[postgis-tickets] [SCM] PostGIS branch stable-3.3 updated. 3.3.2-11-g69900affe
Mon Jan 30 08:25:22 PST 2023
the project "PostGIS".
The branch, stable-3.3 has been updated
       via  69900affe41cb654941e58300829efe352e9a3e1 (commit)
      from  12df1cfd409d85d5a42dcd4c0e17f9603a6d5bb5 (commit)
revisions in full, below.
commit 69900affe41cb654941e58300829efe352e9a3e1
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Jan 30 14:41:02 2023 +0100
    Fix segfault in _lwt_RemEdge when no edge side-faces are found
    References #5106 in 3.3 branch (3.3.3dev)
    Includes regress tests
diff --git a/NEWS b/NEWS
index ee0b1b2e2..9b1deb9fd 100644
--- a/NEWS
+++ b/NEWS
@@ -8,6 +8,8 @@ YYYY/MM/DD
            doubly connected edges healing (Sandro Santilli)
   - #5298, Fix CopyTopology exception with hierarchical layers (Sandro Santilli)
   - #5299, Corrections to address_standardizer_data_us lex (Regina Obe)
+  - #5106, Fix segfault in ST_RemEdgeNewFace/ST_RemEdgeModFace
+           when no edge side-faces are found (Sandro Santilli)
 PostGIS 3.3.2
 2022/11/12
diff --git a/liblwgeom/lwgeom_topo.c b/liblwgeom/lwgeom_topo.c
index 5988e5a67..7ecc5e430 100644
--- a/liblwgeom/lwgeom_topo.c
+++ b/liblwgeom/lwgeom_topo.c
@@ -4049,7 +4049,7 @@ _lwt_RemEdge( LWT_TOPOLOGY* topo, LWT_ELEMID edge_id, int modFace )
       if ( ! box1 ) {
         i = edge->face_left;
         _lwt_release_edges(edge, 1);
-        _lwt_release_faces(faces, nfaces);
+        if ( nfaces ) _lwt_release_faces(faces, nfaces);
         lwerror("corrupted topology: no face have face_id=%"
                 LWTFMT_ELEMID " (left face for edge %"
                 LWTFMT_ELEMID ")", i, edge_id);
@@ -4058,7 +4058,7 @@ _lwt_RemEdge( LWT_TOPOLOGY* topo, LWT_ELEMID edge_id, int modFace )
       if ( ! box2 ) {
         i = edge->face_right;
                 LWTFMT_ELEMID " (right face for edge %"
diff --git a/topology/test/regress/st_remedgemodface.sql b/topology/test/regress/st_remedgemodface.sql
index 320571da2..1686f1d3f 100644
--- a/topology/test/regress/st_remedgemodface.sql
+++ b/topology/test/regress/st_remedgemodface.sql
@@ -414,7 +414,40 @@ DROP SCHEMA features CASCADE;
--- clean up
+-- Test for https://trac.osgeo.org/postgis/ticket/5106
+BEGIN;
+SELECT NULL FROM topology.CreateTopology('t5106');
+INSERT INTO t5106.node VALUES ( 1, NULL, 'POINT(0 0)' );
+-- Cannot reference non-existing faces w/out dropping
+-- these constraints
+ALTER TABLE t5106.edge_data DROP constraint left_face_exists;
+ALTER TABLE t5106.edge_data DROP constraint right_face_exists;
+INSERT INTO t5106.edge VALUES
+	1, -- edge_id
+	1, 1, -- start/end node
+	1, -1, -- next left/right edge
+	1, 2, -- left/right faces (different, both non-0 and non existent)
+  'LINESTRING(0 0,10 0,10 10,0 0)'
+DO $BODY$
+BEGIN
+	PERFORM ST_RemEdgeModFace('t5106', 1);
+	RAISE EXCEPTION '#5106 failed throwing an exception';
+EXCEPTION WHEN OTHERS THEN
+	RAISE EXCEPTION '#5106 threw: %', SQLERRM;
+END;
+$BODY$ LANGUAGE 'plpgsql';
+ROLLBACK;
+-- Clean up
 DROP FUNCTION save_edges();
 DROP FUNCTION check_edges(text);
 DROP FUNCTION save_faces();
diff --git a/topology/test/regress/st_remedgemodface_expected b/topology/test/regress/st_remedgemodface_expected
index 3ae4345d8..dc76f3452 100644
--- a/topology/test/regress/st_remedgemodface_expected
+++ b/topology/test/regress/st_remedgemodface_expected
@@ -194,3 +194,4 @@ RM(11)|P3|t
 RM(11)|P4|t
 RM(11)|P5|t
 Topology 'city_data' dropped
+ERROR:  #5106 threw: corrupted topology: no face have face_id=1 (left face for edge 1)
diff --git a/topology/test/regress/st_remedgenewface.sql b/topology/test/regress/st_remedgenewface.sql
index ebaa42207..1f1bfd6cb 100644
--- a/topology/test/regress/st_remedgenewface.sql
+++ b/topology/test/regress/st_remedgenewface.sql
@@ -414,7 +414,39 @@ DROP SCHEMA features CASCADE;
--- clean up
+BEGIN;
+	1, -- edge_id
+DO $BODY$
+BEGIN
+	PERFORM topology.ST_RemEdgeNewFace('t5106', 1);
+END;
+ROLLBACK;
+-- Clean up
diff --git a/topology/test/regress/st_remedgenewface_expected b/topology/test/regress/st_remedgenewface_expected
index 96eb15131..279e74c78 100644
--- a/topology/test/regress/st_remedgenewface_expected
+++ b/topology/test/regress/st_remedgenewface_expected
@@ -224,3 +224,4 @@ RN(11)|P3|t
 RN(11)|P4|t
 RN(11)|P5|t
Summary of changes:
 NEWS                                             |  2 ++
 liblwgeom/lwgeom_topo.c                          |  4 +--
 topology/test/regress/st_remedgemodface.sql      | 35 +++++++++++++++++++++++-
 topology/test/regress/st_remedgemodface_expected |  1 +
 topology/test/regress/st_remedgenewface.sql      | 34 ++++++++++++++++++++++-
 topology/test/regress/st_remedgenewface_expected |  1 +
 6 files changed, 73 insertions(+), 4 deletions(-)
hooks/post-receive
