[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-575-g7dc3d5e7a
Mon Jan 30 08:57:42 PST 2023
the project "PostGIS".
       via  7dc3d5e7ac146f39ff79a0bad44cb51d8983c2a4 (commit)
      from  33e4ee1e92d9b48e169a53d2da34a851117e0363 (commit)
revisions in full, below.
commit 7dc3d5e7ac146f39ff79a0bad44cb51d8983c2a4
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Jan 30 17:57:07 2023 +0100
    Use scripts_installed for downgrade protection
    References #5329 in master branch (3.4.0dev)
diff --git a/utils/create_upgrade.pl b/utils/create_upgrade.pl
index 5d5cc6e88..d6c5225d0 100755
--- a/utils/create_upgrade.pl
+++ b/utils/create_upgrade.pl
@@ -791,25 +791,9 @@ DECLARE
     postgis_upgrade_info RECORD;
     postgis_upgrade_info_func_code TEXT;
 BEGIN
-    -- This uses postgis_lib_version() rather then
-    -- MODULE_scripts_installed() as in 1.0 because
-    -- in the 1.0 => 1.1 transition that would result
-    -- in an impossible upgrade:
-    --   from 0.3.0 to 1.1.0
-    -- Next releases will still be ok as
-    -- postgis_lib_version() and MODULE_scripts_installed()
-    -- would both return actual PostGIS release number.
-    BEGIN
-        SELECT into old_scripts MODULE_lib_version();
-    EXCEPTION WHEN OTHERS THEN
-        RAISE DEBUG 'Got %', SQLERRM;
-        SELECT into old_scripts MODULE_scripts_installed();
-    END;
-    SELECT into new_scripts 'NEWVERSION';
+    old_scripts := MODULE_scripts_installed();
+    new_scripts := 'NEWVERSION';
     BEGIN
         new_ver_int := pg_catalog.string_to_array(
Summary of changes:
 utils/create_upgrade.pl | 22 +++-------------------
 1 file changed, 3 insertions(+), 19 deletions(-)
hooks/post-receive
