[postgis-tickets] [PostGIS] #5331: reverse geocoder sometimes doesn't return a street and address when it should
PostGIS trac at osgeo.org
Fri Jan 27 15:59:49 PST 2023
should
 Reporter:  robe            |      Owner:  robe
     Type:  defect          |     Status:  new
 Priority:  medium          |  Milestone:  PostGIS 3.1.9
Component:  tiger geocoder  |    Version:  3.3.x
 Keywords:                  |
 There are a lot cases where reverse geocoder does not return an address,
 because tiger seems to have quite a few unnamed streets and many with no
 ranges, such as highways.
 Planned fix is to prefer addressable ranges even if it isn't the closest
 as long as it's within 70 meters.
 In my testing the new approach
 for this query:
 SELECT pprint_addy(addy[1]), ST_ASText(intpt[1]) , (intpt[1]::geography
 <-> ST_SetSRID(var_pt,4269))::numeric(10,2) AS dist_m
 FROM ST_Point( -122.077435,37.414167) AS var_pt,
 tiger.reverse_geocode_testing( var_pt );
 Will give
                 pprint_addy                 |                  st_astext
 | dist_m
  1382 la Avenida St, Mountain View, CA 94043 | POINT(-122.0775952717109
 37.41362206134327) |  62.23
 (1 row)
 vs. the old apprach
 | dist_m
  N Shoreline Blvd, Mountain View, CA 94043 | POINT(-122.07799538107314
 37.41415350501974) |  49.51
 (1 row)
 I'm going to test with several more.  I had already deleted some unnamed
 streets from my set to avoid blank addresses being returned, so in many
 cases the situation is worse than this.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5331>
