[postgis-tickets] [PostGIS] #5424: Use of remark tag preventing Z, M, curved support, SQL-MM attributes from showing in PDF
PostGIS trac at osgeo.org
Sat Jul 1 10:23:37 PDT 2023
#5424: Use of remark tag preventing Z,M, curved support, SQL-MM attributes from
showing in PDF
 Reporter:  robe           |      Owner:  robe
     Type:  defect         |     Status:  new
 Priority:  medium         |  Milestone:  PostGIS 3.4.0
Component:  documentation  |    Version:  master
 Keywords:                 |
 As a result of our new use of <remark> tag in docbook.  Two changes have
 happened
 1. These text elements are now showing as yellow-marker highlights in the
 html docs
 2. These are completely left out in the PDF
 I suspect because remark is intended to be used as perhaps notes to
 authors and corrections etc.
 The other place it showed was index-aware tag.  Since we don't use index
 aware tag for any xsl filtering, I took out the remark on that.  That tags
 appears in some places in the docs, but usually within note tags, so
 looked extra funny with the double-yellow.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5424>
