[postgis-tickets] [PostGIS] #5106: ST_RemEdgeNewFace causes postgre to core dump, but not ST_RemEdgeModFace
PostGIS trac at osgeo.org
Mon Jan 30 06:39:41 PST 2023
  Reporter:  laopsahl  |      Owner:  strk
      Type:  defect    |     Status:  new
  Priority:  medium    |  Milestone:  PostGIS 3.4.0
 Component:  topology  |    Version:  3.2.x
Resolution:            |   Keywords:
Comment (by strk):
 So, specially built PostgreSQL version isn't needed because we're passing
 0x0 pointer to pfree and that should ALWAYS segfault. But what I don't
 understand is how it is possible for ST_RemEdgeNewFace to NOT find any of
 the faces found in an edge's left_face and right_face columns, as those
 values *should* theoretically always be checked by foreign key constraints
 to match existing records in the face table.
 I suspect this has to do with the way we use the "read_only" parameter to
 SPI_execute, that is, has to do with visibility of data changes.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5106#comment:5>
