precision + sizeof(" ")) * 2 * pa->npoints + sizeof(" L ");
Summary of changes:
 liblwgeom/lwout_svg.c | 587 +++++++++++++-------------------------------------
 1 file changed, 146 insertions(+), 441 deletions(-)
hooks/post-receive
