[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1133-gbe40ce36e
Wed Jul 5 06:07:41 PDT 2023
the project "PostGIS".
       via  be40ce36e6e26f9875c08810c97ecf0e961d0e93 (commit)
       via  c1dcfb099017c11fda924b63b4620ed11c847210 (commit)
      from  4ea1204dc513e4fdc35023078f7c643e354830ba (commit)
revisions in full, below.
commit be40ce36e6e26f9875c08810c97ecf0e961d0e93
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Jul 5 15:07:14 2023 +0200
    Remove debbie-unused file, to avoid confusion
diff --git a/ci/debbie/postgis_doc_translations.sh b/ci/debbie/postgis_doc_translations.sh
deleted file mode 100644
index 30e157863..000000000
--- a/ci/debbie/postgis_doc_translations.sh
+++ /dev/null
@@ -1,81 +0,0 @@
-#!/usr/bin/env bash
-set -e
-## begin variables passed in by jenkins
-# export PG_VER=9.2
-# export PGPORT=8442
-# export OS_BUILD=64
-# export POSTGIS_MAJOR_VERSION=2
-# export POSTGIS_MINOR_VERSION=2
-# export POSTGIS_MICRO_VERSION=0dev
-# export JENKINS_HOME=/var/lib/jenkins/workspace
-# export GEOS_VER=3.4.3
-# export GDAL_VER=2.0
-# export MAKE_GARDEN=1
-# export MAKE_EXTENSION=1
-export PG_VER=13
-export OS_BUILD=64
-#this is passed in via postgis_make_dist.sh via jenkins
-#export reference=
-export GEOS_VER=3.10
-export GDAL_VER=3.4
-## end variables passed in by jenkins
-export PROJECTS=${JENKINS_HOME}/workspace
-export PGPATH=${PROJECTS}/pg/rel/pg${PG_VER}w${OS_BUILD}
-export PATH=${PATH}:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}/bin
-export POSTGIS_SVN_REVISION=${SVN_REVISION}
-echo $PATH
-cd ${WORKSPACE}/docs/branches/${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}_translations
-sh autogen.sh
-if [ -f GNUMakefile ]; then
-  make distclean
-fi
-#  --with-gdalconfig=${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}/bin/gdal-config
-#  --without-raster
-CPPFLAGS="-I${PGPATH}/include"  \
-LDFLAGS="-L${PGPATH}/lib"  ./configure \
-  --with-pgconfig=${PGPATH}/bin/pg_config \
-  --with-geosconfig=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}/bin/geos-config \
-  --without-raster --without-protobuf
-make clean
-cd doc
-make update-pot
-make pull-tx
-mv postgis.xml postgis.xml.orig
-sed -e "s:</title>:</title><subtitle><subscript>SVN Revision (<emphasis>${POSTGIS_SVN_REVISION}</emphasis>)</subscript></subtitle>:" postgis.xml.orig > postgis.xml
-make check-localized
-#make pdf
-rm -rf images
-mkdir images
-cp html/images/* images
-#make epub
-#make -e chunked-html 2>&1 | tee -a doc-errors.log
-#make update-po
-make html-localized
-# make -C po/es/ local-html
-# make -C po/fr/ local-html
-# make -C po/it_IT/ local-html
-# make -C po/pt_BR/ local-html
-# make -C po/pl/ local-html
-# make -C po/ko_KR/ local-html
-cp -R html/*.*  /var/www/postgis_docs/manual-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}
-cp -R html/images/* /var/www/postgis_docs/manual-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}/images
-chmod -R 755 /var/www/postgis_docs/manual-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}
-#add back make pdf but after html copy so will work even if pdf generation fails
-make pdf-localized
-cp -R po/*/*.pdf /var/www/postgis_stuff/
-chmod -R 755 /var/www/postgis_stuff/postgis-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}*.pdf
commit c1dcfb099017c11fda924b63b4620ed11c847210
Date:   Wed Jul 5 15:05:38 2023 +0200
    Fix chunked install/uninstall targets
diff --git a/doc/Makefile.in b/doc/Makefile.in
index 7778a96c7..69c918b42 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -482,18 +482,18 @@ chunked-html-uninstall:
 	rm -rf $(DESTDIR)$(htmldir)/postgis/postgis$(DOCSUFFIX)/
 chunked-html-web-install: chunked-html-web
-	mkdir -p $(DESTDIR)$(html-webdir)/postgis
-	cp -R html-web/postgis-web$(DOCSUFFIX) $(DESTDIR)$(html-webdir)/postgis/
+	mkdir -p $(DESTDIR)$(htmldir)/postgis
+	cp -R html/postgis-web$(DOCSUFFIX) $(DESTDIR)$(htmldir)/postgis/
 chunked-html-web-uninstall:
-	rm -rf $(DESTDIR)$(html-webdir)/postgis/postgis-web$(DOCSUFFIX)/
+	rm -rf $(DESTDIR)$(htmldir)/postgis/postgis-web$(DOCSUFFIX)/
 chunked-html-web-mobile-install: chunked-html-web-mobile
-	mkdir -p $(DESTDIR)$(html-web-mobiledir)/postgis
-	cp -R html-web-mobile/postgis-web-mobile$(DOCSUFFIX) $(DESTDIR)$(html-web-mobiledir)/postgis/
+	cp -R html/postgis-web-mobile$(DOCSUFFIX) $(DESTDIR)$(htmldir)/postgis/
 chunked-html-web-mobile-uninstall:
-	rm -rf $(DESTDIR)$(html-web-mobiledir)/postgis/postgis-web-mobile$(DOCSUFFIX)/
+	rm -rf $(DESTDIR)$(htmldir)/postgis/postgis-web-mobile$(DOCSUFFIX)/
 html-assets-install: images-install
 	$(INSTALL_DATA) html/style.css $(DESTDIR)$(htmldir)/postgis/
Summary of changes:
 ci/debbie/postgis_doc_translations.sh | 81 -----------------------------------
 doc/Makefile.in                       | 12 +++---
 2 files changed, 6 insertions(+), 87 deletions(-)
 delete mode 100644 ci/debbie/postgis_doc_translations.sh
hooks/post-receive
