[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1117-ge0e27f295
Tue Jul 4 13:27:29 PDT 2023
the project "PostGIS".
       via  e0e27f29599b382759859552e08bebdae95f4756 (commit)
      from  9f102e75070a764f0e245b3b508e5869a1a9e286 (commit)
revisions in full, below.
commit e0e27f29599b382759859552e08bebdae95f4756
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue Jul 4 22:26:32 2023 +0200
    Loosen conformance filter so it doesn't depend on <remark> tag
diff --git a/doc/xsl/list_3d_functions.xml.xsl b/doc/xsl/list_3d_functions.xml.xsl
index f55f4535e..754b6b90c 100644
--- a/doc/xsl/list_3d_functions.xml.xsl
+++ b/doc/xsl/list_3d_functions.xml.xsl
@@ -29,13 +29,11 @@
 			<!-- For each section if there is note that it supports 3d catalog it -->
 						<xsl:for-each select="refsection">
-							<xsl:for-each select="para">
-								<xsl:choose>
-									<xsl:when test="contains(remark/@conformance, '3d')">
-										<listitem><simpara><link linkend="{$refid}"><xsl:value-of select="$refid" /></link> - <xsl:value-of select="$comment" /></simpara></listitem>
-									</xsl:when>
-								</xsl:choose>
-							</xsl:for-each>
+							<xsl:choose>
+								<xsl:when test="descendant::node()[@conformance='3d']">
+									<listitem><simpara><link linkend="{$refid}"><xsl:value-of select="$refid" /></link> - <xsl:value-of select="$comment" /></simpara></listitem>
+								</xsl:when>
+							</xsl:choose>
 						</xsl:for-each>
 				</xsl:for-each>
 				</itemizedlist>
diff --git a/doc/xsl/list_curved_geometry_functions.xml.xsl b/doc/xsl/list_curved_geometry_functions.xml.xsl
index 96040059c..b87abfbbd 100644
--- a/doc/xsl/list_curved_geometry_functions.xml.xsl
+++ b/doc/xsl/list_curved_geometry_functions.xml.xsl
@@ -31,13 +31,11 @@
 			<!-- For each section if there is note that it implements Circular String catalog it -->
-								<xsl:choose>
-									<xsl:when test="contains(remark/@conformance, 'curve')">
-										<listitem><simpara><link linkend="{$refid}"><xsl:value-of select="$refname" /></link> - <xsl:value-of select="$comment" /></simpara></listitem>
-									</xsl:when>
-								</xsl:choose>
-							</xsl:for-each>
+							<xsl:choose>
+								<xsl:when test="descendant::node()[@conformance='curve']">
+									<listitem><simpara><link linkend="{$refid}"><xsl:value-of select="$refname" /></link> - <xsl:value-of select="$comment" /></simpara></listitem>
+								</xsl:when>
+							</xsl:choose>
 						</xsl:for-each>
 				</xsl:for-each>
 				</itemizedlist>
diff --git a/doc/xsl/list_sqlmm_functions.xml.xsl b/doc/xsl/list_sqlmm_functions.xml.xsl
index a7e825fe3..7010808ae 100644
--- a/doc/xsl/list_sqlmm_functions.xml.xsl
+++ b/doc/xsl/list_sqlmm_functions.xml.xsl
@@ -28,13 +28,11 @@
 			<!-- For each section if there is note that it implements SQL/MM catalog it -->
 								<xsl:choose>
-									<xsl:when test="contains(remark/@conformance, 'sqlmm')">
+									<xsl:when test="descendant::node()[@conformance='sqlmm']">
 										<listitem><simpara><link linkend="{$refid}"><xsl:value-of select="$refid" /></link> - <xsl:value-of select="$comment" /> <xsl:value-of select="." /></simpara></listitem>
 									</xsl:when>
 								</xsl:choose>
-							</xsl:for-each>
 						</xsl:for-each>
 				</xsl:for-each>
 				</itemizedlist>
Summary of changes:
 doc/xsl/list_3d_functions.xml.xsl              | 12 +++++-------
 doc/xsl/list_curved_geometry_functions.xml.xsl | 12 +++++-------
 doc/xsl/list_sqlmm_functions.xml.xsl           |  4 +---
 3 files changed, 11 insertions(+), 17 deletions(-)
hooks/post-receive
