[postgis-tickets] [PostGIS] #5321: postgis commandline tool has a .exe extension under windows, it should be .pl
PostGIS trac at osgeo.org
Fri Jan 27 08:28:00 PST 2023
.pl
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  blocker                |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:  fixed                  |   Keywords:
Changes (by Sandro Santilli <strk@…>):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"1f14839d6f6be7809a186a586ed4c2ccde5525e1/git" 1f14839/git]:
 {{{#!CommitTicketReference repository="git"
 revision="1f14839d6f6be7809a186a586ed4c2ccde5525e1"
 Do not add the .exe suffix on postgis script, for windows
 Closes #5321
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5321#comment:1>
