[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1114-g92a3500f6
Tue Jul 4 07:11:26 PDT 2023
the project "PostGIS".
       via  92a3500f67498ce328d73c0a8456928257d63859 (commit)
      from  9b9a99dd0302f3a4e0b8a1c628fd00ba6f0e348d (commit)
revisions in full, below.
commit 92a3500f67498ce328d73c0a8456928257d63859
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Tue Jul 4 07:11:24 2023 -0700
    Improve doc ST_CoverageSimplify example
diff --git a/doc/reference_coverage.xml b/doc/reference_coverage.xml
index 086d58bff..8da79c8c9 100644
--- a/doc/reference_coverage.xml
+++ b/doc/reference_coverage.xml
@@ -176,16 +176,12 @@ SELECT true = ALL (
       </tgroup>
     </informaltable>
-      <programlisting>CREATE TABLE coverage (id integer, geom geometry);
-INSERT INTO coverage VALUES
-  (1, '(POLYGON ((160 150, 110 130, 90 100, 90 70, 60 60, 50 10, 30 30, 40 50, 25 40, 10 60, 30 100, 30 120, 20 170, 60 180, 90 190, 130 180, 130 160, 160 150),
-  (40 160, 50 140, 66 125, 60 100, 80 140, 90 170, 60 160, 40 160))'),
-  (2, 'POLYGON ((40 160, 60 160, 90 170, 80 140, 60 100, 66 125, 50 140, 40 160))'),
-  (3, 'POLYGON ((110 130, 160 50, 140 50, 120 33, 90 30, 50 10, 60 60, 90 70, 90 100, 110 130))'
-  (4, 'POLYGON ((160 150, 150 120, 160 90, 160 50, 110 130, 160 150))'
+      <programlisting>WITH coverage(id, geom) AS (VALUES
+  (1, 'POLYGON ((160 150, 110 130, 90 100, 90 70, 60 60, 50 10, 30 30, 40 50, 25 40, 10 60, 30 100, 30 120, 20 170, 60 180, 90 190, 130 180, 130 160, 160 150), (40 160, 50 140, 66 125, 60 100, 80 140, 90 170, 60 160, 40 160))'::geometry),
+  (2, 'POLYGON ((40 160, 60 160, 90 170, 80 140, 60 100, 66 125, 50 140, 40 160))'::geometry),
+  (3, 'POLYGON ((110 130, 160 50, 140 50, 120 33, 90 30, 50 10, 60 60, 90 70, 90 100, 110 130))'::geometry),
+  (4, 'POLYGON ((160 150, 150 120, 160 90, 160 50, 110 130, 160 150))'::geometry)
 SELECT id, ST_AsText(ST_CoverageSimplify(geom, 30) OVER ())
   FROM coverage;
Summary of changes:
 doc/reference_coverage.xml | 16 ++++++----------
 1 file changed, 6 insertions(+), 10 deletions(-)
hooks/post-receive
