[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-580-gdfb471df8
Tue Jan 31 10:38:55 PST 2023
the project "PostGIS".
       via  dfb471df8db21fd115a38bedabd2911f4dc4e324 (commit)
      from  d59cb808db2f27f29c14f0cb458195dce445e9d5 (commit)
revisions in full, below.
commit dfb471df8db21fd115a38bedabd2911f4dc4e324
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue Jan 31 19:37:58 2023 +0100
    Add --disable-extension-upgrades-install configure switch
    The switch disables automatic install of extension upgrade
    scripts, giving a message at the end of `make install` as to
    how to manually deal with those.
    References #5092
diff --git a/.gitignore b/.gitignore
index 8485dcc10..2a8570a43 100644
--- a/.gitignore
+++ b/.gitignore
@@ -44,6 +44,7 @@ doc/raster_gardentest_*.sql
 doc/tiger_geocoder_comments.sql
 doc/topology_comments.sql
 extensions/Makefile
+extensions/upgrade-paths-rules.mk
 extensions/address_standardizer/Makefile
 extensions/address_standardizer/mk-st-regexp
 extensions/address_standardizer/address_standardizer--*.sql
diff --git a/GNUmakefile.in b/GNUmakefile.in
index a6bb9a269..8c265bc4f 100644
--- a/GNUmakefile.in
+++ b/GNUmakefile.in
@@ -29,6 +29,20 @@ all install uninstall noop clean distclean check-unit:
 	@if test x"$@" = xall; then \
 		echo "PostGIS was built successfully. Ready to install."; \
 	fi
+ifneq (@INSTALL_EXTENSION_UPGRADES@,yes)
+ifneq (@EXTENSIONS@,)
+	@if test x"$@" = xinstall; then \
+		echo; \
+		echo "PostGIS extensions installed, upgrade scripts retained."; \
+		echo; \
+		echo "You may use the "postgis" script to only install the ones you need, or";\
+		echo "you can install the ones required to upgrade from currently known versions with:"; \
+		echo; \
+		echo "  make install-extension-upgrades-from-known-versions"; \
+		echo; \
+	fi
+endif
+endif
 install-extension-upgrades-from-known-versions:
diff --git a/configure.ac b/configure.ac
index 634628f0d..80cd6c8dc 100644
--- a/configure.ac
+++ b/configure.ac
@@ -1718,6 +1718,10 @@ then
     AC_SUBST([EXTENSIONS])
 fi
+INSTALL_EXTENSION_UPGRADES=yes
+AC_ARG_ENABLE([extension-upgrades-install], AS_HELP_STRING([--disable-extension-upgrades-install], [Disable automatic install of extension upgrade scripts]),
+	[INSTALL_EXTENSION_UPGRADES=$enableval])
+AC_SUBST([INSTALL_EXTENSION_UPGRADES])
 dnl ===========================================================================
 dnl Output the relevant files
@@ -1734,6 +1738,7 @@ dnl echo "TRANSLATIONS_MAKEFILE_LIST: ${TRANSLATIONS_MAKEFILE_LIST}"
 AC_CONFIG_FILES([GNUmakefile
    extensions/Makefile
+   extensions/upgrade-paths-rules.mk
    extensions/postgis/Makefile
    extensions/postgis_topology/Makefile
    extensions/postgis_tiger_geocoder/Makefile
@@ -1789,7 +1794,6 @@ AC_MSG_RESULT([ -------------- Additional Info ------------- ])
 if test "x$LIBINCLUDEMINORVERSION" = "xyes"; then
   AC_MSG_RESULT([  POSTGIS lib file includes minor:   ENABLED])
 fi
 if test "x$INTERRUPTTESTS" = "xyes"; then
   AC_MSG_RESULT([  Interrupt Tests:   ENABLED])
 else
@@ -1829,6 +1833,15 @@ AC_MSG_RESULT([  Perl:                 ${PERL}])
 AC_MSG_RESULT()
 AC_MSG_RESULT([ --------------- Extensions --------------- ])
+if test "x$EXTENSIONS" = "xextensions"; then
+    if test "x$INSTALL_EXTENSION_UPGRADES" = "xyes"; then
+        AC_MSG_RESULT([  PostgreSQL EXTENSION support:       enabled])
+    else
+        AC_MSG_RESULT([  PostgreSQL EXTENSION support:       enabled (manual install of upgrade paths)])
+    fi
+else
+    AC_MSG_RESULT([  PostgreSQL EXTENSION support:       disabled])
+fi
 if test "x$RASTER" = "xraster"; then
     AC_MSG_RESULT([  PostGIS Raster:                     enabled])
 else
diff --git a/extensions/address_standardizer/Makefile.in b/extensions/address_standardizer/Makefile.in
index cbf35ae28..5fac487c5 100644
--- a/extensions/address_standardizer/Makefile.in
+++ b/extensions/address_standardizer/Makefile.in
@@ -119,7 +119,7 @@ sql/$(EXTENSION)--ANY--$(EXTVERSION).sql: $(EXTENSION_UPGRADE_SCRIPTS)
