[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1121-gb3ccbe14b
Tue Jul 4 16:15:14 PDT 2023
the project "PostGIS".
       via  b3ccbe14b21fe47c4f1c16308112cad36d484e07 (commit)
      from  ed155046b7d8af7803c73da16833079775cad3ab (commit)
revisions in full, below.
commit b3ccbe14b21fe47c4f1c16308112cad36d484e07
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Jul 5 01:12:41 2023 +0200
    Add chunked-html-localized rule
    References #5429
diff --git a/doc/Makefile.in b/doc/Makefile.in
index e17c0a266..ab9811e55 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -299,7 +299,7 @@ postgis-out.xml: postgis.xml Makefile
 chunked-html: postgis-out.xml Makefile images $(XML_INPUTS)
 	$(XSLTPROC) $(XSLTPROC_COMMONOPTS) \
-		--output html/ \
+		--output html$(DOCSUFFIX)/ \
 		$(CHUNK_HTML_DOCBOOK_XSL) \
@@ -322,10 +322,11 @@ chunked-html-web-mobile: postgis-out.xml Makefile images $(XML_INPUTS)
 html: html/postgis$(DOCSUFFIX).html
-html-localized:
-	@for lang in $(translations); do \
-    echo "Creating html for language $$lang..."; \
-    $(MAKE) -C po/$$lang local-html || exit 1; \
+html-localized chunked-html-localized:
+	rule=$(patsubst %-localized,%,$@); \
+	for lang in $(translations); do \
+    echo "Creating $$rule for language $$lang..."; \
+    $(MAKE) -C po/$$lang local-$$rule || exit 1; \
   done
 html/postgis$(DOCSUFFIX).html: postgis-out.xml Makefile images $(XML_INPUTS)
diff --git a/doc/po/Makefile.local b/doc/po/Makefile.local
index 8ca8f1fc5..a347803b9 100644
--- a/doc/po/Makefile.local
+++ b/doc/po/Makefile.local
@@ -3,17 +3,8 @@
 local-all: local-html comments
-local-html: symlinks
-	$(MAKE) html
-local-cheatsheets: symlinks
-	$(MAKE) cheatsheets
-local-pdf: symlinks
-	$(MAKE) pdf
-local-check: symlinks
-	$(MAKE) check
+local-html local-cheatsheets local-pdf local-chunked-html local-check: symlinks
+	$(MAKE) $(patsubst local-%,%,$@)
 symlinks:
 	rm -f html; ln -s ../../html html
Summary of changes:
 doc/Makefile.in       | 11 ++++++-----
 doc/po/Makefile.local | 13 ++-----------
 2 files changed, 8 insertions(+), 16 deletions(-)
hooks/post-receive
