[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1137-g2de1941c3
Wed Jul 5 06:42:51 PDT 2023
the project "PostGIS".
       via  2de1941c3724543a2fb76d00ed82e9c7df101fe9 (commit)
      from  3bfa91c6ff748ca4150d9e6d64094851fee1ee3c (commit)
revisions in full, below.
commit 2de1941c3724543a2fb76d00ed82e9c7df101fe9
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Jul 5 15:42:39 2023 +0200
    [debbie] use the install targets for html
diff --git a/ci/debbie/postgis_release_docs.sh b/ci/debbie/postgis_release_docs.sh
index e28dc9e95..60bfff88e 100644
--- a/ci/debbie/postgis_release_docs.sh
+++ b/ci/debbie/postgis_release_docs.sh
@@ -14,6 +14,7 @@ export WEB_DIR=/var/www/postgis_stuff
 export PGPATH=${PROJECTS}/pg/rel/pg${PG_VER}w${OS_BUILD}
 export PATH="${PGPATH}/bin:$PATH"
 export LD_LIBRARY_PATH="${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}/lib:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}/lib:${PGPATH}/lib"
 ./autogen.sh
@@ -22,8 +23,9 @@ POSTGIS_MAJOR_VERSION=`grep ^POSTGIS_MAJOR_VERSION Version.config | cut -d= -f2`
 POSTGIS_MINOR_VERSION=`grep ^POSTGIS_MINOR_VERSION Version.config | cut -d= -f2`
 POSTGIS_MICRO_VERSION=`grep ^POSTGIS_MICRO_VERSION Version.config | cut -d= -f2`
-mkdir -p /var/www/postgis_docs/manual-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}
-chmod -R 755 /var/www/postgis_docs/manual-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}
+# TODO: take base as env variable ?
+HTML_DIR=/var/www/postgis_docs/manual-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}
 echo $PATH
 #sh autogen.sh
@@ -39,7 +41,8 @@ CPPFLAGS="-I${PGPATH}/include"  \
 LDFLAGS="-L${PGPATH}/lib"  ./configure \
   --with-pgconfig=${PGPATH}/bin/pg_config \
   --with-geosconfig=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}/bin/geos-config \
-  --without-raster --without-protobuf
+  --without-raster --without-protobuf \
+  --htmldir ${HTML_DIR}
 make clean
 # generating postgis_revision.h in case hasn't been generated
@@ -56,9 +59,9 @@ make cheatsheets
 #sed -e "s:</title>:</title><subtitle><subscript>SVN Revision (<emphasis>${POSTGIS_SVN_REVISION}</emphasis>)</subscript></subtitle>:" postgis.xml.orig > postgis.xml
 echo "Micro: $POSTGIS_MICRO_VERSION"
-cp postgis.xml postgis.xml.orig #we for dev will inject stuff into file, so backup original
 #inject a development time stamp if we are in development branch
 if [[ "$POSTGIS_MICRO_VERSION" == *"dev"* ]]; then
+  cp postgis.xml postgis.xml.orig #we for dev will inject stuff into file, so backup original
   export GIT_TIMESTAMP=`git log -1 --pretty=format:%ct`
   export GIT_TIMESTAMP="`date -d @$GIT_TIMESTAMP`" #convert to UTC date
   echo "GIT_TIMESTAMP: ${GIT_TIMESTAMP}"
@@ -70,23 +73,20 @@ fi
 make pdf
 make epub
 make -e chunked-html-web # TODO: do we really want this too in the doc-html-*.tar.gz package ?
 make html-localized # TODO: do we really want this too in the doc-html-*.tar.gz package ?
 package="doc-html-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}.tar.gz"
 export outdir=html
 tar -czf "$package" --exclude='.svn' --exclude='.git' --exclude='image_src' "$outdir"
+# Install all html
+make html-assets-install
+make html-install
+make chunked-html-web-install
+make html-install-localized
+make chunked-html-web-install-localized
+chmod -R 755 ${HTML_DIR} # TODO: still needed ?
-cp postgis.xml.orig postgis.xml
-# TODO: Replace all of this by `make html-install` and friends
-mkdir -p /var/www/postgis_docs/manual-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}/images
-cp -R html/*.*  /var/www/postgis_docs/manual-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}
-cp -R html/images/* /var/www/postgis_docs/manual-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}/images
 # TODO: Replace all of this by `make *-install`
@@ -95,10 +95,16 @@ cp -R *.epub /var/www/postgis_stuff/
 cp -R $package /var/www/postgis_stuff/
-#rename the files without the micro if it's a development branch
+  #rename the files without the micro if it's a development branch
   for f in ${WEB_DIR}/*${POSTGIS_MICRO_VERSION}; do
     newname=$(echo "$f" | sed "s/${POSTGIS_MICRO_VERSION}//");
     mv -vi $f $newname
   done
+  # restore the backedup xml file
+  cp postgis.xml.orig postgis.xml
 fi
Summary of changes:
 ci/debbie/postgis_release_docs.sh | 36 +++++++++++++++++++++---------------
 1 file changed, 21 insertions(+), 15 deletions(-)
hooks/post-receive