 sql/$(EXTENSION)_data_us--ANY--$(EXTVERSION).sql: sql/$(EXTENSION)_data_us--$(EXTVERSION).sql | sql
 	cat $^ > $@
-include @srcdir@/../upgrade-paths-rules.mk
+include ../upgrade-paths-rules.mk
 # TODO: fix this by moving data in their own directories
 ifeq ($(EXTENSION_DATA_INSTALL),)
diff --git a/extensions/postgis/Makefile.in b/extensions/postgis/Makefile.in
index 1d5619bc4..4cd1bdcb2 100644
--- a/extensions/postgis/Makefile.in
+++ b/extensions/postgis/Makefile.in
@@ -140,7 +140,7 @@ sql/$(EXTENSION)--ANY--$(EXTVERSION).sql: $(EXTENSION_UPGRADE_SCRIPTS) | sql
 	printf '\\echo Use "CREATE EXTENSION $(EXTENSION)" to load this file. \\quit\n' > $@
 	cat $^ >> $@
 distclean: clean
 	rm -f Makefile
diff --git a/extensions/postgis_raster/Makefile.in b/extensions/postgis_raster/Makefile.in
index 1d061f114..bb78d7a23 100644
--- a/extensions/postgis_raster/Makefile.in
+++ b/extensions/postgis_raster/Makefile.in
@@ -122,7 +122,7 @@ sql/$(EXTENSION)--ANY--$(EXTVERSION).sql: $(EXTENSION_UPGRADE_SCRIPTS) | sql
 	cat $^ >> $@
 distclean: clean
 	rm -f Makefile
diff --git a/extensions/postgis_sfcgal/Makefile.in b/extensions/postgis_sfcgal/Makefile.in
index 6acb88a6b..73f828b5b 100644
--- a/extensions/postgis_sfcgal/Makefile.in
+++ b/extensions/postgis_sfcgal/Makefile.in
@@ -94,7 +94,7 @@ sql/sfcgal_upgrade_minor.sql: ../postgis_extension_helper.sql sql/sfcgal_upgrade
 	cat $(EXTENSION_UPGRADE_SCRIPTS) > $@
 distclean: clean
 	rm Makefile
diff --git a/extensions/postgis_tiger_geocoder/Makefile.in b/extensions/postgis_tiger_geocoder/Makefile.in
index 8c7df1532..de3d37f57 100644
--- a/extensions/postgis_tiger_geocoder/Makefile.in
+++ b/extensions/postgis_tiger_geocoder/Makefile.in
@@ -205,7 +205,7 @@ sql/tiger_geocoder_upgrade_minor.sql:  sql/tiger_geocoder_minor.sql.in | sql
 #only extension files
 EXTRA_CLEAN += $(wildcard expected/*--*.out)
 distclean: clean
 	rm Makefile
diff --git a/extensions/postgis_topology/Makefile.in b/extensions/postgis_topology/Makefile.in
index e63f8f3d1..763fdb5ac 100644
--- a/extensions/postgis_topology/Makefile.in
+++ b/extensions/postgis_topology/Makefile.in
@@ -99,7 +99,7 @@ sql/topology_upgrade.sql:  ../../topology/topology_upgrade.sql | sql
 	cat $^ > $@
 distclean: clean
 	rm Makefile
diff --git a/extensions/upgrade-paths-rules.mk b/extensions/upgrade-paths-rules.mk.in
similarity index 92%
rename from extensions/upgrade-paths-rules.mk
rename to extensions/upgrade-paths-rules.mk.in
index 2f6611201..6759dd32a 100644
--- a/extensions/upgrade-paths-rules.mk
+++ b/extensions/upgrade-paths-rules.mk.in
@@ -22,8 +22,10 @@ install-upgrade-paths: tag-as-any
 	tpl='$(EXTENSION)--ANY--$(EXTVERSION).sql'; \
 	$(INSTALL_DATA) sql/$${tpl} "$(EXTDIR)/$${tpl}"; \
 	$(INSTALL_DATA) "sql/$(TAG_UPGRADE)" "$(EXTDIR)/$(TAG_UPGRADE)"; \
-	ln -fs "$(TAG_UPGRADE)" $(EXTDIR)/$(EXTENSION)--$(EXTVERSION)--ANY.sql; \
-	$(MAKE) install-extension-upgrades-from-known-versions # make this conditional !
+	ln -fs "$(TAG_UPGRADE)" $(EXTDIR)/$(EXTENSION)--$(EXTVERSION)--ANY.sql;
+ifeq (@INSTALL_EXTENSION_UPGRADES@,yes)
+	$(MAKE) install-extension-upgrades-from-known-versions
+endif
 	$(PERL) $(top_srcdir)/loader/postgis.pl \
Summary of changes:
 .gitignore                                                |  1 +
 GNUmakefile.in                                            | 14 ++++++++++++++
 configure.ac                                              | 15 ++++++++++++++-
 extensions/address_standardizer/Makefile.in               |  2 +-
 extensions/postgis/Makefile.in                            |  2 +-
 extensions/postgis_raster/Makefile.in                     |  2 +-
 extensions/postgis_sfcgal/Makefile.in                     |  2 +-
 extensions/postgis_tiger_geocoder/Makefile.in             |  2 +-
 extensions/postgis_topology/Makefile.in                   |  2 +-
 .../{upgrade-paths-rules.mk => upgrade-paths-rules.mk.in} |  6 ++++--
 10 files changed, 39 insertions(+), 9 deletions(-)
 rename extensions/{upgrade-paths-rules.mk => upgrade-paths-rules.mk.in} (92%)
hooks/post-receive
