[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1111-g008e1c6c0
Mon Jul 3 19:23:11 PDT 2023
the project "PostGIS".
       via  008e1c6c02e8b19d76890063381b2f9e13507a99 (commit)
      from  8d1ba14324505966696b356e66d38366855051a9 (commit)
revisions in full, below.
commit 008e1c6c02e8b19d76890063381b2f9e13507a99
Author: Regina Obe <lr at pcorp.us>
Date:   Mon Jul 3 22:21:27 2023 -0400
    DOC CHANGES
     - Loosen filter on table matrix
       Was filtering out input / output functions among others.
     - Also filter out version section which has no specific geome/geog type
    functions
diff --git a/doc/xsl/table_body_function_support_matrix.xml.xsl b/doc/xsl/table_body_function_support_matrix.xml.xsl
index 33915da88..f272d8304 100644
--- a/doc/xsl/table_body_function_support_matrix.xml.xsl
+++ b/doc/xsl/table_body_function_support_matrix.xml.xsl
@@ -58,7 +58,7 @@
 						<tbody>
 						<!-- Exclude PostGIS types, management functions, long transaction support, or exceptional functions from consideration  -->
 						<!-- leaving out operators in an effor to try to fit on one page -->
-						<xsl:for-each select="sect1[not(@id='PostGIS_Types' or @id='Management_Functions' or @id='Long_Transactions_Support' or @id='Exceptional_Functions')]/refentry">
+						<xsl:for-each select="descendant::node()[not(@id='PostGIS_Types' or @id='Management_Functions' or @id='Long_Transactions_Support' or @id='Exceptional_Functions' or @id='Version_Functions')]/refentry">
 							<xsl:sort select="@id"/>
 							<xsl:variable name='comment'>
 								<xsl:value-of select="normalize-space(translate(translate(refnamediv/refpurpose,'&#x0d;&#x0a;', ' '), '	', ' '))"/>
@@ -92,7 +92,7 @@
 										</entry>
 									</xsl:when>
 									<!-- support via autocast -->
-									<xsl:when test="contains(refsynopsisdiv/funcsynopsis,'box') or contains(refsynopsisdiv/funcsynopsis/funcprototype/funcdef,'box')">
+									<xsl:when test="contains(refsynopsisdiv/funcsynopsis,'box') or contains(refsynopsisdiv/funcsynopsis/funcprototype/funcdef,'box') or contains(refsynopsisdiv/funcsynopsis, 'geom_name')">
 										<entry><xsl:value-of select="$matrix_autocast" disable-output-escaping="yes"/></entry>
 									</xsl:when>
 									<!-- no support -->
Summary of changes:
 doc/xsl/table_body_function_support_matrix.xml.xsl | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
hooks/post-receive
