[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1122-g01254db73
Tue Jul 4 21:08:36 PDT 2023
the project "PostGIS".
       via  01254db7360f5f79302f290538964ea4f8e65505 (commit)
      from  b3ccbe14b21fe47c4f1c16308112cad36d484e07 (commit)
revisions in full, below.
commit 01254db7360f5f79302f290538964ea4f8e65505
Author: Teramoto Ikuhiro <yellow at affrc.go.jp>
Date:   Wed Jul 5 02:42:46 2023 +0000
    Translated xsl-config using Weblate (Japanese)
    Currently translated at 100.0% (17 of 17 strings)
    Translation: postgis/xsl-config
    Translate-URL: https://weblate.osgeo.org/projects/postgis/xsl-config/ja/
diff --git a/doc/po/ja/xsl-config.xml.po b/doc/po/ja/xsl-config.xml.po
index 9bbbc8b97..2d37e34e0 100644
--- a/doc/po/ja/xsl-config.xml.po
+++ b/doc/po/ja/xsl-config.xml.po
@@ -6,114 +6,64 @@
 # #-#-#-#-#  tag_curve_support.xml.po (pg 13)  #-#-#-#-#
 # Japanese translations for pg package.
 # Automatically generated, 2023.
 # Teramoto Ikuhiro <yellow at affrc.go.jp>, 2023.
 # #-#-#-#-#  tag_geography_transform.xml.po (ming 64gcc81)  #-#-#-#-#
 # Japanese translations for ming package.
 # #-#-#-#-#  tag_index_aware.xml.po (pg 13)  #-#-#-#-#
 # #-#-#-#-#  tag_M_support.xml.po (pg 13)  #-#-#-#-#
 # #-#-#-#-#  tag_P_support.xml.po (pg 13)  #-#-#-#-#
 # #-#-#-#-#  tag_sfcgal_enhanced.xml.po (pg 13)  #-#-#-#-#
 # #-#-#-#-#  tag_sfcgal_required.xml.po (pg 13)  #-#-#-#-#
 # #-#-#-#-#  tag_sfs_compliant.xml.po (pg 13)  #-#-#-#-#
 # #-#-#-#-#  tag_sqlmm_compliant.xml.po (pg 13)  #-#-#-#-#
 # #-#-#-#-#  tag_T_support.xml.po (pg 13)  #-#-#-#-#
 # #-#-#-#-#  tag_Z_support.xml.po (pg 13)  #-#-#-#-#
 # #-#-#-#-#  xsl-config.xml.po (PACKAGE VERSION)  #-#-#-#-#
 # Japanese translations for PACKAGE package.
-#, fuzzy
 msgid ""
 msgstr ""
 "Project-Id-Version: PACKAGE VERSION\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2023-07-04 20:03+0000\n"
-"PO-Revision-Date: 2023-06-30 05:08+0000\n"
+"PO-Revision-Date: 2023-07-05 04:08+0000\n"
 "Last-Translator: Teramoto Ikuhiro <yellow at affrc.go.jp>\n"
-"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/xsl-"
-"config/ja/>\n"
+"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/"
+"xsl-config/ja/>\n"
 "Language: ja\n"
 "MIME-Version: 1.0\n"
 "Content-Type: text/plain; charset=UTF-8\n"
 "Content-Transfer-Encoding: 8bit\n"
-"#-#-#-#-#  tag_address_standardizer_required.xml.po (pg 13)  #-#-#-#-#\n"
-"Plural-Forms: nplurals=1; plural=0;\n"
-"X-Generator: Weblate 4.16.4\n"
-"#-#-#-#-#  tag_curve_support.xml.po (pg 13)  #-#-#-#-#\n"
-"#-#-#-#-#  tag_geography_transform.xml.po (ming 64gcc81)  #-#-#-#-#\n"
-"#-#-#-#-#  tag_index_aware.xml.po (pg 13)  #-#-#-#-#\n"
-"#-#-#-#-#  tag_M_support.xml.po (pg 13)  #-#-#-#-#\n"
-"#-#-#-#-#  tag_P_support.xml.po (pg 13)  #-#-#-#-#\n"
-"#-#-#-#-#  tag_sfcgal_enhanced.xml.po (pg 13)  #-#-#-#-#\n"
-"#-#-#-#-#  tag_sfcgal_required.xml.po (pg 13)  #-#-#-#-#\n"
-"#-#-#-#-#  tag_sfs_compliant.xml.po (pg 13)  #-#-#-#-#\n"
-"#-#-#-#-#  tag_sqlmm_compliant.xml.po (pg 13)  #-#-#-#-#\n"
-"#-#-#-#-#  tag_T_support.xml.po (pg 13)  #-#-#-#-#\n"
-"#-#-#-#-#  tag_Z_support.xml.po (pg 13)  #-#-#-#-#\n"
-"#-#-#-#-#  xsl-config.xml.po (PACKAGE VERSION)  #-#-#-#-#\n"
@@ -165,7 +115,7 @@ msgstr "このメソッドは曲線ストリングと曲線に対応していま
 #, no-c-format
 msgid ""
 "For geography this is a thin wrapper around the geometry implementation."
-msgstr ""
+msgstr "この関数のジオグラフィ版はジオメトリ実装にかぶせた薄いラッパです。"
 #. Tag: para
 #: xsl-config.xml:88
@@ -210,7 +160,7 @@ msgid ""
 "</ulink>"
 msgstr ""
 "このメソッドは<ulink url=\"http://www.opengeospatial.org/standards/sfs\">OGC "
-"Simple Features Implementation Specification for SQL 1.1.</ulink>の実装です。"
+"Simple Features Implementation Specification for SQL 1.1</ulink>の実装です。"
 #. Tag: para
 #: xsl-config.xml:144
Summary of changes:
 doc/po/ja/xsl-config.xml.po | 60 ++++-----------------------------------------
 1 file changed, 5 insertions(+), 55 deletions(-)
hooks/post-receive
